Washing machine will fill up but do nothing else
Washer was working fine unhooked hoses to clean lines now will only fill nothing else HELP
    Problem Solver:
  • 11 Answers
Did you check the safety switch it is located in the front right corner it works when you put the lid down you can take it out and connect the two wires together and see what it does then
Posted on Jan 11, 2009
Washer fills extremely slow. Hoses are fine water
Hi, check to see if there's good water volume coming through the hoses attached to the washing machine. If there is, check to see if the screens inside the water-inlet valve are clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If they're clean, you probably have a defective water-inlet valve. If so, you should completely replace the valve.
Jun 19, 2011 | Maytag PAV2300 Top Load Washer
Slow filling of water
Where the water hoses plug in the back, unhook both lines from the washing machine. There are filters in the back of the washer. Make sure that they are clean.
Jan 14, 2011 | Whirlpool Washing Machines
GE Model WHRE5550K will not fill with water, fill light will not illuminate
Check the fill lines, on the back of the unit two hoses go into the machine. Unhook them from the washer not the wall, you will find screens in the hoses clean them off and your good to go.
Dec 16, 2010 | GE WHRE5550K Top Load Washer
Fills cold and warm but not hot
This is a common problem with hot water lines to washing machines. The hose connecting the washing machine to the hot water supply has a small screen in the inlet of the hose. These are used to keep grit, etc from getting into the washing machine and causing bigger problems.
Here's what to do:
Pull the washing machine away from the wall a little so you can access the shut-off's. Turn off the hot and the cold water valves.
Take the hot water hose off the valve and check the screen in the rubber washer of the inlet hose. Replacement screen/washers are available at local hardware stores for a couple bucks.
You can clean the old ones, just be careful not to damage the rubber washer because that's what keeps your hose from leaking when you reinstall it on your faucet.
While you're at it, clean the cold water screen as well.
REcheck your fill on a hot cycle... you've most likely solved your issue!
May 09, 2010 | Washing Machines
Water pumping in very slowly and uneven flow
The washer filling so slowly can get very irritating and frustrating..most of the time the fix is very simple. The hoses have a screen in them to catch any dirt that may come in the water and this screen plugs up.
Simply unhook the hoses at the washer and clean the screens.
This tip will explain this in more detail for you..
Washing Machine Fix Washing Machine No Water
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
May 05, 2010 | Fisher and Paykel WL37T26D Top Load Washer
Washer stops after aggatating and wont drain
My Kenmore 70Series washer goes through the wash cycle then just stops when it is to drain and then spin.
Jun 10, 2009 | Whirlpool Washing Machines
Washer will not turn on
You have some scale or something keeping the water fill valve open most likely. If it still tries to fill unplug the machine if it still tries to fill do the following. Remove the fill valve and disassemble it. If you see the dirt or rust flush it out when it looks clean reassemble it and before you attach the hoses put them in the washer and turn them on to flush out the lines then reattach hoses and try it.
If this helps you please rate me with as high a retign as possible. If not please restate your problem and help me understand better what trouble your having. Thnks for using fixya and good luck.
Jan 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine will not fill w/ hot or cold water
Could be an air lock in the water pipes,turn off the water to the washer, disconnect the hoses, and hold them over the sink or into a bucket, then turn the water taps back on to the washer.
The water should come through at full pressure.,
If it does not , then the problem is with your supply and not the washer.
Hope this helps.
Plz leave feedback.
Ta.
Dec 09, 2008 | GE WBSE2090A Top Load Washer
My GWL11 won't fill correctly or wash!
Hi there you need a new cold valve in the washing machine. :)
Sep 17, 2008 | Fisher and Paykel GWL11 Top Load Washer
I have a whirlpool front load washing machine model WFW8300SW00
Hay Crab.
what I have found is that the washer thinks it is not pumping out .. if your drain pump is clearly removing the all the water in a good time... then the problem is your pressure switch...it is telling the computer that it still has water in the machine...
replace the pressure switch and it will solve your f21 error.
It is a round unit on the right hand side on top...with a tube and wires going to it...let me know if it helps
Apr 05, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
