Question about Dryers
Makes a loud noise when running
Has the ind replaced three times
    Top Expert:
  • Dryers Master
  • 9,472 Answers
Could you please describe the problem you are having a little better?
Posted on Dec 01, 2012
TheMobilian
  • 8220 Answers
SOURCE: Dryer makes loud noise
Probably a bad set of glides.
ea82af1.jpgor worse.Check out my BLOG on this
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on May 20, 2009
  • 72 Answers
SOURCE: Dryer makes a loud noise when running.
check rollers and idler besure and watch how you remove belt its tricky
Posted on Jul 01, 2009
TheMobilian
  • 8220 Answers
SOURCE: My GE gas dryer makes a loud squeeking noise running
WE 3X 75 is the part number you need. Take a look at these repair pix
Posted on Sep 09, 2009
  • 73 Answers
SOURCE: makes loud noise when running
bad berring that the drum rides in
Posted on Oct 02, 2009
  • 254 Answers
SOURCE: loud noise while running
you are gonna have to get inside the unit to determine whats defective...
if you want a parts breakdown i would recomend going to sears. com clicking on the section parts and service usually upper right corner, then click parts, u should be in their parts direct section enter you model number which u can find when u open ur dryer door their should be a sticker or tag somewhere that will list it.. find ur model or sometin similiar uually last digits designate color so it doesnt matter. you can see how the unit comes apart or get prices or part numbers on specific parts.
I would personally check the operation for defectiveness on your belt,rollers, idler pully, and possibly a seal if yor dryer has sometype of glides or seal.. hope this helps
Posted on Feb 02, 2010
Sprinkler pump makes loud noise when it is running, how to fix?
Typically this sound indicates bearings going out. Usually this means replacing the motor, or may be repairable depending on size and make.
Jan 11, 2013 | Pool & Spa
Amana AFD2535FES makes loud buzzing noise
When a start relay and the coil that opens the water for the ice maker or the water dispenser begin to weaken they some times buzz. Its possible you will need to either replace the=> 67003753 Water Inlet Valve
or the compressor=> 67005560 Relay or overload with run capacitor
Here is a parts manual for your=> AFD2535FES and a user manual=> HERE If you have questions please ask thanks Sea Breeze
Oct 18, 2012 | Amana AFD2535FES Stainless Steel Bottom...
Makes a loud noise like a grinding noise then smokes comes out and it smells like burning rubber? When I take the (rod) brush off with the belt then run the vacuum there is no more noise? Please help me...
Your belt is worn and stretched and so it is slipping on the motor drive shaft. That is why it is noisy and smells like burning rubber. You simply need to replace the belt. You can get replacement belts here:
Replacement Vacuum Belts
Nov 30, 2009 | Vacuums
Sep 09, 2009 | GE Dryers
Makes very loud noise at start up.
It sounds like the bearings are going bad on the motor. Does it make the same sound when it is running?
Aug 09, 2009 | AO Smith 2 HP 115/230V 56C Replacement...
CAR IS RUNNING ROUGH HAS 122K. MAKES LOUD NOISE
With that many miles, I think you need to replace the timing chain or belt. Also if you havent changed the plugs, plug wires, fuel filter and had the fuel injectors cleaned lately, this might help.
Jul 17, 2009 | 2003 Nissan Xterra
When running it makes a loud continuous loud noise
Your bearing are failing. Replacing them and the seal at a local electric motor repair shop will likely cost around $50.
Jun 02, 2009 | Polaris 380: Polaris Booster Pump
When running it makes a loud noise
Jun 02, 2009 | Polaris Pb460 Polaris Booster Pump...
Grinding Noise
you an remove lower access panel run d/w and nextime it makes the noise grab a flashlight and take a look under. sounds like a vibration issue( especially since you hit it nad it stops) perhaps your copper water line is rattling or your drain line is hitting motor causing noise
Feb 23, 2008 | Dishwashers
Dryers Logo
27 people viewed this question
Top Dryers Experts
