Question about Miele Optima G2470SCVi Built-in Dishwasher
Miele f42 error - Miele Optima G2470SCVi Built-in Dishwasher
WAT DUSE F42 MEAN ON A BOSCH WASHING MACHING
It could mean there's a fault with the motor
Source: Bosch Error Codes Page
Dec 14, 2016 | Bosch Washing Machines
What mean technics error in whaching machine miele
There should be an error code that follows - What is the model number?
Aug 16, 2014 | Miele Washing Machines
E010
IR330, step 1- this Error is the main motor fails to rotate normally, does the main motor rotate until E010 turn on? if yes go step 5, if no step 2- harness wiring connectors around the main motor normal? if no correct the wiring, if yes step 3- does the voltage of J102-B12 on the controller pcb change to 0 VDC while the main motor is rotating?, if no replace main motor ( main motor driver pcb), if yes step 4-is there 24 VDC generated between J204-3 and J204-4 on the composite power supply PCB, if no replace the composite power supply PCB, if yes step 5 is the voltage of J102-B11 on the DC controller PCB about 5 VDC during WMUP? if no replace DC controller PCB. if yes step 6- Is there continuity of the harness between the image processor PCB and DC controller PCB normal J714-A14 to J113-A7 also 714-A16 to J113-A5 if yes to if no replace the harness if yes replace the DC controller PCB and the Image processor PCB.
Nov 30, 2013 | Printer Essentials Canon Gpr-2...
F42 is showing on my Bosch Logixx 8 sensitive washing machine what does this mean and how do I fix it . thanks
An error code of "F42" means your oven has a defective or jammed lower latch, latch motor or latch switch, which is preventing the lower oven's latch from locking properly. If all of the electrical connections are in place on your oven's power board, you may have a faulty power board.
Apr 01, 2011 | Bosch Washing Machines
Miele front loader washing machine W3275- error code F53- what does this mean?
hi,
this is a tachogenerator fault or the drive motor brushes are faulty. you will need a Miele service tech or a Miele service agent to look at this.
May 21, 2010 | Miele W865 Front Load Washer
Miele Optima G2470SCVi Built-in Dishwasher Logo
85 people viewed this question
Top Miele Dishwashers Experts
Mike
shaun taylor
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
