Question about Kenmore Dryers
Fire sensor replaced and now the dryer will not turn on
My husband changed the fire sensor and now the dryer will not turn on. Does anyone have any ideas?
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
What is the model number of your unit?
Do you mean he replaced the "flame sensor"?
Have him check to see that the wires to the door switch are attached. This will prevent the dryer from starting.
Posted on Dec 01, 2012
  • 2 more comments
  • joanne Franco Dec 01, 2012
    Yes it is the flame sensor! lol Its a series 90 and the wires to the door are attached.
  • Richard Roth
    Richard Roth Dec 01, 2012
    Does it not heat or does it not work at all?
  • joanne Franco Dec 03, 2012
    It does not work at all. There is electricity to the timer because you can hear it but the drum doesn't turn.
  • Richard Roth
    Richard Roth Dec 03, 2012
    OK, what is the model number? I don't see where you posted it. Look inside the door area.
Dryer will not turn on the heat/
There are usually two temp sensors mounted near the heater or in ducts. Thy look a lot like a silver button about the size of a quarter and about half of an inch thick with a tab on either side to screw the sensor down. At room temperature both should measure almost zero ohms when checked with an ohmmeter. One opens and closes to turn on the heater. The other opens if the dryer gets too hot to prevent a fire. This second sensor will not reset if it trips, so it must be replaced. These sensors sometimes fail with age. The kit of the required parts cost around $25.00 when I last replaced mine.
Sep 12, 2014 | Dryers
Any help with reconnecting wires to heating element?
I would only be guessing but it was probably done wrong
Jul 14, 2014 | Roper Dryers
MEDX500XWO Dryer
most are 220 volt elements..then sometimes a ground wire goes to the frame of the element mount flange(usually a green wire) the ones that connect to the element have a flat (spade) connector on them with a fireproof (woven white covering) on them or its a red wire..(2 of them, one for each connector) then the whole thing gets mounted in..
Mar 04, 2014 | Maytag MEDX500XW - 27", 7.4 Cu Ft, He...
Dryer will not turn on. it stays on the sensor light. husband thinks it might be a sensor bulb or something i don't know.
If the sensor light is illuminated, the motor relay on the control is likely bad or the solder connection to it is burnt. Remove the control and inspect the rear of the control board for signs of damage. The new board is available at www.aplusapplianceparts.com.
Jan 02, 2011 | Whirlpool GEW9868K Electric Dryer
97 Toyota Camry Has been having issues lately. First it started to miss fire a lot kept getting the code p1300 so i was advised to get a tune up i did that. Tune up included spark plugs changed, wires...
Has anyone checked the Crank position sensor or knock sensor? If the Crank position sensor isn't reporting the correct position of the crank when it turns the spark plugs are firing at the wrong time. This could be because of a worn timing belt or faulty timing belt tension arm. Have the sensors checked and if they are good your left with replacing your timing belt.
Oct 16, 2010 | 1997 Toyota Camry
Have Whirlpool Model # LGB6200PQO dryer runs but does nut dry. Burner kicks on with fire on gas dryer but after about 5 min kicks off after a few minutes the igniter glows on but no fire then kicks off...
The moister sensor can be bad or good. If the exhaust tubes are clogged with any lint build upo the sensor is working putting the burner into check
Jul 28, 2010 | Whirlpool Dryers
Lights come on the dryer but it wont start...any ideas
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jul 06, 2010 | Samsung DV448AGE Gas Dryer
HI, had my suburban a couple of years and has
make sure all your grounds are in place and tight. especially in the area you were working
Nov 07, 2009 | 1999 Chevrolet Suburban
Gas neptune dryer fires up for 45 sec. to 1 min, then goes out
Could be a couple different things,Possibly a thermostat or high limit that is kicking out too soon,also has a flame sensor next to the burner that can come and go.if you have a toggle switch or pushbutton switch you can unplug the unit take the two wires off the flame sensor (black box about the size of a cigarette pack on the left of the burner)plug them into the switch start the dryer Turn the switch on till the igniter glows bright,turn the switch off and the burner will light if it stays lit at least till it gets to temp replace the flame sensor.(It won't cycle with out flipping the switch each time)
Sep 03, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
