Question about Kitchen Ranges
Temperture control will not increase - Kitchen Ranges
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
What is the complete model number of your unit?
Posted on Nov 30, 2012
I have a KitchenAid Refrigerator Model Number: KBFC42FTS. Bottom drawer freezer over cools -10 degrees.
That's interesting, -10 or colder is too cold and something is defiantly going on. This unit is controlled by a mulitple control boards, temperture sensors and other components. Question, what is freezer temp set at? Try increasing it by 3-4 degrees and see if that changes anything. Beyond that, I'm going to change the temp sensor first before doing any of the control boards. #29 is the temp. sensor. Good Luck
Sep 19, 2017 | KitchenAid Refrigerators
Why do my temperture gauge rise when im idle and drop when im moving 2002 Infiniti qx4
Hi Delevain:
This is a fairly normal circumstance.
When you are moving, there is an increased flow of air through the radiator. That cools the fluid, and thus the lower temp indication.
When you are stopped, there is very little air flow through the radiator (just from the fan) which results in the engine being able to heat the fluid faster than it can cool in the radiator. And the temperature increases.
As long as the temp does not increase to the point where daage could occur, all should be good.
Cheers.
Feb 19, 2016 | Infiniti Cars & Trucks
I need to know the right temperture settings cause i dont have a manual
dont try to lower cool setting below 70 degrees or heat setting above 78 degrees. all a/c's are designed for a 95 degree ambient when it gets above that you have to increase tonnage to compensate.
Jul 30, 2015 | Heating & Cooling
Where is the temperture control system
some model has not display temperature control system.
You must see your instruction manual for indicate how to control the temperature. if you do not have download www,fitness.manualsonline. com or www.retrevo.com or www.manualsfactory.com
God bless you
May 09, 2012 | 2005 Chrysler 300 Hemi
When , i turn on my heater on inside the car it blow out cold air. When I increased the temperture it still blow out cold air
First check that the blender door motor is operating.This should be a little box directly in front center of the console. When you adjust the temp control, the arm should move on the box motor.
Probably though your heater core is plugged.Do a search for don-ohio and heater core and maybe the long tryped message will come up, if you CAN do a search on this site.I'm pretty new here, and don't know the `ropes'. ha! don-ohio
Oct 19, 2011 | 2000 Mercury Sable
Whirlpool oven/ temp decreases when increase control is pressed
you need to replace the ( e o c ) the clock ) it's lost the ability to comprehend your needs .. the 350 start up is normal / but the up arrow should increase temp .. time should not be changing .. replace the clock / this part # 4452240 is n l a ) your clock can be sent in to be repaired / only . hope this info will help .. & 238.00 last price on this clock .
Dec 02, 2009 | Dishwashers
At what temperture should the electric fan start and how is it controlled
computer controlled , should come on around 225 degrees. You will need a scanner to see what the PCM is seeing.
Nov 02, 2009 | 1998 Jeep Grand Cherokee
Cpu temperature = 58-> 70 degrees celcius is taht normal ?
are u using amd turion ... in the case of laptops the temeprature of near 65 can be said as normal antivirus and hidden virus activities can also increse cpu usage and cause over heating . i am using amd turion i usally get temperture upto 65 dg . note at which processes the cpu temperture increases
Jan 23, 2008 | HP Pavilion zd8000 Notebook
Same problem no solution not sure but need help bad fridge is getting warm
Not cooling at all? or other symtoms that can help us get you going. Can you make sure the refrigerator is listed as Kenmore
Here are some examples of model numbers for this appliance: 106.8782070, 596.58692890, 119.909851, 119.3101279, 198.887482, 253.835123
•  Inside the refrigerator or freezer, on the upper left or right side wall
    •  Behind the lower crisper drawer
    •  Behind the lower toe kick-plate
    •  On the face frame of the refrigerator body
Can you help locate these numbers so I can assist you with the drawing of that door?  TKS,Sea Breeze
Oct 24, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
