Question about Lands Phones
How do you turn off the 'do not disturb' that is showing on the phone screen.
A red light flashes when a call is coming in, but the phone doesn't ring. The volume is set to full.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Lands Phones Master
  • 102,366 Answers
What make and model phone?
Posted on Nov 30, 2012
  • Petera Tapsell Nov 30, 2012
    Hi. We have found a previous solution on Fixya and solved the problem by holding down the # key on the phone for awhile - it has the letters DND on it. We had visitors yesterday who must have turned on the Do Not Disturb function by mistake.
SOURCE: GE cordless dect 6.0-do not disturb
According to the instructions, you only need to press the "do not disturb" button again. The button is on the base (not the phone).
Posted on Mar 21, 2008
SOURCE: Panasonic KX-TD7896 Phone phone no longer rings only vibrates
Is there an 'M' on the display? If so, that means it is in 'meeting mode.' All you have to do is press and hold the star key (*) and that will take care of it.
Posted on Dec 22, 2008
SOURCE: GE phone has stopped ringing
I had the exact same problem and tried everything. It wasn't until I unplugged and main base from the electrical outlet for a few minutes and plugged it back in -- for some reason that made everything work. It is worth a try. We had some minor electrical outages in the last week due to weather so I assume that screwed something up.
Posted on Feb 02, 2009
SOURCE: Uniden corless phone says Do not disturb on screen
On the base unit there is DND button. Just press it. Goodluck
Posted on Jul 04, 2009
SOURCE: My uniden powermax 5.8 ghz set itself to Do Not Disturb.
The do not disturb feature (DND) allows you to mute the ringer, the base, and any registered handsets at the same time. The phone must be in standby mode. Press and hold do not disturb on the base. You will hear a confirmation tone, and the DND LED illuminates. To cancel the DND feature, press do not disturb again. You can also mute the ringer tone while the phone is ringing by pressing do not disturb on the base.
Activating the DND while the answering system is off will turn the answering system on automatically. The answering system setting will reset to the original setting when you cancel the DND.
If you press answer on/off when the DND and the answering system is on, both of the DND and the answering system will turn off.
To mute the ringer tone temporarily for each handset or the base, when the phone is ringing, press the MUTE soft key on the handset or the base. The ringer tone will return to the previous setting starting with the next incoming call.
Posted on Jul 07, 2009
When someone calls messae says' not accepting calls' how do i turn this off
Does this happen on all inbound calls or just some?
If this is on all inbound calls...Sounds like Do not disturb is turned on. Most uniden's have a DND (do not disturb) mode. Try turning this off and see if that helps.
Using Do Not Disturb
  • The Do Not Disturb or DND feature turns off the audio ringers of the base and all handsets at the same time. It does not affect any of the visual ringers.
  • With the phone in standby, press and hold Do not Disturb on the base. The phone automatically turns on the answering system and shows Do Not Disturb in the display on all handsets.
  • To cancel, press Do not Disturb.
If this is not the issue, it may be turned on at the central office (your phone company) try using the DND activation/deactivation code of *64 from your phone.
If this is just on some inbound calls...Then it you may have anonymous call rejection turned on. That feature blocks calls from people that block their calling number when placing calls.
Mar 01, 2012 | Uniden DECT 6.0 Cordless Phone ID
JVC TV has flashing red light in front. TV won't turn on when red light starts flashing. After unplugging tv for a while, TV sometimes turns on but screen is shaking violently. Any flashing lights...
sometimes a leaky filter capacitor in the power supply primary section could caused this problem,or a loose solder connection in the power supply section
Jul 18, 2011 | JVC AV-32230 32" TV
Why can't I turn off the FWD/DND flashing light?
It will flash for 2 reasons. The phone is in Do Not Disturb, The phone is forwarded and the lazy installer didn't change the button indication to solid.
What happens when you press the FWD/DND button on an idle phone? In most systems, it's supposed to toggle between FWD DND and OFF after you press it more than once. If that doesn't work, try pressing FWD STORE 0 STORE. That should turn off FWD/DND and unset it.
However, here's the problem. Your phone may have CF-condition set to send busy and unanswered calls to voice mail. We do that so the individual extension can set his own transfer to VM time. Those commands start with *710x and the VM extension which is 500 by default. For example dialing *7104 500 on the intercom will set CF-NA to the voicemail port on a TDA/TDE system equipped with a Panasonic Voice mail system. When that happens, the FWD/DND light goes either red or blinks red and the forward condition is set.
You can review the operations in the OM for your system under Call Forward and Do Not Disturb.
Carl
Mar 04, 2011 | Panasonic KXDT343 Phone
FWD/DND SHOWING RED AND INCOMING CALLS RESTRICTED
If you have not found an answer to this as yet just pick up intercom and enter 7100 at the phone. This will clear any DND. Now enter intercom 7105165. This will give a long tone and the DND/FWD lamp will flash showing Call forwarding active for VM.
Jan 18, 2011 | Panasonic KX-T7630 Corded Phone
Want to turn the DND off
Typically DND is turned on and off by pressing the FWD/DND button. There are three status conditions for this button indicated by the button light.
button light off: both features off(Forwarding and Do Not Disturb)
button light blinking red: Forwarding on
button light solid red: Do Not Disturb on
The functionality of this button can be customized by the phone system installer to work differently than outlined above. Station features can also be accessed through station programming using the LCD screen by pressing the button then either scrolling through the features using the LCD screen navigation keys or entering the specific program number as in 50 for FWD/DND programming.
Dec 08, 2010 | Panasonic KX-T7731 Corded Phone
How can I deactivate DND samsung OfficeServ DS-5007S
To turn DND (do not disturb) on and off on any Samsung phone systems (inc. Prostar, DCS, OfficeServ) watch this video clip. Or visit http://www.AbbeyTelecom.com for more vids.
May 08, 2010 | Lands Phones
Red light that shows a message waiting won't go off after all messages have been heard and deleted.
turn it off and take out the battery?
But it could be a software problem?
May 31, 2009 | Uniden Cordless Phone
How do you turn off the "Do Not Disturb" on the Model 21028GE3-A
its a glowing red button on the base. bottom right corner. push the glowing red button till its off, and no light. should work right.
Jul 18, 2008 | GE 21018GE3 Cordless Phone
When someone calls the buttons flash but doesn't ring.
Your ringer has been switched off..to solve this press the menu button(mute in most of the sets)and press it until you see the option ringer press + to change it to off and then press menu again until you see the main screen...Thats all..
Let me know if it worked..
Oct 20, 2007 | GE 28111 Cordless Phone
My phone will not show it charging and will not turn on, red light flashing
Mine started acting wierd and it was flashing on and off. someone told me to press:*and # together with the power button.
Oct 19, 2007 | Cell Phones
Lands Phones Logo
87 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
