Question about Saniflo & Saniplus& Macerator Pump
Saniflo base has been dropped and has a plastic piece that is broken, can I get a replacement base and if so where from
To be exact a hammer was dropped on the plastic base of the saniflo macerator for bathroom and wc. I cant find a replacement part for it anywhere, can anyone help me find a replacement base for it and any idea how much it will cost me?
    Scholar:
  • Saniflo Expert
  • 115 Answers
I suggest to log in to their webpage at www.saniflo.com and ask for their technical department to purchase parts.
Posted on Dec 10, 2012
  • 145 Answers
SOURCE: Saniflo Sanitop pump keeps running
CHECK YOUR OWNER BOOK
Posted on Dec 12, 2008
  • 7 Answers
SOURCE: shower does not empty
Did you try to plunger the shower drain?
Posted on Feb 12, 2009
SOURCE: Saniflo Macerator Noise
If it's a one shot cleaning and not an ongong additive, bleach can be used to dissolve the tissue.
Charlie
Posted on Aug 31, 2009
Testimonial: "i havent tried it but its very helpful. Thanks."
  • 82 Answers
SOURCE: item in saniflo toilet
Yes, depending upon which model you have it *may* be fairly easy. My son decided to put a whole load of 'kando's' down ours!
*** STEP 1 ... DISCONNECT THE MAINS POWER SUPPLY!!!! ***
You'll need to drain the main toilet bowl of water and remove the toilet bowl away from the sanoflo. This may require that you also empty the cistern and stop the water from entering it (do you have an inline valve to the cistern supply pipe?)
When you have emptied the water and removed the toilet bowl there should be a large Jubilee clip attaching the saniflow to the WC waste outlet. Loosten this and remove it so you can see into the saniflo where the WC waste goes.
You should be able to see the object and reach it with your hands. I would suggest wearing some rubber gloves to protect your hands from getting gunk in cuts etc.
If you cannot get to the object, you'll need to empty out the other pipes to the Saniflo and remove the unit. When you have done this you'll need a star driver to open up the unit and get to the object inside. I woudl suggest that since most of the saniflo range have an internal grille to stop objects such as this actually hitting the macerator that you should be able to reach it just by disconnecting the WC waste connection
Hope this helps .. good luck
Posted on Jan 24, 2010
Testimonial: "Thanks very much for your help Regards Sheelagh"
  • 251 Answers
SOURCE: saniflo macerator pump to toilette cauase mcb to
hi, the usual cause is damp or water in the connector box on the unit .
hope this helps
p.s. wear gloves
Posted on Apr 24, 2010
How do I repair the plastic base on the bottom side of the projector? Plastic base cracked?
In many cases you can contact the projector manufacturer for replacement parts, The plastic (also known as the chassis) can sometimes be purchased separate. Although a crack should no effect the projectors operation unless it was dropped hard enough to cause a crack.
Nov 29, 2014 | Office Equipment & Supplies
How to change a motor coupling on top load wirlpool washing machine
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Nov 01, 2010 | Washing Machines
The agitator and tub will not turn. Does this indicate broken motor drive coupling assembly?
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (110.#######) and you'll see a list of major sub-components with diagrams and parts.
The other shaft on the motor directly drives the pump. This is likely why the machine drains.
Oct 22, 2010 | Washing Machines
Starts slowly in wash and spin, then increases has a slight noise when starting. could it be the drive motor?
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
It's possible (though unlikely) that it's the motor. I'd check the following first.
Look in the section for the motor, pump gearcase and you'll see the Motor Coupler.
If the coupler looks damaged, (plastic prongs broken or rubber center piece holes broken) it's a relatively easy fix.
Jun 28, 2010 | Kenmore 22062 Top Load Washer
What size toilet seat fits a sanicompact elite?
The manual http://www.saniflo.co.uk/pdf/install/Sanicompact.pdf shows that the lid and seat is of an elongated design and I think that you would need to get a direct replacement instead of trying to fit a standard seat/lid combo as a replacement. A normal seat/lid may line up with the fixing holes, but would probably not be the same elongated design.
You should be able to get a direct replacement from your plumbers merchant (may need to order), or from Saniflo directly http://www.saniflo.co.uk/
If this helps please leave feedback, if not let me know and I'll try and help some more!
Jan 31, 2010 | Elite Saniflo SaniCompact- SaniCompact One...
I need directions for replacing the motor coupler on a kitchenaid washer
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135&osCsid=c72212e477ba171564b9fdddc85a3649
Dec 01, 2009 | Washing Machines
Series 80 washer quit spinning;makes a whir sound instead .model#11028802890
You have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.28802890
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission. It's used as a fail safe device and consists of three parts.
Between them is a rubber piece with six holes. The power from the motor is transmitted through the rubber piece to the transmission.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning. You would also hear a sound from the two plastic pieces rubbing togetner.
With the transmission out of the washer, I'd also check the clutch for wear or broken springs.
Sears has a "rebuild kit" for the clutch if it is damaged.
Oct 19, 2009 | Kenmore Washing Machines
Washer does not reach top speed on the spin cycle
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission. It's used as a fail safe device and consists of three parts. Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes. The power from the motor is transmitted through the rubber piece to the transmission.
See the following Whirlpool direct drive installation and service manual.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console2.gif.
Oct 15, 2009 | Whirlpool LSB6200KQ Top Load Washer
Agitator doesn't turn, very loud
Assuming that this is the basic Kenmore / Whirlpool top load, direct drive, neutral drain two piece agitator model.
There is a Sears repair parts site:
Enter your model number and a list of major sub-components will come up.
Sinceit isn't agitating (I assume not at all rather than just the top partof the agitator. If just the top part isn't turning then the easiestsolution is replacing the 4 "agitator dogs" ) the solution points to acouple of places.
1. The motor coupler may be broken.
This piece is a fail safe between the motor and transmission. and basically transmits power to the transmission.
This is a relatively easy fix for the basic Kenmore / Whirlpool washers.
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
Follow the instructions for removing the cabinet and pulling the pump, motor and motor mounting plate.
Thecoupler has two plastic pieces with three prongs each. In between isthe rubber coupler with six holes. If either of the plastic pieces orthe rubber coupler are damaged,
Pry the plastic pieces fromthe motor and transmission. Some people use a claw hammer but I'vefound that using a small (6 inch) pry bar works well.
Carefullyfit the plastic pieces over the motor and transmission shafts and pressthem in place (Use a 1/2" of larger socket to put pressure equallyaround the pieces.
Carefullyline up the plastic prongs on the motor based plastic piece to thethree un-used holes in the rubber piece. If they don't line up right,the coupler could be damaged.
Sep 30, 2009 | Kenmore 15864/15862 Top Load Washer
Will not agitate. motor runs, no swish
Since it isn't agitating (I assume not at all rather than just the top part of the agitator. If just the top part isn't turning then the easiest solution is replacing the 4 "agitator dogs" ) the solution points to a couple of places.
http://www.fixya.com/support/r699497-replacing_gearcase
The coupler has two plastic pieces with three prongs each. In between is the rubber coupler with six holes. If either of the plastic pieces or the rubber coupler are damaged,
Sep 29, 2009 | Kenmore 22422 Top Load Washer
Saniflo & Saniplus& Macerator Pump  Logo
118 people viewed this question
Top Saniflo Home Experts
paulcarew
Donni Steen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
