Question about Watches
Manual breil milano BW0384 - Watches
3 Suggested Answers
SOURCE: Need to reset the time. Side knob will not pull
Is it a pull out or a screw? My Breil 0080 is a screw... when i first got it, i couldn't pull it out either. Try turning it counter clockwise.
Posted on Sep 23, 2010
  • 5 Answers
SOURCE: I need the manual of
The crown has 3 positions.
Normal screwed down.
First pull out position.
Second pull out position.
Setting the Time:
Pull out the crown to position 3.
Rotate the crown to set the exact time.
Ensure that you are in the daytime12 hour segment by allowing the hands to pass 12 o'clock and notice if the date moved on or not.
If the date changed, then you will need to advance at least 2 hours before moving on to set the date.
If you do not need to change the date, return the crown to position 1.
Setting the Date:
DO NOT DO THIS IF THE WATCH IS BETWEEN 8pm & 2am
Pull crown to position 2.
Rotate the crown clockwise to set to the correct date.
Return the crown to position 1.
Setting the Alarm [12 hour]
Pull the crown to position 2.
Rotate the crown anti clockwise to move the alarm hand to the desired time.
To activate the alarm, press the 8 o'clock button. You will hear 2 beeps.
To deactivate the alarm, press the 8 o'clock button. You will hear 1 beep.
NB If the alarm is not cancelled while it sounds the first time, it will repeat again in 2 minutes time. The alarm sound last for 15 seconds. If the alarm time coincides with 1 beep of the countdown, the alarm function will be cancelled.
Battery EOL [End Of Life]
The Swiss ISA 8270 movement uses a 395 cell and will signify a low power state by advancing the small seconds hand 4 steps every 4 seconds.
Setting the Countdown
You can specify a countdown of between 1 and 10 minutes.
Press the 4 o'clock button to enter setting mode. You will hear 1 beep.
Press the 4 o'clock button to move the central timing hand successively to the desired countdown time.
Wait 3 seconds for the watch to automatically exit the setting mode.
You can change the duration of the countdown [except in the last minute] at any time.
e.g. If the countdown is set to 10minutes, and you now want to change the countdown to 9 minutes, press the 4 o'clock button. The hours/seconds counter sub-dial will perform one complete turn and then stop at 60, before continuing.
Activating the Countdown:
Press the 2 o'clock button to start the countdown. You will hear 2 beeps.
When the countdown begins, the hour/seconds counter sub-dial indicates the seconds with 1 step every 2 seconds, and the central timing hand indicates the minutes with 1 step being 2.4 seconds.
Countdown tone:
There are 2 beeps every minute.
in the last minute:
50 seconds=1 beep.
40 seconds=1 beep.
30 seconds=2 beeps.
20 seconds=2 beeps.
10 seconds and less=1 beep every second with zero being 1 second long beep. Timer function automatically starts.
Timer:
After countdown has finished the timer starts automatically.
The central timing hand indicates the minutes with 1 step every 12 seconds. The hour/minutes counter sub-dial indicates the hours up to a maximum of 96.
Press the 4 o'clock button to see the timer seconds [display lasts up to a minute].
Press the 4 o'clock button to see the timer hours.
The timer has a maximum time of 96 hours [4 days] after which the hour/seconds sub-dial counter will stay at 0 and the central timing hand will stay at 12.
Start/Stop Timer:
Press the 2 o'clock button to stop the timer. You will hear 1 beep.
Press the 2 o'clock button to resume the timer. You will hear 2 beeps.
Setting the Countdown & Timer:
Countdown reset:
Press the 2 o'clock button to stop the countdown. You will hear 1 beep.
Press the 4 o'clock button to reset.
Setting the Timer:
Press the 2 o'clock button to stop the timer. The hour/seconds counter sub-dial will show the elapsed hours and the central timing hand the elapsed minutes.
Press the 4 o'clock button to view the seconds elapsed on the hour/seconds counter sub-dial.
Resetting the Hands:
If the hands do not zero correctly, which might occur after a battery change or a violent shock, you can make adjustments by doing the following settings as long as the countdown is not in operation.
To correct the hour/seconds counter sub-dial, pull the crown out to position 2 and wait 1 second.
Press either the 2 or 4 o'clock button; the central timing hand will turn and stop [not necessarily at 12].
Press the 2 o'clock button to increment the hours/seconds counter sub-dial hand to position it at 60.
To correct the central timing hand, press the 4 o'clock button to increment the hand to the 12 position.
If the battery had been replaced, the central timing hand defaults to the 10 minute position. If the battery had not been replaced, the central timing hand will return to the previously set position.
Posted on Jun 09, 2011
How can you get an instruction manual for this Breil Milano BW 0493 watch?
Manufacturers don't usually reinvent the wheel. You may be able to find something from one of these: http://fitness.manualsonline.com/manuals/mfg/briel/briel_watch_product_list.html
Jun 18, 2014 | Breil Milano Bw0493 Milano Chrono Lady...
I just got new watch Breil bw0484. How do I activate the watch?
It should start working by pushing the crown all way in.
if not, then your Breil needs a new battery.
www.tictacarea.com
Feb 19, 2014 | Watches
How do i reset the big hand to zero. it is the chronograph
pull crown out to second position then press start button till it gets to zero then push crown back in
Sep 15, 2013 | Briel Breil Mediterraneo Time watch...
Need to purchase a replacement rubber strap for my Breil watch. The strap # is BW0379. Where may I purchase one?
visit http://www.kkhservices.co.uk/ All Breil straps are very expensive ive just found out as i need to replace my rubber strap and was quoted £57 and £150 for a metal bracelet!!!!!
Aug 31, 2011 | Briel Breil Bw0379 Mediterraneo Chrono...
The long second/split time hand resets to 58secs and not 00secs
You have to set the long second by pulling the crown to it's third position(which you can set the time) then push the upper button until you reach 00 then push again to normal position. that's it. i hope i had helped you...
Jul 10, 2011 | Briel Breil Milano Chronograph BW0491...
How to set my breil chronograph BW0036B
have you figured it out?? If so can you help me?
Jun 28, 2011 | Watches
I need to fix the date on my breil tw0287. how can i do this?
mcdevit75 here, If your watch has a stem (winder) simply place your fingernail under the stem and gently lift the stem to it"s first notch (position) now you should be able to turn the stem (winder) to change the date push the stem back in when date is set.
Jun 23, 2010 | Briel Breil Globe BW0213 Watch for Men
Apr 06, 2010 | Watches
How can I determine the authenticity of my Breiling 1884 Automatic watch?
I would recommend taking it to your nearest Breitling Retailer and they can verify the authenticity of it.
Jul 26, 2009 | Breitling Hercules 246/GRY/PROF
Watches Logo
26 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
