Question about Xerox WorkCentre 7228 7235 7245 7328 7335 7345 Fuser Cartridge 008R13028
How do i reset my drum for xerox workcentre 7345
You can't reset the drums counter on the machine. The drum has what they call a CRUM on it. It's the micro chip on the drum frame. You can buy new CRUM's or use one that still has some life on it. Press the two plastic retainers to remove the CRUM.
Posted on Mar 07, 2013
5 Suggested Answers
  • 2072 Answers
SOURCE: We have a Xerox Workcentre Pro575; it has an error
NOTE: Perform the following procedure to reset the Drum Cartridge counter after you replace the Drum Cartridge. Do not perform this procedure at any other time.
  1. From the Standby Mode, press the [Menu] (up arrow) button, then press [5], [2], [0], [4]. The screen will display: Change drum.
    1. Yes
    2. No
  2. Press [1], then press [Enter]. The screen will display: Completed.
  3. Press [Stop] to return to the Standby Mode.
Posted on Nov 05, 2009
Testimonial: "Thanks very much, worked like a charm!"
  • 2072 Answers
SOURCE: Replace Drum
Start by trying this.
    1. Yes
    2. No
If that doesn't work try this. You may not be able to perform step 1 but that's ok.
> Support & Drivers > WorkCentre Pro 555 Support > Search Results Solution: Print / Clear Documents From Memory bttn_print.gifMake Printable bttn_email.gifEmail this page elem_1_spacer.gif
Any documents stored in memory due to an error condition will print after the error is corrected. The errors may be: 'paper tray(s) out of paper,' 'paper jam,' or 'out of ink'.
  1. Print a Pending Jobs report to determine what types of jobs are in memory. Press the [Menu] (up arrow) button, then press [2], [2].
  2. If there is a job with the status of Resend Stored Fax, turn off the Resend Stored Fax feature to delete the job.
    To turn off Resend Stored Fax:
    1. From the Standby Mode, press the [Menu] (up arrow) button, then press [5], [3], [0], [4].
      The screen will display: Resend stored fax
      1. On
      2. Off
    2. Press [2] to disable the feature.
    3. Press [Exit] or [Stop] when the menu selection screen displays to return to the Standby Mode.
  3. Print the ITU-T mailbox report to determine if there are any mailbox documents. From the Standby Mode, press the [Menu] (up arrow) button, then press [2], [4].
  4. Print any documents stored in an ITU-T Mailbox:
    1. From the Standby Mode, press the [Menu] (up arrow) button, then press [1], [8].
      The screen will display: Mailbox
      1. Confidential
      2. Bulletin board
      3. Relay request
      4. Setup & delete
    2. Press [1] to select Confidential mailbox, or [2] to select Bulletin board mailbox.
      The screen will display: Confidential (or Bulletin board)
      1. Print mailbox
      2. Send to mailbox
      3. Poll from mailbox
      4. Store to mailbox
      5. Delete contents
    3. Press [1] to print from the selected mailbox.
      The screen will display: Box number (20 max)
      [_]
    4. Use the numeric keypad to enter the mailbox number, then press [Enter]. NOTE: If you entered a password when creating the Confidential Mailbox, you must enter that password now to print the document.
    5. Enter the password if required, then press [Enter].
Posted on Jan 08, 2008
Avwrexit
  • 47 Answers
SOURCE: change the drum on xerox
Here is the pdf for the manual. Check out chapter 2 page 10 it has step by step instructions on installing the drum.. This should help in the removal of the drum also!
http://download.support.xerox.com/pub/docs/CopyCentre_C20/userdocs/any-os/en/UG_Eng.pdf
Good luck and dont forget to rate my response!!
Posted on May 31, 2008
  • 3 Answers
SOURCE: I need to know where
PostScript language support is available as an upgrade kit from Xerox - You need to buy it and I was advised it is around the £400 mark.
Posted on Jun 17, 2009
WorkCentre 7345 Fuser Assembly replace soon showing. please how i reset this
Replace the fuser assembly.
The fuser melts the toner ink onto the paper.
As such, it's a vital part of the printing process.
Mar 25, 2015 | Xerox WorkCentre 7328 7335 7345 7346...
Xerox 7345 error 004-361
what is the solution erro code 004 361 Machine docucolour 7345 ?
Dec 09, 2014 | Xerox WorkCentre 7228 7235 7245 7328 7335...
Erreur cod 009-330 xerox 7245
009-330 error code xerox work center 7345 problom & soluson
Jul 10, 2014 | Xerox WorkCentre 7228 7235 7245 7328 7335...
I have a Xerox workcentre 7345 and reported that the transfer belt cleaner needed to be replaced. I replaced it and the message is still appearing.
Hi, In my printer Xerox 7245 display it appears Replace Transfer belt error. So please guide me how to reset value without replacing ETB
Jan 14, 2011 | Xerox WorkCentre M-24 Color Copier
I used tranfer paper on the Xerox Workcentre 7345, have i caused major damage?
It's possible, transfer paper can melt to the fuser roller, the drum, and other rollers in the printer and leave them sticky and unusable. Problems can manifest right away, if the plastic crud left behind is think. Or they can manifest several days later as toner turns the clear melted plastic black.
If several days later your still running, you're probably safe.
Jun 03, 2010 | Xerox WorkCentre M-24 Color Copier
Xerox WorkCentre 7228 7235 7245 7328 7335 7345 Fuser Cartridge 008R13028 Logo
1,979 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
