Usb on arris dg950 modem?? connect for network printer??
oldnovii
  • 667 Answers
SOURCE: how is Arris Telephony Modem installed?
Hi taldrich6 - You have this listed under Arris CM450. Is that what you have?
Posted on Jul 22, 2008
djxtreme979
  • 151 Answers
SOURCE: Switched to cable(arris modem) can't set up network
cable dsl same thing. Did you switch providers and get new modem from them? If so. Just delete previous netowrk and install new one let pc discover new one. Also, with your router you got a disc. It should install correctly. Perhaps it is previous network that is hindering you.
Posted on Dec 30, 2008
  • 31 Answers
SOURCE: connecting my arris modem to x-box live
I have an Arris cable modem and use Xbox live. They work very well together. Most ISP's will only allow one active device at a time. When you switch between you cable modem and your Xbox you need to use a pen and press the reset button on the arris every single time you switch.
Posted on Apr 09, 2009
  • 31 Answers
SOURCE: connecting a network printer to 2wire 2701HGV-w
This is a little tricky technically it your printer isn't made to go onto the network, but you and do one of to things... let me start with the most cost effective way and that is
1. Hook your Printer up to a computer that is already on the network and then go into windows and SHARE that printer giving access to all the computers to print to it that you need to. I don't know what Operating System you have so your going to have to give more information to get clarification on exactly what you need to do in the Operating System to share the printer. The CONS of this approach is that you can only print to that printer when that computer is on. So if you want to have continuous ability to print to that printer you will have to keep your computer on.
2. You can get what they call a Print Server... and connect it to your printer and your network.. turning your printer into a network printer. Of course you might need to get more detail depending on what Print Server you choose. The Cons of this approach is that ofcourse your going to have to buy more equipment... but the pro's are you won't have to keep other computers on in the network to print to it. One last note you will find Print Servers in the store where you find Routers and Hubs.
The best of luck to you... and I hope this Helps... after you decide which way you want to go you might want to contact me or one of the other techs to get more percise approaches to installing your equipment... but we will need to know you Operating System, and the Print Server... if you go that route. Good Luck! I hope this works for you!!!
Sincerely,
cdixon18
The Man Inside the Machine
Posted on May 20, 2009
  • 17 Answers
SOURCE: Arris cable modem
if the power light is flashing then the modem is on battery backup and internet is disabled. plug the power cord into the modem or find a working power outlet, you should be set after that.
Power light flashing=bad
Posted on Jul 04, 2009
I have a modem arris cm450b, i bought splitter to use 2 cables but the the cable connected to my sons computr isn't working
That is not the right way to do it. Connect one computer to the cable modem using an USB A/B cable from the USB port on the modem to an available USB port on the computer and connect the second computer to the modem Ethernet port-to-Ethernet port using an Ethernet cable (probably the modem came with one Ethernet cable).
Hope this helps.
Oct 14, 2014 | Arris Touchstone 450a (CM450) Modem
Cant connect modem to new wireless brother printer
It is best you contact Arris support. Mark Motorola Mobility Support ARRIS
Jun 17, 2014 | Motorola Computers & Internet
Can't Connect TV to Wifi
You have to go to network setting on tv and printer and find something that says ip and set it to automatic
Dec 02, 2013 | Arris Computers & Internet
There is no internet connection to the laptop. The arris modem gives internet acess to the PC computer, though. The manual for the Airlink 101 router says to connect the router and MODEM to each other by a...
What you're missing is that ALL the PCs will be connecting THROUGH the router to the Modem. Unplug the PC network Cable from the modem, then plug a network cable from the router's INTERNET port into the modem (where you removed the PC's network cable). Now, plug the PC's network cable into one of the ports on the router (usually 4 or more, marked 1,2,3,4. Think of a Router as a "splitter". It connects to the Modem, then several devices connect to the Router, some of them by wire and some by Wi-Fi. So your desktop PC is connected by wire to the router and your laptop PC is probably connected by Wi-Fi (wire is an option, as well). The Router sorts out all those signals and communicates with the Modem. Sound reasonable?
May 02, 2017 | Arris Comcast Touchstone Telephony VOIP...
