My oil furnace stopped and I think it might be the oil filter. i bought filter and want to change it, but read different things about bleeding etc.. can i just replace the filter without going thru all that or how do I know?
  • mopar440man May 11, 2010
    do you have a 1 or 2 pipe oil line. do you have a tiger loop or not.
  • 52 Answers
Depending on the type you have some have bleeders on top others you just leave loose on open valve until some spills out. you must bleed out the air
Posted on Aug 29, 2009
Furnace power has to turned off and on then it will start and run. Had to do this 2. Days in row now.
Oil burner? If so sounds like there was or is air bubble's in the in the system due to no oil in tank or a breach in the oil feed system (sucking air) . check your oil tank to see if it's empty, if full look for leaks around the filter and or air bleed screw on top of the oil filter housing. the furnace oil feed line will need to be purged of air at the pump with the bleeder screw. Call a heating repair man if you are not mechanically inclined but if you are try bleeding the system. here's a video of how you do it.
https://www.youtube.com/watch?v=gczmnT-FHJ0
Oct 13, 2016 | Heating & Cooling
I have just replaced the coolant in my 2012 T5 VW with the 2.0 biturbo diesel and now it's over heating, do I have to bleed the cooling system?
Right dont think their is a bleed out on this motor ,fill it up run engine till warm then allow to coool and check the level again,should be ok unless you have another problem that you havent stated previously like why did you change the antifreeze in the first place ,stop reading all these s t u p i d books by little more than technical writers who think they know it all and know sweet FFFFFFF all .You only change antifreeze if a leak or a component change .Yes i know what they say but beleave me you will change a hose or water pump before the antifreeze needs changing.Leave well alone while a motor runs just do a regular oil change every 5000 miles witha oil filter every third oil change ,inspect everything but leave it alone and stop reading these sunday drivers type book .
Feb 22, 2015 | Volkswagen Cars & Trucks
My oil furnance is running but when it reches temperature it shuts off and will not come back on until we bleed the lines
You have a small leak on the suction side of the pump between the tank and the pump. when this happens the pump looses prime each time the furnace shuts down and when the furnace tries to fire up again the saftey device trips before the oil gets to the burner.
Jan 25, 2015 | Heating & Cooling
Getting poor intermittent flame. I changed out my
It sounds like there is a leak in the suction side. Be sure all connections are tight and you replaced all gaskets etc. I am not familiar with your system but hopefully this helps.
Sep 30, 2013 | Suntec a1va-7112 pump,oil burner
Reillo 40 oil burner wont start
If I read correctly, you should have a pump for your fuel oil. If you are not getting anything out of the bleed screw I would suggest you start there, see if it is running, then check for clogged fuel lines, or possibly filter. Do you have a pilot light or HSI? Does that come on?
Mar 02, 2013 | Heating & Cooling
How to Change the oil and filter on a yamaha Vity 125 2009 and how much oil do i need and what oil
Not one answer is for the Yamaha Vity 125cc. Why give instructions for a completely different bike, please dont listen to the previous answers. I own a vity and this is not how to change coolant etc....what they are talking about is a Motorcyle of a completely different model.
Mar 21, 2012 | 2009 Yamaha Vity
Aprilaire 550 makes extremely loud grinding noise when turned on
yes it should be bypass but solenoid could be trying to open but the voltage to it may be to low if you have 24v ac power at the 2 small wires. but to change shut down power to furnace and water to humidifier.you loosen the 2 compression nuts unwire they cant be reversed so dont worry then 2 mounting screws then reverse to install
Dec 17, 2009 | Aprilaire 550 Humidifier
Oil pressure reading
I have a gmc envoy (same thing) and it does the same thing. normal.
May 28, 2009 | 2000 Chevrolet Blazer
My oil furnace is locking out what do i do
You need to change out the burner orifice, change the filter and make sure there is pkenty of oil. Bleed lines at brake like valve until there are no bubbles present.
Mar 02, 2009 | Honeywell Power Humidifier: Furnace...
Extreme heating bills
easy way to fine the high usage is to turn everything off and watch your meter and have someone start turning thing back on and watch for the most usage of power
Jan 25, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
56 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
