Hoover WMH147DF machine - door will not open
Have a Hoover WMH147DF machine. It will complete any programme requested. Then reports END and the door lock light is not on. Problem is that the door will not open, when I try to open door the door lock light comes on. I have already cleaned out the drain filter. Any other ideas?
5 Suggested Answers
  • 101 Answers
SOURCE: Door on the Hoover washing machine, model H130E
make sure the tap is not broken off ,if the tap is good that means you switch is bad, replace it. hope this information could help you.
Posted on Apr 23, 2008
  • 353 Answers
SOURCE: i have an electrolux EWX14440W Washing machine,
could be your door interlock is faulty
Posted on Mar 02, 2010
blueextc3221
  • 15935 Answers
SOURCE: candy GO 146 washing machine. cycle does not complete
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
  • 6277 Answers
SOURCE: I have a hotpoint ultima WDD960 washing machine.
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 08, 2011
My belling washing machine doorv wont open
from the factory info,,,
door lock is activated because of the water level in the machine.
Drain the water by running the Pump or Spin programme.
• Machine is heating up the water or it is at the spinning cycle.
Wait until the programme completes.
• Child lock is engaged. Door lock will be deactivated a couple of minutes after the programme has come to an end.
Wait for a couple of minutes.
when in doubt unplug for 5 minutes and plug back in and see if that resets the unit.
Hope this helps a little.
Jan 09, 2018 | Belling Washing Machines
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
Dyn8163d8p
Has the programme finished but the door remains locked? Turn the machine to OFF to reset the machine and this will allow the door to open.
Then look at this > Has the programme finished? Is the END light illuminated? If not the programme is not complete. Has the door locked light gone out? If not wait a further couple of minutes and the light will go out and you will be able to open the door.
If nothing happens and door still locked, and you live in the UK you need to ring this number > Phone 08444 995 599 to book your repair
E05 is a fault on the temperature sensing circuit. You need to check the wiring to the temperature sensor at the bottom rear of the tub. (circular item near the element). Unplug it, check the terminals and the wiring, check the connector on the sensor. If all ok, take the sensor out, clean it and refit it. Try the machine again. If the fault persists and the wiring and connections are good, you'll need to try a new sensor. Check it out, see how it goes and get back to me if you need more help Hope this helps
May 12, 2014 | Hoover Washing Machines
My Hoover Optima WMH147DF has gone nuts.
call a local repair service , we can not fix control boards that wiggle
Jan 08, 2018 | Washing Machines
The functions has stoped but the door is not getting open.the model is hoover nextra.what i should do to get the door open?
switch off at the wall then manually drain the water using the (emergency drain outlet near bottom) if your model does not have one of these turn on and off at wall then set the wash programme to drain only this will be indicated in the manual of on the programme guide on the front panel.
Now your door should unlock once the water is drained.
Feb 28, 2011 | Hoover AL120 Front Load Washer
Superwash button constant flashing
I do not have a solution but also have the same issue. That is when putting on a cotton programme, the superwash light comes on at the end of the programme and I am unable to open the door as it remains locked. I then have to put it to a rinse or spin cycle as it does not seem to have spun the clothes at all.
Jul 15, 2010 | Hoover H140E Front Load Washer
Wash programme will not start
If your machine will not start or complete the programme..
  • The plug, the socket and the switch, if necessary, with another appliance.
  • The fuse in the plug.
  • That the door is closed.
  • That a programme is accurately selected.
Jan 18, 2010 | Hoover AAA160 Front Load Washer
Door won't open on Hoover vhd9163zd washing machine
THE DOOR MAY HAVE A TIME RELESE SWITCH CHECK IN MANUAL
Dec 24, 2009 | Washing Machines
Washing Machines Logo
43 people viewed this question
Top Washing Machines Experts
