Question about Medea VideoRaid RT
Hi...My Medea RT VideoRaid just went on the blink... it no longer appears on my MAC desktop and the blue lights don't stay on. One light (of 5) cycles on and off independently from the others, while the others cycle on and off in sync. Sound familiar to anyone???
  • Wendy Jan 11, 2009
    Hi...Thanks for your feedback. I think you're right that the interface is no longer recognizing the hard drive. Your suggested trying a file recovery program....Sigh. I'm a bit lost here. I have the Disk Warrior program. Again, the Videoraid is not showing up at all on my MAC. I'm not sure how to "look" at the inside of the drive---? I can tell you that everything went down when I was rendering a video composition yesterday and got an "error" message which ultimately jammed the system and forced me to manually reboot. Any other suggestions?? THANKS! Wendy
    A big thanks to Benimur! Will try Disk Warrior to recover and rebuilt disk directory. First, I'm transferring what I can in the project I'm working on to a different RAID. Turns out that I routed MOST of the actual vdieo and audio DATA for the project to this other RAID and was using the problem RAID for creating special effects and compositions. I now reassigned those functions to the working raid and am in the process of RE-RENDERING the project. After I see what I'm still missing, I'll proceed with the problem RAID.
    I'm more of an "artist" than a "technician," as you can see. Your help is very much appreciated as, it seems, MEDEA sold out to AVID and I'm not sure what kind of "servicing" I can now get on this machine.
    Have a great day!
  • 13,433 Answers
Check the powersupply and the drives. I suspect the powersupply may also be a problem with the drives, I'm not too fimiliar with this setup.
Posted on Jan 11, 2009
    Brigadier General:
  • 6,966 Answers
Hi again and welcome back to FixYa,
As it would seem that you were unable to view my Clarification post in your "Ask Me".
Initially, your description of "the power light, rather than stay on, is also cycling on and off" is indicative that the electronics/interface of the Medea VideoRaid is no longer recognizing the hard drive(s) installed inside (most likely), or the electronics/interface itself is faulty (least likely). You could try running a file recovery program/utility and see if files inside could be recovered (if needed) or run a partitioning/formatting utility. Otherwise it would be a hardware problem and of course would require the services of a qualified professional. If you are considering a DIY (do-it-yourself), then you must have access to the service manual and/or the checklist/procedures. You have an advantage since there are other Medea VideoRaid readily available for you to compare performance, voltage checks and temporary donor of parts or test bed.
Check and perform preliminary visual or necessary inspection of the inside. Pls post back result(s) with photos if at all possible.
Good luck and Thank you for using FixYa.
  • Louie  Role
    Louie Role Jan 11, 2009
    Appreciate the postback.
    I am not familiar with the Disk Warrior utility nor for that matter much about Mac OS. Even having said that, a recovery program is a recovery program and as the name implies, its purpose to extract files from a media that is no longer "readable/accessible". It is of course assuming that:
    • you still want to recover the contents of the erring Medea
    • the hard disk(s) are physically operational.
    It would be expected for your system to "jam" since initially the erring Medea
    VideoRaid was mounted and your Mac was accessing and storing/retrieving the video files from there. Sudden loss of the attached storage device is a major systems failure.
    Proposed course of action:
    • run the Disk Warrior. Should you be successful, you would need a comparably sized storage media to save the recovered video files, perhaps a spare Medea
    • should the recovery program be not successful, then it would be required to physically inspect the internal electronics of the Medea
    • primary focus should be on the supply voltage of the hard drive(s). Most hard drives need +12 & +5 VDC. A DVM (or VOM) would be needed to confirm their presence/absence;
    • if both voltages are missing, then focus should move to the power supply although I doubt this very much since the same power supply provides the needed voltage for the "blue lights" to operate;
    • next to be checked would be the hard drives themselves (most likely). They could be removed and checked externall individually but must be marked where it was originally positioned inside the machine. They should not be interchanged;
    • an external IDE/SATA to USB interface/adapter could be used to check if they will mount (individually) and therefore verify the integrity/operationability of each drive;
    • connecting the hard drive to the IDE/SATA to USB interface/adapter to your Mac's USB port should enable you to access the contents (not necessarily the video files);
    • being able to access the contents would indicate that that particular drive is operational;
    • depending the RAID formation/arrangement, it is imperative that both be operational;
    • it is also possible to install the drives in another Medea
      VideoRaid to determine if they will work and enable you to ascertain that the electronics interface/Medea
      VideoRaid is the one at fault and not the drives.
