Question about Dishwashers
Lg dishwasher
I have a 7 month old LG D1454TF dishwasher it was not cheap which has worked fine until now , it keeps showing EI and IE error message which it states there is a hose leakage or water leakage. This is definatley not happening . I wonder if anyone has had the same problems with their LG dishwasher i had a so called lg engineer he put in new pcb and the IE and EI tells me it was my fault owner miss use??
4 Suggested Answers
SOURCE: LG Dishwasher
according to the manual that i have just downloaded from the net,E1 code means.water leakage in Hose connections.
.water is leaked by damages
hope this helps,
keith
Posted on Oct 20, 2007
Falling Down
  • 67 Answers
SOURCE: LG dishwasher, LD14AT2
the level switch usually a two-or three inch plastic floating device on the base of the dishwasher that looks like a rounded tube. You should be able to pull the top up and down freely otherwise it may be clogged. If you listen closely, you may be able to hear the microswitch inside click as the unit is moved up and down.
Posted on Nov 30, 2007
  • 110 Answers
SOURCE: E1 error on LG - LD-4120M
E1 is a common error in the LG Dishwasher range and is usually caused by the failure of the circulation pump and/or the impeller.
The motor and impeller are a complete unit.
Often what happens is the impeller breaks on the motor shaft and doesn't spin, therefore doesn't pump water.
There is a pressure sensor which indicates the lack of pressure and shuts the machine down with the E1 error being displayed.
The lack of pressure can also be from a water leak (as the owners manual suggests) also a controller PCB fault may produce an E1 error, however, the pump problem is extremely common.
Unfortunately, I have had 5 pumps die in 4 years and my dishwasher is only used about 4 times a week.
Posted on Dec 27, 2007
Lg ldf7932ss growling noise at wash cycle
The LG is known for the main motor bearings (2 small cheap) bearings that are of poor quality and become noisy (growls) after a period of time. I pulled the motor and replaced the Korean bearings with quality German equivalents. This is cheap and solves the problem. (the front bearing closest to the plastic pump is the culprit.
Mar 15, 2013 | LG LDF7932ST Builtin Dishwasher
LG LD2131SH Dishwasher displays a ie error
Hi santjiesfras,
The error code your receiving is an "Inlet Error" message. This means that no water is going into the Dishwasher. Please check the following:
1) Is the tap open.
2) Is the inlet hose kinked?
3) Is your water pressure fine? Because anything less than 0.3kgf/cm(bar) is not going to work
If all of the above is fine, then take off the inlet hose of the dishwasher, and clean the filter which is between the hose and machine (small circular filter). If still not working, then you will need to replace the inlet valve. I would suggest getting a L.G service agent to do so.
Good Luck :-) - J.Q
* If you found this solution helpful, please vote positively. A 4 four thumbs up will do nicely too :-)
Apr 13, 2011 | Dishwashers
Hi I have an LG LD - 14AW23 dishwasher. It shows an IE error (no water) but it fills, stops and then gives the error message. What's thye problem? Many thanks, John
Hi
Error code IE on LG dishwasher means Inlet error. This error comes up when the Water Supply Tap is closed or Water Supply is shut off. If water supply is turned on then make sure that the Inlet Hose is not kinked and water Pressure is not low (should be above 10 psi). Next thing to check for is Water Inlet Valve, measure the electric resistance of Inlet Valve. (950-1300 ohms) Make sure the filter of Inlet Valve is not clogged.
Hope this helps... Please post back for further assistance.
Daniel
Mar 26, 2011 | LG 24 in. LDF 7811 Built-in Dishwasher
LG dishwasher LD-2120WHU I get the
This happens to my LG dishwasher every 6 months or so. It also makes a groaning sound as if the system is starved for water. The resolve the problem by removing the dishwasher and laying it over on it's right side. I then remove the two plastic assemblies that are on the left side and I remove them from the dishwasher (you will need a vice grips to remove the hose clamps from behind them, you will also need to remove the round circular water intake plastic disk that is on the inside of your dishwasher on the left hand side right in the middle of the left wall) and clean them. Once the water can run freely through these plastic parts you will get a good water flow and you should be fine. Until you have time to do this I recommend putting a few quarts of hot water into your dishwasher once you start to hear the groaning problem. This solution should be very easy for anyone who is comfortable doing their own oil change. Oh, and turn off the power supply first.
May 26, 2010 | Dishwashers
IE error code, machine keeps on draining
It sounds like the flood switch in the bottom of the washer is activated. check for water in the base as the machine if maybe leaking. This is a Dishwasher?
Feb 24, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
LG LD-A2T2 Dishwasher returns Error code E1
EI is an error to do with your drain. Check your drain hook up. You should have a loop out side the unit, it should be a minimum 40in in height, or put in a air break. What I believe is happening is your unit is siphoning out. Fix this and you will be able to stop washing the dishes by hand.
Sgt 48
Jun 18, 2008 | LG Dishwashers
LG Dishwasher Model LD-14AW3
I have had this dishwasher about 4 years, it has work beautifully, then one day there just wasn't any power going to it. Have tried different power points and no change. Looked for a fuse, was unable to find one. The power cord coming into the machine is undamaged. Any suggestions.
Mar 28, 2008 | LG 24 in. LDF 7811 Stainless Steel...
IE error message
Hi, had the same problem on a LG LD 12aw5. (No water entering). Check the inlet solonoid. There should be 220V over the solonoid. I replaced the solonoid, at first, just to have the same problem. The problem was a bit more serious, the Triac driving the solonoid burnt out, and the solder on the mainboard keeping the transformer were shot to. I replaced the Triac, soldered the Transformer - and wolla - working. If water enters - but you sill get the IE error it could be the float(checks the water level). This device tells the machine when there is enough water. If this is stuck, the machine will think no water is entering. conrad_dot_dewet@gmail.com - replace "_dot_" with "." to email me.
Apr 05, 2007 | LG 24 in. LDF 7811 Stainless Steel...
Dishwashers Logo
62 people viewed this question
Top Dishwashers Experts
