Question about Iomega 2TB Prestige External Hard Drive
External Hard Drive I now get the message "Windows Delayed write failed. Windows unable to save all the data for the file H:\$mft
I think the hard drive is bad. Any way of retrieving the data on the hard drive? I moved all my pictures from my laptap to the external hard drive. I deleted the file on my laptap in September. Help
  • Iomega Master
  • 27,725 Answers
Click start control panel Administrative tools Computer Management Disk Management
right click on your drive select properties click tools you should see click check now click start two boxes
Automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start then after its finished return and tick the other box you should not do anything while the chkdsk utility is in progress any input may damage this drive.
You might get best results ticking in one box the returning after it has finished then ticking the other box
it might take some time depending on the size of your disk but be patient.
Try some of these
Downloads to Recover Your Files and Save Your Bacon and 10 Best Free Hard Drive Utilities.
Some addition links found on Google
http://www.datarecoveryreview.net/
http://www.cleverfiles.com/
http://www.easeus.com/resource/hard-disk-data-recovery.htm
http://www.dtidata.com/resourcecenter/2010/11/04/hard-drive-recovery-from-scored-platters/
if no luck
http://www.ebay.com.au/itm/120738767650?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
AU $8.40 Buy it Now + postage AU $0.96
you could get this on Ebay if you dont have an account you will need to create one
https://scgi.ebay.com/ws/eBayISAPI.dll?RegisterEnterInfo
Add Email adress
Add Bank Acc
Add Credit Card
also add your postal adress
also add a paypal account
On Ebay summary page you will see on left a paypal link
When you get to the paypal login page at the bottom you will see new to paypal sign up tab
Paypal to create an account
Paypal registration password ,bank card /credit card,phone numbers home/mobile ,email adress and a postal adress
be very specific when you type in the search
Always ask questions ?
Before you make a purchase and keep the email /s for security reasons if the item arrives and its not as described.
You will even see the pictures of your item so you cant make a mistake and get them home delivered.
or you might be able to find one closer for local pick up
USB 2.0 To SATA IDE 3.5 2.5 Hard Drive with an Adapter Cable
You would have to remove the hard drive and use a usb sata ide kit
you will then have to connect it to your computer using a usb port
http://www.bing.com/images/search?q=SATA+Power+Splitter&qpvt=SATA+Power+Splitter&FORM=IGRE
Once connected to another computer to a usb port and power supply you should get a message found new hardware and it should install the drivers it should show on your computer or you might have to install it manually
click start click on computer to open you should see this drive
If you dont.
Click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a Yellow Question / Exclamation Mark? ! or a Red X
you will need to update/reinstall drivers
right click to reinstall drivers.
If you can see your usb drive but its not working
ports (com&lpt) right click update driver
Once you see this drive just click on it to open and copy all or any data you want and save it to another usb drive
or get one of these
http://www.ebay.com.au/itm/NEW-2-5-SATA-USB-2-0-external-HDD-enclosure-case-AU-/221010079433?pt=LH_DefaultDomain_15&hash=item33753a2ec9
NEW!2.5" SATA TO USB 2.0 external HDD enclosure case AU
i have used this method to recover some important files from faulty hard drives.
If you need more help with this post a reply
Hope this helps.
Posted on Dec 01, 2012
anaesarora
  • 172 Answers
SOURCE: I have an Iomega external
please check the power rating and the amperage rating
you will get it as 500ma or 1amp or 1.5amp.
and as 12 volts.
so a adapter with specifications of 12v DC. 1.5 AMPS WILL WORK.
IF 1.5 AMPS IS NOT AVAILABLE USE 1 AMP THIS SHOULD ALSO WORK
IF YOU FAIL SEND THE DRIVE TO ME....
NUMBER +0-9-3-2-1-1-0-1-7-1-7
Posted on Jul 25, 2008
  • 5 Answers
SOURCE: Maxtor Basics external portable hard drive not getting detected
Right Click on My Computer, click on Manage, go to Disk Managment, if the drive is available you will see it there. Check to see if it has a drive letter assigned to it, if not right click on it and choose Change Drive letters. Make sure you are on the external drive though, you don't want to change your C drive accidentally. It should pop up in My Computer.
