Question about Kenmore Washing Machines
Do you sell just the spider assembly for w10269756 and if so what is the cost
I feel that for the spider assembly was poorly made to deteriorate like it did. I feel it should be replaced free of charge.If not the cost of a regular washing machine costs less than the part so I will discard this and may be buy a washing machine from some company like Home Depot but it won't be a Kenmore or Whirlpool.
SOURCE: replacing lid switch on Kenmore 80 series washing machine
It's attached under the top panel but depending on the year of manufacture it could be on the right, below a hole where the strike comes down or on the left rear under the console.
Posted on Jan 07, 2008
  • 132 Answers
SOURCE: whirlpool washing machine won`t spin or pump out
1-check the drain hose maybe cloged 2-check the drain filter maybe filed with materials 3- check no spin mode maybe you selected thank you
Posted on Jun 08, 2009
  • 25 Answers
SOURCE: My washing machine makes noise. I want a washing
all washing machines make some sort of noise LG make a washing machine that is a direct drive no belts or pulleys less vibration these seem to be a lot quieter
Posted on Jul 16, 2009
jsrock516
  • 5911 Answers
SOURCE: broken door latch whirlpool ghw9100lw1
The following link explains how to replace the door latch on a Whirlpool front loader:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
This is a very simple repair. I'm surprised at the cost of the labor you were quoted. An experienced technician can replace one of these latches in 30 minutes or less.
An alternate method of the replacing the latch is the remove the top panel of the washer and work down through the top. Due to variations in design features between models, this isn't always possible. If you want to remove the top panel, just locate and remove the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel will slide back, then lift off. If you have access the latch assembly from the top, you can attempt the repair using this method.
If you have any questions, please let me know. I hope this helps you.
Posted on Sep 02, 2009
  • 96 Answers
SOURCE: My Kenmore washing machine does everything but spin
yes that is how some parts are plus it is like a two hour job
Posted on Jan 01, 2010
So i just bought a kx 125 dirt bike and it's a 2003 and i got it off craigs list. The kid i got it from said he put a new clutch in it. Well it starts first kick but It's leaking a little oil and just...
Try adjusting the clutch cable on the handle bar; and find out where that leak is coming from and fix it; might be a simple gasket repair or maybe a hose deteriorated .
You don't want something like that to turn into costly repairs
They also have clutch rebuild kits that sell around $50.00
Mar 01, 2015 | Motorcycles
What is TSB 7/2006
TSB 7/2006
Subject/Concern: Hesitations; Poor or no start; Deteriorated fuel economy; Diagnostic trouble codes (DTC) P1412, P0490 and P1335 stored
Model: Focus C-MAX 2003.75 (06/2003?¿½) Build Date: 14.02.2004-01.03.2006
Build Code: 4R-6S
Assembly Plant: Saarlouis
Engine: 2.0L Duratorq-TDCi (DW) Diesel
Focus 2004.75 (07/2004?¿½) Build Date: Up to 01.03.2006
Build Code: Up to 6S
Assembly Plant: Valencia
Markets: All
Section: 303-08
Summary
Should a customer express concern about one of the following:
* hesitations,
* poor or no start,
* deteriorated fuel economy,
and upon investigation diagnostic trouble codes (DTC) P1412, P0490 and P1335 are stored in the powertrain control module (PCM), the probable cause is a sticky exhaust gas recirculation (EGR) valve.
To rectify this concern, a new EGR valve with a stronger EGR valve motor and revised PCM calibration should be installed.
Jun 23, 2014 | 2003 Ford Focus
Why does water still comes out of the backwash pipe?
Deteriorated internal valve multi-port gasket seal, commonly referred to "Spider" gasket. This has Failed. And allowing water to pass between the many ports within that valve, mainly between the "Return" port and the "Waste" port.
Most common reason these gaskets fail: Turning the valve handle while the pump is still "ON". Never do this!
Obtain another gasket, and plan on doing this yourself. Not that difficult. But if you feel you don't want to attempt, your local service provider should be able to do this very quickly & effectively.
It will look something like the one below. Imagine, one or most of the "Spokes" on that gasket can no longer remain in the recessed groove of the body due to detioration, therefore water will pass between the ports.
