Question about Whirlpool Dryers
I have a Whirlpool dryer AZC 6470 and both the empty filter and empty container lights are flashing and they both are emptied ,as a result the dryer wont work ,what is the problem ?
I have already emptied the water container and cleaned the filter and pulled out the dryer ,reset it with the fusebox I even unplugged and plugged it in again and it is still not working
apart4u
  • 213 Answers
SOURCE: Problem with Indesit tumble dryer
could be a switch in there or one of these This sounds like the thermostats
ForAll Your Appliance Video Help Visit Apart4u video tutorials
see other tumbledryervideos here
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
You-Tube video "6x3oXHgPLDg" placeholder (do not delete)
Posted on Jan 10, 2010
Master_Tech
  • 770 Answers
SOURCE: water empty light wont go out
Please check the switch where you reomve the tank it needs to be open and tell the dryer it is empty
Posted on Jan 27, 2008
SOURCE: indesit condenser tumble dryer water
Maybe trapped water in the dryer. Switch off and remove power from wall. Remove condenser unit from the dryer (clean the condenser while you have the chance with plenty of water and an old toothbrush - it will probably be filthy). With the condenser unit removed stick an old tea towel in the hole where the condenser was and then tip the dryer on its side. If there is water it will either run onto the tea towel or onto your kitchen floor OR into the water container!
It worked for me, honest...
Posted on Mar 13, 2009
SOURCE: I have a Hoover vision hd b energy condensor dryer
My engineer is coming out, didnt realise i had to pay for this assistance,it made out on the ad that someone was able to help you by giving advice,it didnt state you had to pay, for i thought forget it.
Posted on Aug 27, 2009
SOURCE: HOTPOINT AQUARIUS CONDENSER TUMBLE DRYER CTD40
There are three water reservoirs - one at the bottom behind the condenser, a second at the back bottom of the machine and then a third at the top which is the one you would normally pull out to empty.
There is a hole at the bottom of the filter in the first reservoir (at the back of the condenser) which leads to the second reservoir at the back. If the hole gets clogged up with lint/muck then the reservoir at the back does not fill up.
So to solve this, unplug the machine, take out the condenser (front left bottom of the machine) reach through to the back and mop up the spare water with a towel and check that the hole to the back reservoir - you can feel this it is towards the right side at the back of the machine is clear from muck.
Once you have cleared it, water will flow to the second reservoir and then (once you switch on the machine) up to the main removeable reservoir at the top.
Hopefully this helps. GB
Posted on Sep 10, 2009
Why is warning lights on on my AZC6470 Whirlpool condenser dryer when i have cleaned heat exchanger/filter and emptied water container
Not trying to be a smartass but what does the manual say about the warning lights as in what do they refer to.
Oct 09, 2014 | Whirlpool Dryers
LIGHT FLASHING EMPTY WATER,CUTTING OFF WHEN WATER EMPTIED
Try cleaning the water sensor, it may need to be replaced though.
Dec 22, 2013 | Dryers
My whirlpool awz7303 is not get hot so there for my clothes are not drying. i have checked the filter, water container and the heat exchange they are all clean and empty but the filter indicator light is...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 19, 2010 | Whirlpool AWZ7303 Electric Dryer
Problem with whirlpool condenser dryer,light on to say empty water bottle but after doing all that and cleaning it out it still wont reset. HELP PLEASE!
Empty the bottle and then unplugg the dryer. Plugg the dryer back in and see if the empty light goes off.
Apr 04, 2010 | Dryers
Empty Water light is on but water container is empty
The float switch could be sticking,or there is a blockage to the water container.
It means a strip down of dryer if you are certain that all filters and vents are are clean.
Hope this helps.
Dec 19, 2009 | Hotpoint Dryers
I have a Hoover vision hd b energy condensor dryer mega 9kg. The start light and empty water light flash at the same time and dryer stops. I have emptied the water container and the filter and still the...
Aug 26, 2009 | Hoover Dryers
Maintenance lights won't go away
elaine hopefully this will help. advance your selector dial to the 6 o'clock position, press start 3x. advance your selector dial to 7 o'clock position, press start 3x. turn the unit off then on. try using it as normal.
Apr 24, 2017 | Whirlpool Dryers
Water empty light wont go out
the black wire that was moving water from down condenser to up - water container - remove it. Use cotton swabs to "clean" the holes, do a run of the dryer without that black wire connected ( carefull, cause some wated might spill at this point), reattach black wire, and enjoy :)
It worked for me anyway. ( fingers crossed, its been on for 20 mins and still no red lights flashing)
Dec 30, 2007 | Hotpoint TDC32 Electric Dryer
Dryers Logo
304 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