    Would appreciate again updates on developments.
What does the blue blinking light at the very bottom, under the blue power button indicates?
According to the Dell 531 owners manual:
"Drive activity light-
blue light - A blinking blue light indicates the computer is reading data from or writing data to the SATA hard drive, CD, DVD or HDD."
Safe to ignore. It will blink even when the computer appears to be idle.
Aug 15, 2011 | Dell Inspiron 531s Desktop Computer
The unit we have is the 5/600 RT3 P/N 904002-02 Turn it on it makes a regular "ticking" sound and i cannot access the drive. the desktop icon has disappeared as well as the rest avenues through...
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: for a "no data - no charge" guarantee.
Dec 13, 2010 | Medea VideoRaid 5160 SCSI Ultra160 Hard...
Medea VideoRaid RTR. Was initially set up on a win 98 or Win 2000 video editing machine(98 I think). PC long gone but still have the VideoRaid. I need to pull the files off it but cannot access it. It has...
try to hook it with a usb on xp...and if it doesnt appear on my computer add new hardware from the control not let it run auto..but choose from a list ..and specify thats a storage device...for to not being seen with the wrong driver ...
no matter if it seen as ok or not ..probably needs formatting cause the previous was an elder OS try just to right click on each drive and choose format might work ..but you will be loosing any data-s on it ..
another way is to hook each hdd one by one on the internal ide or sata ....depending on the plug ...(if they are having another kinda connexion ..just get a Rack that will make it connectible ..
remember to change the jumper configuration if you use them as slave ...
they will work ok after you will format them one by one in NTFS (or fat 32) ..and hook them back in the tower...
it also may be problem that one of them is corrupted...and in this way you will be able to identify it ...if one is corrupt ..they all have trouble cause they are somehow in serial connection...and seen as one...
Jan 02, 2010 | Medea Video Raid RTR 5/720 720GB Array...
Imac not booting
Hi, Sorry you're having trouble,
OK, so much is happening here...
Can you shut the Mac down ( by holding the power on button for 5 seconds or so ) and then, make sure your keyboard is connected and that nothing is resting o the keyboard possibly pressing down on a key without you knowing it....
Now, start up your Mac and VEY QUICKLY, press down on the ( alt ) key and hold it down until you see a blue screen with a large Right pointing arrow and a circular arrow.
This is the start up disk selection screen. You should eventually see your Hard Drive appear at which point, you click on your hard drive and then the right arrow to start up the mac on your Hard drive.
If your disk is still OK, it will boot properly.
If your disk does not appear in the blue selection screen, it means you either no longer have a valid bootable system on that disk or it is KAPUT.
So, if this is the case, you will need to get a new hard drive.
How old is your mac, what model is it what Mac OS is it ?
Mar 22, 2009 | Computers & Internet
Malfunctioning Medea RT 4/180 VideoRaid
Hi again,
Glad to be of some assistance and appreciate the rating too in your Premium Problem.
Pls update status if and when convenient.
Jan 11, 2009 | Medea VideoRaid RT
No pix
Have audio? I turned off my speakers so I couldn't tell. Blue light? Does it blink twice then stay solid? They went through the 2 large panels and power supply and couldn't get it to work. Solution was plasma panel was shot. $3000 bill.
I'm waiting to hear from others if it was one of the smaller boards around the edges as I have a giant piece of metal in my basement that I get to dispose of. My sony 52" should be here tomorrow.
May 30, 2008 | Hitachi 55HDS69 55 in. Plasma Television
Medea VideoRaid RT Logo
69 people viewed this question
Top Medea Computers & Internet Experts
David Payne
David Payne
Are you a Medea Computer and Internet Expert? Answer questions, earn points and help others
