Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron Tv shut off then made two beeping sounds and doesnt turn on anymore
The tv was on and then out of nowhere it shut off then made the two beeping noises and wont turn on anymore, when I try to turn it on, it makes the noise but the tv doesn't flicker nor make a sound
    Master:
  • 879 Answers
Two beeps can be considered as two blinks. Blinks of standby light in Sony TVs are fault indications. Visit the site linked below to know more about the blinking codes and fault locations to Sony TVs. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there.
Posted on Dec 01, 2012
SOURCE: tv wont turn on only clicks and then flashes red timer light
I heated up board with hair dryer through back of TV without taking back cover off. The heat was on high for approx. 5min. and was placed on right side of TV about 1/3 up from bottom.
Posted on Feb 11, 2008
tv wont turn on when i hit power it makes the clicking noise like it is going to turn on, but never does and the red timer light next to the power button just flashes.
help!
trinitron kv29f1u
only clicks and blinks
Posted on Aug 10, 2008
  • 4 Answers
SOURCE: sony trinitron wega 36 inch
If you are not a professional Electronics guy,it is beyond you to tackle this problem. otherwise log on to www.free service manuals.com and see the SONY Blink codes and also download the service manual.best of luck
Posted on Aug 31, 2008
daniel719
  • 240 Answers
SOURCE: Shuts off by itself, then makes weird noise in back of TV
have a tech check your flyback conection in side the set some times thay come loos during shipment.
regards
daniel.
Posted on Jan 13, 2009
techman007
  • 1112 Answers
SOURCE: Sony Trinitron Wega TV keeps shutting off and red
There are two Ic's that need replacing on the Deflection Board (D) board.. These regulate power for the High Voltage and Chopper PWM circuits. The IC location on the board are IC6501 and IC8002
Posted on Nov 19, 2009
Why is my Samsung RF26XAERS refrigerator repetitively chiming, and how can I fix it?
NOISE? from the fridge inside? or from the outside compressor? In overstressed compressor or low freon level will make weird noises? a bad fan in freezer will? Even seen bad ice makers make weird noises? if the ice making is hindered by obstructions?
Aug 20, 2014 | Samsung RF26XAERS 26 Cu. ft. French Door...
Sony kd-36xs955 Turn tv on all channels fuzzy,once warmed up,everything is good.Now when you try to use the hdmi port for PS3 nothing there.The tv has had problems before like it would shut off and blink...
Count how many times the standby light blinks at one time. These blinking are fault indication. You can get an idea about the faulty circuit part inside, from these number of blinks. After make it sure, if you wish to get more details about Blinking Codes to Sony TV sets, check this link.
Feb 16, 2013 | Sony FD Trinitron KD-36XS955 36" TV
The tv usually turns on but now it won't. When it does turn on it makes a noise like a motor boat sound. The noise stays on until you shut the tv off. I'm not sure what it is I think it's the fan but
I would say that if there is a fan inside of it and it sounds like a fan bearing going bad then that is what it is. The reason for it not to be turning on anymore could be because whatever that fan is cooling has failed. Not sure.
Jan 30, 2013 | Televison & Video
GETTING MESSAGE TV WILL SHUT OFF SOON ON Sony trinitron, then tv turns off'
More than likely someone has inadvertently set the sleep timer to ON. That will cause the set to shut off, it kindly gives you a warning that it will shut off so your TV is more than likely just fine. Usually it can be turned off using the on screen menu and the remote control.
May 30, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
It wont turn on anymore. it fires then instantly shuts off, doesnt even flash screen. standby lights still flash and its trying to turn on, just cant get on. you can hear the on sound and then the tv...
Depending on the age of your tv, if you hear a rapid clicking, it seems like your ballast is starting to turn on your tv but it's not able to. (1) Check your lamp, (2) reset the lamp timer, (3) make sure the cover panel is all the way. the positioning sensor might not be detecting the cover all the way in.
Personally I think you're experiencing a ballast problem.
Apr 20, 2010 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
PS3 wont display video or audio
This is a rare problem ............ i faced similar kind of problem
i solved my problem with the help this repair guide you can also try this out i hope this will help you a lot .......
all the best
Click Here
Feb 11, 2010 | Sony Playstation 3 (PS3) Console
My 26' sanyo vizon wont turn on and i dont know why.
I have the same tv. Was watching last night when it turned itself off. When I tried turning it back on the switch just made a click noise and nothing happened. After a couple more tries, it didn't even do that.
Jan 26, 2010 | Sanyo DP26746 26 in. LCD Television
I was watching tv and out of nowhere the tv turned off and now will not turn back on for more than a couple seconds. When it does turn on it makes a click noise then turns off, with no sound or picture.
Dec 14, 2009 | Pioneer SD-P50A5-K 50" Rear Projection...
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
104 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
