Question about Maytag Refrigerators
MODEL #MF12569VEB2 LEAKING WATER UNDERNETH
3 Suggested Answers
  • 403 Answers
SOURCE: dishwasher is leaking water. Water is puddling
There is a tube on the side of your dishwasher for over flow. It sounds to me like your washer was moved and it banged against that line. You can put some caulking around where it enters the washer and that should be fine. The bottom can be several things. If your washer was removed and reinstalled like say maybe floor installation the supply line, or waste line may not be tight. If your unit has not been moved recently it is most likely the motor housing. Take off the one or two covers on the front bottom of the washer. Place the washer through the cycles and with a flashlight see at what cycle and where the water is coming from. It it appears to be coming from the white housing it's the motor. It's cheaper to just replace the unit as these motor housings are around $150.00. Check out craigslist. Hope this helps.
JimmyC
Posted on Sep 25, 2009
Testimonial: "This certainly gives me some options to try. Thank you. The dishwasher was recently moved due to renovations so could be some of these problems."
  • 12 Answers
SOURCE: leaking water underneth .I changed the water
ac condensation or heater core for heater core look under truck going through fire wall usually in middle or off set to drivers side it might be on top or mid ways there will be three holes one inlet one outlet and on in middle that is open crank truck if water comes out of middle its your core you have to take dash completely apart to get to it if not only thing eles has to be condensation
Posted on Sep 16, 2011
Leaking water underneth .I changed the water pump.it is still leaking .whear can it be leaking from.
Sep 16, 2011 | 1995 Chevrolet K1500
Displays E1 code. water is on
Hi there Dolly, error code E1 relates to water leaking. Its the code the machine displays when the flood switch in the bottom of the machine activates. The flood switch activates when the bottom of the machine gets filled with water from a leak. I surgest you have a look underneth the machine for signs of water. I hope this helps regards Gary.
May 04, 2011 | LG 24 in. LD-12BS6 Stainless Steel...
My 1992 f-250 is leaking fuel out of front tank but I had back tank on...whats wronf?
switch underneth truck bad leting fuel back feed to other tank
Nov 27, 2010 | 1992 Ford F250
Water leak underneth 93 ford thunder bird. Don't seem to be coming from the radiar. It's leaking some where near the crank shaft. I really can pin point it yet.
Sounds like it's leaking from the water pump. There are weep holes in the water pump and when the bearing in the water pump has worn out, coolant will start to leak from the holes.
Replace the water pump after you inspected it for any signs of leak. Good luck and thank you for using Fixya.
Nov 24, 2010 | 1993 Ford Thunderbird
Dishwasher is leaking water. Water is puddling
JimmyC
Sep 25, 2009 | GE Dishwashers
My buick is releasing steam vapor though the vest and is leaking in the car from the dash, what could it be? and also it is leaking from underneth the passenger side.
Your heater core needs to be replaced. It's located on the passenger side , under the dash. The heater core is like a small radiator. Coolant from the engine is circulated through it, and that is what provides heat in the car. The heater core is leaking, causing the 'vapor' through the vents, and leaking on the carpet on the passenger side. Heater cores are a pain to remove and replace, it's quite a labor intensive job.
Sep 11, 2009 | 1989 Buick Century
Leack proplem
is it water or coolant? if it's just rain water, open passenger door and check around door frame for any holes that the rubber seals should be in are unplugged. if so just plugg them back in. also open hood and check area right below windshield, there should be a rubber strip the lenth of the window, make sure it's press firmly down. look down further to see if any holes where rain can get in, if so plug them up. if it's coolant, it's probably a heater hose . good luck
Nov 26, 2008 | 2002 Chevrolet Monte Carlo
Where is the filter
filter should be checked regularly and is a pain to do on hotpoint. however, blocked filter would not cause leak.
remove small panel at bottom back.
you will see a large diameter hose running from tub to pump.
undo this hose at the tub end and you will find filter inside hose.
carefull, water will come out
Sep 17, 2008 | Washing Machines
Refrigerators Logo
59 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