Jun 04, 2014 | Hayward SAND FILTER, PRO SERIES
I have a 2000 Chevy Blazer 4.3 4 wheel drive. It stalled and would not start again. The garage said the fuel pump and fuel regulator first , hen they replaced that they now say its the spider assembly on...
No.
The spider is one injector that supplies six small lines going to the cylinders instead of having one injector for each cylinder.
I would ask for a partial refund for parts and/or labor on the fuel pump job if that did not fix the problem. They should apply some or most of that cost to the cost of replacing the injector assembly if they diagnosed the problem as being the pump first.
Feb 20, 2014 | Cars & Trucks
W10269756 spider
Nope. They just want you to buy a new washer apparently. Like you would spend $600 on a friggen basket. Good lord.
Feb 02, 2014 | Washing Machines
Lg wd 10264
follow this steps and fix it. God bless you
  • The basket spider provides support and stabilization for the washing machine's basket. It is located at the back of the basket and has three arms, which are attached to the basket by three bolts. Although the machine's basket is made of stainless steel, the spider is not. It is composed of an inexpensive, white, aluminum metal, also known as "pot metal," which is subject to corrosion. Eventually, the aluminum or pot metal deteriorates to the point where the spider breaks during a wash cycle - accompanied by very loud noises. According to one repairman, the sound mimics that of a car collision. The amount of corrosion behind the basket can be enough to fill a pint container.
Life Expectancy
  • The spider basket in a front-load washing machine does not have a long life expectancy. According to the appliance repair website Suds and Service, pot metal basket spiders in small front loaders, those with a capacity of 16 lbs. to 17 lbs., have a life span of only five to six years. These short-lived basket spiders are found on several washing machine brands, including Kenmore, Frigidaire, Electrolux and White-Westinghouse, as well as Gibson, Tappan, Wascomat and some GE washers.
  • Sponsored Links
Replacement
  • Replacing a front-loading washing machine's broken basket spider is expensive. Although the spider is removable from the basket, washing machine manufacturers do not sell the spider as a standalone part, so you must purchase an entire basket. At the time of publication, the price of a basket and spider ranges from $259 to $470 depending on the manufacturer. When combined with labor costs, replacing the basket and spider can cost more than $600.
Read more: http://www.ehow.com/info_12176732_causes-basket-spider-break-frontload-washer.html#ixzz2aSx3lP95
Jul 29, 2013 | Washing Machines
H250 heater spark, but no pilot
Spider nest in the pilot assembly. You should be able to pull the pilot out, remove the pilot tube and orifice inside, and see and clean out the silk.If not, a new assembly is about $100 from a pool store. We sell them at www.arrowmotor.net
Jun 13, 2009 | Hayward 250kbtu Ng Pool Heater - Inground
I have a Kenore Elite 110.45992400 and it is thumping when it spins and the drum feels loose when you try to move it around. I've been reading, I gather this is the tub/bearing assembly? What is the spider...
The drum bearing is located at the back of the drum, and it is held by a drum spider.
This is the drum spider:
The drum spider is attached to drum on one side, and on the other it has the drum bearing.
See here a general diagram: redarrow.gif Front Load Frigidaire/GE/Kenmore Style
See also
how to mend it .com - Replacing a Drum Spider
Apr 17, 2009 | Kenmore Washing Machines
Terrible noise on spin cycle, stainless drum is loose inside plastic tub, wore the front half of the plastic tub down due to friction. Took washer completely apart, found the spider arms cracked. It...
Just had the same problem 1 month ago. My Whirlpool Duet front load made that terrible noise. 2 of the 3 spider arms were cracked. I hade a new hole tub with the spider arm and the shaft , because it is 10 years limited waranty . But if it is not under waranty it costs about 270$ for that tub you can buy it from many appliance parts web sites on the net. Good luck, huge job to all remove that thing
Dec 03, 2008 | Washing Machines
During spin cycle started making loud noise now drum feels loose DURING SPIN CYCLE DRUM SOUNDS AS IF IT'S HITTING SIDE.. FEELS LOOSE WHEN I PUSH IT AROUND FRIGIDARE GLTF1040ASO
ckd your warranty papers sounds like rear drum support(spider) has broken will require new basket and rear drum half est cost 400-600 spider is not a separate part and rear bearing is probably damaged that too is not a separate part and require rear tub replacement
May 20, 2008 | Frigidaire GLTF1670A Front Load Washer
Washing Machines Logo
336 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
