Bizhub c454 jam code 9901
New machine it's giving me jam code 9901
2 Suggested Answers
taminol
  • 62 Answers
SOURCE: my brand new machine Bizhub 211 have paper jam problem
COF32 means the ATDC sensor has detected some unusually high or low readings.
The ATDC sensor measure the toner lever inside the developer unit.
Try swithcing on/off, open/close the front door to clear the code.
If this doesn't work, you'll need an engineer to reset the ATDC level.
Good luck
Tam
Posted on Apr 26, 2010
How can I enter system error clear in bizhub c 224e printer? Thank you, Uchenna.
Hope this helps
http://manuals.konicaminolta.eu/bizhub-C554-C454-C364-C284-C224/EN/contents/id16-0046.html
May 29, 2017 | In Office Equipment & Supplies
C454 scans have checkerboard pattern
the set up of the machine was not done properly, have a tech come and what is required
Apr 25, 2014 | Konica Minolta Bizhub C454 Color Copier
When scanning it gives error of deleting
are you using your phone and or Ipad to control the document feeder what do you mean operating remotely???????????? turn off the main power switch??????????????????
Mar 26, 2014 | Konica Minolta Bizhub C454 Color Copier
Am konica monlta c452
C-2553 is Magenta image unit so replace the unit, as for the 0214 0215 no such codes for that model of machine
Feb 18, 2014 | Konica Minolta Bizhub C452 Color Copier...
Konica minolta bizhub 7000 controller doesn't turn on
Turning the Power On or Off - Konica Minolta Online Manuals
manuals.konicaminolta.eu/bizhub-C554-C454-C364.../id10-0061.html
bizhub C554 C454 C364 C284 C224 ... The Main Power Switch of the machine and thePower key on the Control Panel. No. Name, Description. 1. Main Power Switch. Press this switch when turning on or off the main power of this machine or ...
[PDF]C7000/C7000P/C6000/C70hc/ C6000L
myworks.sindoh.com/upload2/.../d37800822888835787371.pdf
KONICA MINOLTA Confidential. 2. C-2721, Intermediate .... v) Execute Printercontroller calibration for every output profile. (Standard ..... Start CWS5 and login to a Fiery controller. ii) Click [Calibrate] ...... If FD skew doesn't remain,. FD skew ......*A1DURX01: For bizhub PRESS C7000/C6000 and bizhub PRO C6501. 2.
Feb 15, 2014 | Konica Minolta Konica Kit For Bizhub Press...
TROUBLE CODE C173
the error code given does not match any in the C452 diagnostics
if you meant CB173 then the error reports to the fax control pwb and page sizeing error. reseat the fax board/ reset the fax borad to factory and then reprogram to current location ( cleariing any possible programing mistakes previously) set the correct marketing area ( see service manual) it is very rare for a fax board to go down, the problem likely remains with its install/programming/firmware levels.
Jan 16, 2014 | Konica Minolta Bizhub C452 Color Copier...
TROUBLE CODE C173
Have a tech come out re-flash th copier os and also check the NVRAM board firmware, mite also be the control board
My brand new machine Bizhub 211 have paper jam problem
Good luck
Tam
Apr 12, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
516 people viewed this question
jasbo
jasbo
