Harman kardon fl 8400 won't rotate or play cd
  • stenelli
    stenelli Nov 30, 2012
    tray will open. wont disc skip while opened or closed. i already have the cover off.
  • stenelli
    okay fixed that rotating problem...now it wont lift the laser up to the cd any ideas?
  • 112 Answers
SOURCE: HARMAN KARDON CDR-26 CD RECORDER/PLAYER
You need to clean the laser lense, if that doesn't work you need a new laser pickup. Check first, but from memory you need a sanyo sfp151 17 pin laser. Costs around $25.
Posted on Mar 10, 2008
SOURCE: Does anyoe know how to record from LP to cd?
Use your tape out, or another line out signal from your preamp.... if possible - OR Sometimes you can pull out some connectors on the back of your amp (a Metal joint kindathing ;), to break signalpath between preamp and poweramp if its an integrated amp -
Use preamp out signal to feed your cdr ( Main purpose is to equalize out, the RIAA correction on a record)
Have you tried to google your question ? Lots of fine guides out there!!!
Posted on Jan 14, 2009
  • 382 Answers
SOURCE: My Harman Kardon FL 8550 will not play, the
Couple possibilities.
Disc jammed inside, take cover off and inspect.
Worn belts, belts are old and worn and it can't move the carousel or open, stripped gears will also have the same effect.
Or electronic problem, not worth repairing.
Posted on Jan 01, 2010
SOURCE: Describe your Harman Kardon CDR30 2-Disc CD
With mine, it was the drive belts for the cd drawers, which were stretched and rigid. Open the case. Remove the 4 screws that hold down each cd drive. Push the drives out enough so you can pull the silver facing off the sliding try by pulling it up. Now you can lift out the cd drives, removing all the connectors as you go. Flip the white plastic slider underneath each drive and you can mechanically open the slide tray. This reveals the little motor and rubber pulley belt that operates the slide tray. If the belts are broken, perished, rigid or something, get something similar from your local electronics parts store (a couple of bucks each belt), and reassemble.
Posted on May 25, 2010
  • 347 Answers
SOURCE: I have a Harman Kardon CDR2 and the cd drawers
hi jlcady
sounds like the belts need to be replaced. for that the units eject mechanic assy has to be disassembled.
feel free to text for further assistance.
regards
Posted on Feb 13, 2011
No disc error dvd on Harman BDS
maybe try cleaning the laser ? with a cotton wool bud and metho
Jul 28, 2013 | Harman Kardon Audio Players & Recorders
AirPlay won't connect to harman kardon receiver
My iPhone has a button at the bottom right-hand side of the screen (next to the volume control), that gives me the option to listen on the phone or to have it run on the Harman Kardon airplay. It automatically turned on the receiver and played the sound of the video in surround sound. It looks like a rectangle with a triangle at the bottom of it.
Mar 11, 2013 | iPhone Apps
FL 8350 CD Player. Disc drawer will not open. Getting error message
Most likely a belt has stretched and will not now move the tray. This happens of units more than 2 years old usually.
Dec 26, 2012 | Harman Kardon FL8350 5-Disc CD Changer
Can't' play blue ray disk
It is a CD Player, It will not play DVD,s
Oct 21, 2012 | Harman Kardon CDR30 2-Disc CD Recorder
Harmon Kardon CDR 2 no power
Check its fuse at the power supply section. If found opened,never insert an other one, till the fault has been rectified. Without any fault, the fuse won't go out. Try this to understand.
Apr 17, 2012 | Harman Kardon Audio Players & Recorders
Harman kardon go and play don't have video out port
If I understand you correctly the Harman Kardon does not supply the output video and usb ports. Since this is a go and play they pobably felt it was not needed. to impliment these changes would require a complete design change.
Mar 28, 2012 | Harman Kardon Go + Play Portable Speaker...
I have a Harman Kardon crd20 and when trying to record i'm getting "no audio" what is the problem? And is it possible to get a manual?
"CRD20"
A simple web search, which you could do yourself, for "Harman Kardon CDR 20 manual" finds several.
http://www.retrevo.com/support/Harman-Kardon-CDR-20-CD-Players-manual/id/386dj191/t/2/
Look for "no audio" in the manual. It occurs twice.
Aug 27, 2011 | Harman Kardon CDR20 CD Player
My Harman Kardon FL 8550 will not play, the display shows error and the carousel seems stuck. I already cleaned the lens.
Nov 27, 2009 | Harman Kardon FL8550 CD Player
Jan 14, 2009 | Harman Kardon CDR2 2-Disc CD Recorder
109 people viewed this question
 Grubhead
Grubhead