Posted on May 31, 2009
lifebyguitar
  • 57 Answers
SOURCE: iomega external not visible
Unfortunately, Windows isn't the most efficient operating system when it comes to it's "Plug 'n Play" abilities. In my experience, external hard drives can be particularly sensitive when it comes to unplugging the data cable while navigating the drive. I've had two external drives lose all data because of that flaw in the NTFS file system. The MFT exists on every drive with NTFS storage method. If that becomes corrupt, it can render the drive useless.
The drive may have power, but that quiet beeping you hear is an indication that the reader head is stuck to the platter and may be grinding into it. There is a myth (may or may not be true) that says if you put the drive in your freezer for a few minutes, take it out, drop it from 6 inches onto a hard surface, it may knock the head loose and make the drive work again.
I tried that method, and it made the situation worse for me, but it may work for you. I would resort to that option only if nothing else fixes it.
Posted on Aug 09, 2009
  • 739 Answers
SOURCE: cannot copy files to Iomega 500 GB external hard drive.
It depends on how you formatted the the drive.
If it was formatted FAT it will work on both Mac and PC.
If you formatted to HFS+ (the native mac format) then it will only work on a mac.
Posted on Sep 17, 2009
Geekinator
  • 183 Answers
SOURCE: my seagate external hard drive is making a beeping
Hello there quaylanburns.
Here's your geek-steer ...
Please refer to another post of mine I JUST submitted. Just like him, I'm going to recommend you also perform a chkdsk on the problem drive ...
chkdsk DRIVE_LETTER: /X /R
Regardless of the outcome of that diagnostic, if you're having ANY persistent hard-disk-drive (HDD) access difficulties, AND you have irreplaceable data contained on that HDD, your IMMEDIATE objective is to BACKUP/RECOVER that data.
Please refer to another post of mine for follow on guidance.
Good luck, and please do post back ...
  • to let me (and interested others) know how things worked out,
  • to provide clarification or feedback,
  • if you have ANY further questions.
Today's the best day of my life ... and NOW you're part of it!
Via-con-Dios and Godspeed -- Geekinator (aka Craig).
Posted on Oct 13, 2009
Windows -Delayed write failed. Windows was unable to save all the data for the file D:\$MFT
You've got a "hardware" problem with the disk-drive. Windows cannot write an updated 'MFT' ("Master File Table") to reflect files that you have added/deleted/updated on the Maxtor.
Copy all the files from the Maxtor, e.g., onto another external drive, or "burning" to DVD disks, and then replace the Maxtor disk-drive.
Dec 31, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
WD My Book-Delayed Write Failed-Can't access-Files deleting!
Hi when you buy a hard disk you do not get instructions on how to change from FATS to NTFS. Your hard drive is set to FATS by default,which limits you tranferring files up to 4GB.If you changing to NTFS does 2 things. 1.you can transfer bigger files.
2. You will lose all data on the drive so you have to save any files to another drive ect
To change to NTFS, go to Start then Right-click on My Computer and select Manage. Under Storage click on Disk Management. Now find your hard drive in the list and Right-click on it and select Format. Under File System change the Answer to NTFS and leave the Allocation Unit to default.Click on Perform Quick Format if you want. click OK and confirm your OK with losing all data on the drive,and your done.
Regards Bill
Apr 18, 2010 | Western Digital My Book Essential Edition...
Error msg
try to format the drive
Feb 25, 2010 | Western Digital Computers & Internet
I have a 500 gig Seagate Free Agent external hard drive that I am having problems with. The problem is that the amber light on the hard drive comes on solid (bright) at initial start up, but then goes dim...
windows - delayed write failed
Windows was unable to save all the data for the file I:\$mft.
The data has been lost. This errors may be caused by failure of
your computer hardware or network connection. Plese try to save elseware.
