Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
Tv shuts green light starts blinking
Tv shuts off green light starts blinking 5-25 times and tv comes back on and then back on for 1 or 2 min. and then back off
  • dadball60 Jan 11, 2009
    what is going on with my tv
I have te same prolem. when online and read all solution. Decide to un-plug TV, remove light buld and vacuum clean the buld and the location where the buld goes in. Pray and re-installed light buld. Turn on TV and problem when away. Picture and sound stay on. TV no longer come on and off every couple of second. Thank God for the internet and every suggest I read.
Posted on Feb 01, 2009
    Champion:
  • 240 Answers
Change the lamp
Posted on Jan 11, 2009
Screen went black. Shut t.v. off and tried to turn it back on. Power comes on, front light is green, and in about 3 seconds the t.v. shuts off, green light goes off. Was playing dvd at the time. Shut off...
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix. SD TECH
Jul 15, 2011 | Mitsubishi WS-55819 55" Rear Projection...
I replaced the lamp however the green light blinks for a minute then the lamp light comes back on and the tv can't be turned on. WD-Y57 model
with that model after the tv shuts off pres the "menu" and "device" button on the front panel buttons together for about 8 seconds and then the power led will blink green. it will blink a certain number of times then pause and blink a different number of times this will be the error code for the fail that the tv thinks it is having. for example it may blink green 6 times then pause and blink 1 more time that would be code 61 check the code and repost and i will tell you the next course of action good luck
Jan 05, 2011 | Mitsubishi WD-Y57 57" Projection HDTV
BE WATHING IT AND SHUT DOWN AN LEAVE ON IN A COUPLE MIN. KICKS BACK ON,SHUT IT OFF AND TRY TURNING IT BACK ON AND THE GREEN LIGHT DONT COME ON BUT RED LIGHT WILL BLINK FIVE TIMES AND DO IT CONSECTIVELY
Replace Lamp #XL2100u Mats has them $99.00 and up 1-800-628-1118.I checked Encompass Parts Distrubtion has them for $200.00 they also List other Parts/Prices for your TV.Let me know if you should need any more Help.
Mar 25, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony kf 50e200a screen goes black and sound turns off for min...
TV has gone into "protect mode" to do just that to protect against the damaging failure that has been detected, you will need a servicer to diagnose the failure. Good luck and Merry Christmas!
Dec 25, 2009 | Televison & Video
Screen Goes Green TV goes to stand by blinking 8 times
try adjusting your color tuners located inside tv behind speakers.
Nov 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Tv cuts off and green light flashes
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Green Blinking Timer Light Mitsubishi WD-62527
hold the menu bottun for 10 seconds
after press power
see if that works
Sep 22, 2007 | Mitsubishi WD62527 62 in. LCD HDTV
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
299 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
