Question about LG WM2701HV Washer
Washer stalls at 7 minutes remaining during the spin cycle and does not continue to finish no matter what setting or cycle. I have unplugged and I have stopped and started the washer 4 different time. What else can I do.
SOURCE: vibration during spin cycle
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Posted on Dec 13, 2008
  • 132 Answers
SOURCE: LGWM2277HW Front Load High Efficiency set Code "LE"
may be a belt problem since you have this sound
thank you
Posted on Jun 21, 2009
  • 160 Answers
SOURCE: Error code FE
From the manual ,FE means Water level is too high due to a faulty water valve. hence the possible leak
Posted on Dec 22, 2009
  • 161 Answers
SOURCE: Washer will not stop shaking during spin cycles
Place a load in the machine use a good level to get machine perfectly level. Now put machine on spin and check the feet. Find the one that is not solid and slowly adjust it until it stops shaking. PS place level on flat top surface and level side to side and front to back.
Posted on Jan 26, 2010
  • 713 Answers
SOURCE: LG WM0642H washer "excessive" vibration
sounds like damper rods are getting worn. they support bowl underneath.i think if u change them it should fix problem. is it noisy during spin?if u need more help please reply. please turn power off b4 working on it do not want any accidents.
Posted on Apr 10, 2010
Washer stops during normal wash cycle for a minute or more, and then continues. Would replacing the timer fix it?
If it actually goes on and finishes the cycle and that really bothers you replace it. If not leave it alone and allow a little more time to complete its cycle. The lid switch only keeps the spin cycle from going with the top open.
May 23, 2014 | Whirlpool Washing Machines
I have a Whirlpool duet front load washer model # GHW9150PWD. I have an error code of F 02 and SUD. I have so far cleaned the filter and the lines, replaced the pump, replaced the water pressure swith and...
6 - 1
DIAGNOSIS & TROUBLESHOOTING
SUDS DETECTION
During Drain Routine
During the Drain Routine, the water level is checked continuously. Normal drain will occur until the
pressure switch senses no water in the wash tub and there is no foam (suds). The drain pump will
operate an additional 15 seconds after the pressure switch reports no water or foam.
If the drain routine operates for four (4) minutes and the pressure switch senses any foam (suds) in
the wash tub, the Central Control Unit will start the "Kill-Foam" Routine. (See description of this
Routine below.) After the Kill-foam Routine is concluded, the Drain Routine will restart. If, after
four (4) minutes the pressure switch still senses foam in the wash tub, the Central Control Unit will
go into Failure Mode. The digital display will show, F02.
During Spin (Extract) Routine
During the Spin/Extract Routine the water level is checked continuously. If, during this routine, the
pressure switch senses the presence of foam (suds) in the wash tub, the Central Control Unit will
stop the drive motor and the basket will stop spinning. The electronic control will count the number
of spin repetitions that are attempted due to foam (suds). There are a maximum of three (3)
attempts for each Spin/Extract Routine.
Kill-Foam Routine
1.
The Remaining Time counter is stopped.
2.
The digital display shows Sud.
3.
The Drain Pump is turned OFF.
4.
The Central Control Unit will fill the wash tub with 1 gal. (4 L) of cold water.
5.
While the tub is filling the basket will tumble 1 sec. ON/15 Sec. OFF.
6.
Once the tub is filled, the drive motor will turn OFF and the basket will rest without any
movement for five (5) minutes.
7.
After the five (5) minute rest, the remaining time counter will restart and the digital display
will show the remaining time left in the routine.
NOTE:
If the Kill-Foam routine was initiated during a Spin/Extract Routine, the tumbling action
will be reduced to a cycle of 3 sec. ON/13 sec. OFF. If, at the end of either the Drain or Spin/
Extract Routines, a suds condition still remains, the digital display will show Sud.
Sud will also be displayed for a short period at the end of a cycle, if a Suds condition was
detected during the cycle. This will alert the consumer to reduce the amount of detergent in
subsequent uses MANUAL
Oct 31, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Our whirlpool sport will not drain, 5d code has appeared. what can we do
SUDS LOCK (OVERDOSE OF DETERGENT DETECTED DURING THE WASH CYCLE)
If suds are detected continuously by the pressure switch during the drain or spin phases, the washer will fill 4 liters of water and during 5 minutes the unit will rest without tumbling, the water will be drained and it will try to spin or drain again.
Possible Causes/Procedure
• If too much detergent was used:
- Run the unit through a RINSE/SPIN cycle.
- Run a NORMAL cycle without adding any detergent,
• This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump, pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic Test or any cycle.
Nov 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine stopped and says "sud". What does that mean?
SUDS DETECTION
Kill-Foam Routine
1. The Remaining Time counter is stopped.
2. The digital display shows Sud.
3. The Drain Pump is turned OFF.
4. The Central Control Unit will fill the wash tub with 1 gal. (4 L) of cold water.
5. While the tub is filling the basket will tumble 1 sec. ON/15 Sec. OFF.
6. Once the tub is filled, the drive motor will turn OFF and the basket will rest without any
7. After the five (5) minute rest, the remaining time counter will restart and the digital display
NOTE: If the Kill-Foam routine was initiated during a Spin/Extract Routine, the tumbling action
subsequent uses.
Oct 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore HE2 won't finish spin cycle
you have blockage in you drain plug. to solve this problem you'll have to remove the lower front panel of your machine by removing the 3 (1/4") screws on the vary bottom of the machine. once the panel is removed you'll see a 1 1/2" white PVC drainage plug. turn the inner plug to the left in till open. (WARNING ALL THE WATER IN THE DRUM WILL DRAIN THOUGH THIS PLUG) remove debris likes socks or everything that's there replace the panel and your all set.
May 28, 2009 | Kenmore HE2 Plus Front Load Washer
Whirlpool top Loading washing machine won't spin on spin cycle
If the washer won't finish a spin cycle, it probably means that your timer went bad or stalled. You can take the control panel off and look at the contacts for scorching or corrosion.
Sep 21, 2008 | Whirlpool LCE4332P 2.1 cu. ft. Top Loading...
GWL11 Machine adds water during spin cycle and leaks on floor
diverter valve is not switching to pump the water out. instead it is resurculating back into the tub.
Oct 14, 2007 | Fisher and Paykel GWL11 Top Load Washer
LG WM2701HV Washer Logo
69 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
