Question about Northland 60SS-WS Side by Side Refrigerator
Draw slide - Northland 60SS-WS Side by Side Refrigerator
    Top Expert:
  • Northland Master
  • 9,472 Answers
Could you please describe the problem you are having a little better?
Posted on Nov 30, 2012
Bottom refrigerator crisper drawer slide fell off
draw slide is mounted to the shelf bracket --either order new bracket or remove bracket [look how slide positioned on other side ] and try drilling and putting in small screw and nuts till you can order a replacement bracket
Sep 09, 2016 | Refrigerators
Dealer says only 5 of 6 sensors on sliding door are making a connection. The sensor not working is drawing power, effectively killing my battery every 3 weeks or so.
Does your vehicle sit for 3 weeks at a time? There will always be a draw on the battery. It is called a parasitic draw. This draw comes from computers and modules within the vehicle to maintain memories. If the vehicle sits for 3 weeks or more, this small drain will deplete the battery. If the vehicle is driven daily and every 3 weeks the battery goes dead overnight, the draw will have to be high. If the door is the problem, I would suspect the battery to be dead every morning. Removing the door fuse will illiminate the door as the problem. The life expectancy of an automotive battery is 5 years. Anything older can start to cause electrical problems.
Jan 20, 2016 | 2006 Honda Odyssey
How do I get a stuck DVD out?anks
Contact Philips customer support at: http://www.support.philips.com/support/contact/contact_page.jsp?userCountry=us&userLanguage=en
Apr 14, 2015 | Philips Magnavox 26MD357B-37 26 in. LCD...
Hi the vege draw on the bottom always freezers the veges the draw above is fine i have tried sliding the open/close lever also where to purchase replacement draws and milk shelf
USUALLY A PROBLEM WITH THE AIR FLOW DAMPER CONTROL AND OR THE FRIDGE THERMISTORS> IS THE FREEZER OK? IF U HAVE A BAD DOOR SEAL OR CLOGGED DRAIN PLUG U CAN GET CONDENSATION THAT MAY FREEZE AT BOTTOM AS WELL
Mar 16, 2015 | Refrigerators
Power cannot be turned on. led display not on
Check that the draws are closing properly and evenly , there is a door sensor just inside the frame top and bottom on the right side .
If thr machine is not level the doors can slide forward.
if this does not work , feel if the draw really locks in when closed because at the back of the draw slides on each side are two plastic lock mechanisms. when the draw has been out they need to be upwards facing so when closed thy lock the slides in on both sides . Sometimes thy only lock in one side causing it not to deactivate the door sensors and shut down .
Yes it sounds simple, but most problems i have found are
Feb 03, 2014 | Fisher and Paykel DishDrawer DS605FDSM...
Need to remove upper drawer Fisher and Pykel dd605ss
Open the top draw. On each side of the draw at the bottom / front, is a clip that releases the rails that the draw slides in and out on. Press the clips in to release and slide it back (into the machine as if you were closing the draw). Do this one at a time and then lift the draw slightly and rotate the draw anti-clockwise direction (due to the plumbing) and lay the draw on its left hand side. The draw is out!
Oct 18, 2012 | Fisher and Paykel DD605SS Stainless Steel...
The DVD player slide draw will not open or close
Check for a manual eject slide on the bottom near the front of the tray
Nov 21, 2009 | Philips DivX DVD Player
WATER IS POURING OUT THE DISPENSER DRAW OF MY WF000G
Normally if you take the soap slide draw out,you will see a hole underneath where the slide draw was. It normally blocks up with undesolved soap. Clear the channel then retry.Or sometimes water pressure is to high and then tends to splash internally causing water to drip out. Also make sure the slide draw is cleaned properly..
Sep 21, 2009 | Washing Machines
Self Propel Belt, how to replace with the new one
First I suggest you either take a digital picture or draw the belt wrap...that way you'll know how to wrap new belt. You'll need to remove both front wheels and pinion drive stubs. Slide the shaft out far
enough so you can install new belt on lower sprocket. push belt up through access opening in deck.
Then finally install the new belt..make sure to slide belt over sprocket on shaft coming out of motor block last. It might require a std. screwdriver to slide belt over edge of sprocket. Re-assy wheels etc.
If you feel like this task is too tough..just draw yourself an assy. drawing as to how it comes apart, it will be worth it when you re-assy.
May 29, 2009 | Toro Lawn Mower With Toro Power Tools
I need to have a mirror image of text in power point .
If you are using PowerPoint 2007, here is how you can accomplish this:
Select the text, Then right click and select Format Shape, Then select 3-D Rotation, then change the X value to 190 degrees.
In PowerPoint 2003, you can't create mirrored text,, you can however use WordArtto create a graphic image of text that you can mirror by using the Rotate or Flip command.
To create mirrored text with WordArt, follow these steps:
  1. On the Drawing toolbar, click Insert WordArt.
  2. In the WordArt Gallery, select the WordArt style that is closest to the effect that you want to use, and then click OK.
  3. In the Edit WordArt Text dialog box, type the text that you want.
  4. Click OK.
  5. Use the tools on the Drawing and WordArt toolbars to format the text the way that you want.
  6. On the Drawing toolbar, click Draw, point to Rotate Or Flip, and then click Flip Horizontal.
You will see a mirror image of your text.
Apr 07, 2009 | Microsoft Computers & Internet
Northland 60SS-WS Side by Side Refrigerator Logo
46 people viewed this question
Top Northland Refrigerators Experts
Cameron Dyer
Cameron Dyer
Level 1 Expert
Bill Boyd
Terry Weaver
Terry Weaver
Are you a Northland Refrigerator Expert? Answer questions, earn points and help others