Aug 03, 2009 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
Hard disk failed
dear sir
you can't recognise your hard disk, but you can rectify your data from your damaged hard disk ( by using data recovery softwares ( ex: ontrack data recovery etc., ) ). This is the only option
& you can't use that hard disk in future.
regards
murali
Dec 10, 2008 | Gateway 835GM (835GH) PC Desktop
The file system of my hard drive become RAW.
http://www.z-a-recovery.com/unformat-tutorial.htm
This tutorial describes the procedure to recover one volume when
  • the volume was accidentally formatted
  • Windows reports the volume is "raw filesystem", or "not formatted"
  • An external drive failed, either flash (so called "thumb drive") or an hard disk connected using USB or FireWire enclosure.
  • MFT is corrupt on the NTFS volume, rendering filesystem partially or completely unreadable
The recovery is done in seven steps, requiring about eleven (11) mouse clicks. Note: The older than current versions of ZAR might have been used to create the screenshots in this tutorial. We did not update the screenshots if there is no significant difference between older and current versions. If you see some option in the program which is not described in the tutorial, just leave it at its default setting.
plashkablue_left.gif Step 1 - Get, install, and start ZAR
plashkablue_right.gif box-top-l.gif box-top-r.gif Download and install ZAR just like you do with any regular program.
When you run it, ZAR displays the window like the one below:
  1. Click "Next >>"
plashkablue_left.gif Step 2 - Select processing mode
  1. Select "Recover data from a simple volume or from a functional RAID volume"
  2. Click "Next >>"
plashkablue_left.gif Step 3 - Select physical device to recover
  1. Select the appropriate hard drive
  2. Click "Next >>" for a list of volumes (logical disks) on this hard drive
Nov 19, 2008 | Western Digital My Book Essential Edition...
Problem with seeing files on external Hard drive
What has happened is that your file system on the hard drive became corrupt becasue windows had not updated the MFT on the drive. THe MFT is a table of contents regarding whats on your drive.
What happened is similar to someone cutting out a few pages of the table of contents in a book that has a lot of pages.
Windows tried to fix this stupid programming method by asking people to always use the "safely remove hardware" button in the taskbar to force it to update the MFT.
In this case yur a victim of the Hard Discs MFT not updating properly probably because software was accessing the drive when it was disconnected from the machine.
You need to run chkdsk to have it rebuild your MFT.
http://support.microsoft.com/kb/315265 <-- How to perform Check disk
*NOTE: Remember to use the drive letter that the USB External is on.. Not just type CHKDSK. It will default to drive C to scan for errors. ex: c:\chkdsk g: (where g is the drive your external usb is)
If you get an error like "CHKDSK is not available for RAW drives.. see my notes below.
Beware that it will take a LONG TIME to perform this procedure.
If this doesn't fix it.. contact a data recovery specialist.. It's worth the cost. There are two types. Simple and Advanced.
Simple= recovering files your deleted with the delete button (fairly easy with the right software)
Advanced = recovering files from a hard disk crash or file system corruption. (Not easy and very time consuming)
Nov 04, 2008 | Seagate FreeAgent Pro Desktop - 320GB -...
Maxtor OneTouch 500gb external; delayed write failure, etc., on disconnect
* Mac OS: la función VD Video no es compatible a través de VOB/IFO (carpeta Video_TS). El tamaño de archivo DVD ISO no puede superar los 4 GB. El sistema de archivos FAT32 / MS-DOS no admite tamaños de archivo mayores que 4 GB. No intente formatear la unidad en el sistema de archivos HFS+, ya que no es compatible en el modo TV.
Jun 29, 2008 | Computers & Internet
Maxtor One Touch
The harddrive itself has gone bad, only solution would be to replace the HDD inside the enclosure :-( sorry.
Sep 15, 2007 | Maxtor OneTouch II Hard Drive
Iomega 2TB Prestige External Hard Drive Logo
63 people viewed this question
Top Iomega Computers & Internet Experts
Owen Barnes
Martin Murray
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
