Question about Canon PIXMA iP1300 Printer
Canon PIXMA iP1300 Printer ink absorber is full , how can do empty it?
SOURCE: Waste Ink Absorber is full In Canon Pixma IP3300
my printer say, "the ink absorber is full".
Posted on Dec 06, 2008
SOURCE: waste ink absorber full
It's Very Simple
Just Enter in Service Mode of your printer and clean absorbers count.
To enter in SERVICE MODE
1) Power off Printer
2) Push and hold "Resume" button and then push and hold "Power" button
3) Hold the Power button, then release and 2 times press Resume button
4) Led indicators must change
5) Release all buttons
6) Then printer in Service Mode
(If something wrong, repeat 1-6)
To clean absorber counter,
7) Press "Resume" Button 4 Times and after press Power button. It's all! Your absorber count is EMPTY!
In SERVISE MODE you can do several useful things:
To print Service Nozzles test, press "Resume" 1 time and press Power
To print EEPROM data, press Resume 2 times and press Power.
DO NOT press Resume 3 times and POWER. It will reset some EEPROM data settings
Any Question mail me: ossipenko(prettydoggy)gmail.com
Posted on Feb 05, 2009
  • 272 Answers
SOURCE: ink absorber full warning
Yes, first unplug the power chord and then the usb chord. When you are done doing that, take the printer to an area where you have a little working space. Put it down on some newspaper. Open the lid. (Normally, when you open the lid with printer on, the cartridges will slide over to the left of the machine, this is important to remember for part of the cleaning). Now, with printer lid up in the air, look down inside the printer. you will see some plastic running horizontal with the printer ribbon, (the area I am referring to is right under where the ink cartriges slide back and forth)on the floor of the printer. If you take your finger and feel inside, you will find a very thin, narrow piece of foam in between the plastic strips. You can gently remove this foam and clean it with denatured alcohol and let it completely dry before replacing. You can also go in and clean the plastic area with a Qtip, because there will be a residue of ink all over this area. Also, right under where the ink cartridges park when opening the lid when plugged in is another small piece of rubber pad that should be cleaned too. Once you have done this, and this is important.. before, and during the replugging of the usb plug and the power chord, YOU MUST keep the "on key" pressed in. This is going to help reset your printer once it's plugged in. So keep your on button pressed down and plug both chords in. ONCE that's done, let go of the power button. It will go on and run through some of it's noise. The yellow light might come on again, that's okay, just turn off your printer, wait a few seconds and turn it back on. It should work fine. We did this because we had read about holding in the button for resetting. If you clean the ink pads in the future you must do that because it actually is resetting something in your printer. Mine works just fine. I will add that I went through a lot of ink cartridges to get to this point but it is pretty easy to clean if you just take your time, be patient and carefully remove the foam not to damage it. Good luck
Posted on Jun 01, 2009
  • 5603 Answers
SOURCE: Ink absorber
A special service software program is needed to reset the internal counter for the ink absorber.
Check here:
http://www.pdfoo.com/result-service-tool-software-resetter-for-canon-pixma-ix-5000.html
Posted on Sep 01, 2009
pineworks
  • 4041 Answers
SOURCE: waste ink absorber is almost full,so printer has
Hi there
Here this step by step to resetting waste ink counter printer Canon Pixma MP130
1. You will include printer.
2. Press button MENU, then SCAN, COPY and again SCAN - they entered
3. Into the service regime
4. Select NVRAM ACCESS and further BY OK.
5. Select SET Abs- m level and advance value equal to zero.
6. Select SET Abs- r level (if there is) and also you will establish into zero
7. You will turn off printer by button POWER
Some time of other you will need to clean out the inkpads that are in the printer or it will in time leak the ink out.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 17, 2010
Plz solve me problem\r\nmy canon ip1300 printer absorber is problem
This mayclear the ink absorber problem.There is ink absorbers located at both ends ofthe printer where the ink head move.
To dry the ink absorber, power up the printer and open the cover so the inkcartridges and print head will move to the middle of the printer.
Then take several sheets of absorbent tissue, fold it into a pad and place itinside the printer over the ink absorber on the far left hand side of theprinter to soak up the excess ink. You may need to change the absorbent tissuea few times. Then repeat the same procedure on the right hand ink absorber.
Close the lid and the printer should now function normally.
Aug 07, 2011 | Canon PIXMA iP1300 Printer
Full ink absorber
There are ink absorbers located at both ends of the printerwhere the ink head move.
Then take several sheets of absorbent tissue, fold it into a pad and place it insidethe printer over the ink absorber on the far left hand side of the printer tosoak up the excess ink. You may need to change the absorbent tissue a fewtimes. Then repeat the same procedure on the right hand ink absorber.
Closethe lid and the printer should now function normally.
Jun 15, 2011 | Canon PIXMA iP1300 Printer
Cannon pixma ip 1300 cannot function to windows 7 homebasic
There may be a Windows 7 printer driver on the Canon WEB site.
You can download the Canon printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload : -http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
Jun 13, 2011 | Canon PIXMA iP1300 Printer
Waste ink absorber is. full. How do I empty it?
The waste ink absorber can sometimes be removed and cleaned out and put back into place. Although it is not always easy to get at. Usually once this happens it is time for a new printer. You can also contact Canon and see if they have a replacement part for this.
May 28, 2010 | Canon PIXMA iP2000 InkJet Printer
My Canon ip1800 ink absorber is full is there a quick fix
No .You must replace waste ink tank.
to get printout
Jul 01, 2009 | Canon PIXMA iP1300 Printer
The canon pixma ip1300 was full of the ink absorber,what is the solution of it,and what i do for the ink absorber?
You need to reset your printer and replace the absorber.The absorber is on the bottom of the printer and you need to disassembly the hole printer to replace it.For reset the printer look this: http://tricks-collections.com/iptool-canon-printer/
Jun 12, 2009 | Canon PIXMA MP760 All-In-One InkJet...
Ink waste absorber
Waste absorber is full. Where is the waste ink absorber and how do I empty it?
Apr 08, 2009 | Canon PIXMA iP1600 Printer
MY PIXMA iP1300 keeps error
since canon printers need service tool to reset the waste ink counter, i suggest that you bring your printer to an authorized service center in your area to have them reset the waste absorber counter and clean it as well.
Feb 15, 2009 | Canon MP610 Photo All-In-One Printer
Canon Pixma ip1300 Ink absorber is full what can i do
another solution for a quick override is to unplug the power lead from the back of the printer. With one hand hold down the power button on the printer whilst simultaneously plugging back in the power lead. When the light is back on, take your finger off the power button. You may need to press the power button once more, but this should 'override' the problem until the next time you turn your printer off.
Mar 26, 2008 | Office Equipment & Supplies
Canon PIXMA iP1300 Printer Logo
564 people viewed this question
old marine
old marine