I have my main computer set yp with arris router
  • You can use both Ethernet and USB interface to connect two PCs simultaneously with one cable modem.
  • If you plan to go wireless (and maybe connect more computers), you have to purchase a router to split/share the internet connection coming from the modem.
Apr 07, 2010 | Arris Touchstone 450a (CM450) Modem
We have just signed up for cable TV/high speed internet/cable telephone. The modem provided is an "Arris" version 1.5. The cable tech said I could connect my Belkin G router so that more than one computer...
Plug the ethernet net cord into the arris ethernet port. plug the other end into the router where it says "internet"
Plug a ethernet cable from one of the router ports to the computer.
First start up the arris modem, then power up the router, then start the computer.
Oct 22, 2009 | Belkin 802.11g Wireless Desktop Network...
I am looking for usb driver for arris rndis modem model number is tm602g
http://www.drivers-fix.net/arris.php. Comcast sometimes has drivers for this device. Use the ethernet connection if you can cause Arris EMTA's usb outputs **** unless your trying to do both which is what I think your doing. If your computer only has a USB connection look for adaptors
Oct 11, 2009 | Arris Touchstone 450a (CM450) Modem
Need solution to Networking 2 comps thru an Arris tm602g/ct via a linksys 8 port switch, the seems to be no Usb connection on the modem
You will need to purchase a router my friend. The arris does not have a DHCP server built in and cannot assign IP addresses to the work stations. The only way that could work is if you ISP provided you with a second IP address, which would also be extremely unsafe from a security standpoint. Any wireless router should do the trick.
Mar 18, 2009 | Arris Touchstone 450a (CM450) Modem
Unable to connect Linksys wireless router to my arris cm450a
All routers will only work with ethernet. You would need to get an ethernet card installed in your computer. You can probably buy one for about 20.00 at Walmart. If you don't want to do this you can purchase a usb/ethernet adapter and still use the usb port on your computer. You can purchase one of these for around 5.00's on ebay. Just go to ebay and search for usb/ethernet adapter. Please rate if this has helped. Thanks.
Jan 31, 2009 | Arris Touchstone 450a (CM450) Modem
No driver for my modem
There are no drivers for the arris cable modem unless you are using USB.
If you are using ethernet then it is simply plug and play. You may need to press the reset button on your arris.
Thank you.
Jan 20, 2009 | Arris Touchstone 450a (CM450) Modem
Open Questions:
Have A Non Responsive Touch Screen. Can I Recover My Data? These days, not only businesses but individuals increasingly need access to their data on the go without thinking about storage and hardware maintenance costs. Online Cloud backup provides an efficient solution and is swiftly attaining popularity. Before cloud-computing, end users stored their personal data on computer's hard drives and memory cards. Unfortunately, computers and mobile phones require physical proximity to the device to allow access to the stored data and are far more vulnerable to damage and accidental deletion. Individual devices need diligent support and maintenance, and ensuring the security of the data remains a challenge. With Online Cloud Backup, end users can upload documents, photos and videos to the cloud and then fetch them at their ease. This helps them save storage space on their computers and mobile devices. Furthermore, the cloud based structure allows end users to upgrade software more quickly - because software Cloud Backup publishing companies choose to offer their products via the web rather using traditional, tangible methods that involve discs or flash drives. Top software publishing companies have chosen to turn their business models to subscription based and they deliver their product offerings through cloud solutions. An online backup service isn't much capable if the process of restoring your data and getting back to being productive is not simple and quick. DataAlign offers a Computer Data Backup search tool to find a backed-up file. Also, the ability to replicate an entire folder-tree structure, helps with preventing bigger data losses. Versioning is another capability offered by DataAlign. This allows you to see earlier versions of a file in case you made Business Server Data Backup some undesired edits. This can also be termed as archiving function. You can set the number of versions and days you wish to keep any file and utilize the maximum available storage space. Using the version history, you can view the history of each file stored and undo mistakes, if required. Any accidental deletion of file from the computer and can be restored instantly as deleted files are backed up on the cloud. The moment the data is no longer required, you can setup a data destruction policy.
May 21, 2018 | VIA Computers & Internet
Computers & Internet Logo
357 people viewed this question
David Payne
David Payne
