Question about Furniture
Benson mattress showed local depressions after just one night,and deterioration since then. it is only two months old now.
    Problem Solver:
  • 16 Answers
In case, you must complain to the manufacturer or the supplier or from whomever you purchased the mattress. From next time, purchase only from reputed company and also use a mattress pad along with your mattress.
Posted on Feb 05, 2013
If the orange exclamation light is on constantly does this mean the error is unsolvable?
means that a printer cartridge is empty and needs replacing
most likely it is for the color cartridge
While you may not be using color , thee is a certain amount of color used to get the various shades of grey/black to get that variation
If you decide to junk it , hp printers are available for around $40.00 and for your use will last at least 10 years
May 25, 2018 | Dell Office Equipment & Supplies
The "F" LED remains on and I'm unable to get it to change states by depressing the settings button. This has happened on two of the units that are both less than 6 months old. Any ideas?
Copy following link to identify timer, and find comparable product that might last longer.
http://waterheatertimer.org/Woods-timers-and-manuals.html#2001
Check output voltage at outlet using multimeter. Should be minimum 80% rated value or 110Volt outlet = 88 volts
Check outlet with circuit analyzer for correct polarity and grounding.
All timers come with 1 year limited warranty, in this case it will be through seller because first alert does not show timers on their website.
Don't buy First Alert products.
They are generally cheaply made promotional grade timers.
I recommend Intermatic HB61RC or Woods 49103 or Intermatic HB65R because their products are good, and warranty policy is direct from company.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 24, 2012 | First Alert Hardware & Accessories
Last night i was on my lg xenon and it shut off. well this morning i turned it on and now my screen wont work. nothing is showing up on my screen. its only about two months old.
This is a common manufacturing error and can often be repaired by going to a touchscreen specialization store and getting them to replace the LCD screen. If this does not work I strongly suggest that you go to your local provider that you have your contract with and show them what is going on with your phone, and ask if it can be replaced. Bright lights, if you leave your phone in the sunlight, it kills the LCD screen. And if you leave it in extreme heat, even in the shade, it can cause the screen to crack.
Nov 06, 2010 | LG Xenon GR500 Cell Phone
Trimmer will start but as soon as i depress the trigger it dies. I have had to replace the primer bubble and in doing so made sure the gasket was put back on properly IT JUST WONT STAY RUNNING can you...
Your trimmer is starving for fuel. If it is less than 18 months old, my guess is that it just needs a carburetor adjustment. If it is older than 18 months, it should have the carb cleaned and rebuilt, or replaced. Check with homelite.com for the cost of a replacement carb, sometimes they are less expensive than having the old one repaired. If it just needs an adjustment, find a local repair shop to do it for you. Homelite requires a special tool to adjust the carb, and won't sell the tool directly to consumers. Some shops will sell the adjustment tool. No special tools are required to replace the carb, just basic tools.
Sep 11, 2010 | Homelite Mighty Lite Lawn Trimmer
Chrome delivery spout deteriorates
I have had this issue as well they are replaceable. order the part thru your local repair person or appliance store
May 04, 2009 | Dacor CM24P
Zenith Redi_set clock radio Z230S
Describe your problem: Depress MONTH/DATE and ALARM1 for 3 seconds and display will show DST 'start' month,week,and date.
Display will show 4F 4.1, alternately flashing
4F = April First week. 4.1 = April 1.That is the old dates for change. What we want to do is to change to the new dates. Once it is done, it will change in the new dates as it did on the
old dates..
Hold down the MONTH/DATE button for 5 seconds, and while pressing the - or down button3 times, until the display shows '3'F2.
3 is month F2 is the week.
=March 2nd week.
You have successfully change the March changeover.
Now for the November change.
Depress and hold MONTH/DATE and ALARM2 after 3 second the display will show DST 'end' month,week, and date.
First digit will be 10 =month. second digit will be L=Last week, and date, will flash alternately.
While holding down the MONTH/DATE press the + or UP button once the display will show 11 (November) and F (first week) and 1 as date alternately flashing.
You have successfully set it for the next 100 years
Apr 17, 2009 | Zenith Z230S Clock Radio
Dim headlights on 2006 buick lacrosse
check the earth wire first,wattage on the bulbs in case their wrong or old type bulbs ,check supply voltage ,if all ok then fit aux spot lights .if still having a problem have eyes checked as over 40 the old peepers can deteriorate ,dont know the name of it but it can affect some people at a younger age than others,glasses will not correct this problem.
Feb 13, 2009 | 2006 Buick LaCrosse
Side by side whirlpool fridge/freezer
ON SOME OF THE FRIDGES THERE ARE RESET BUTTONS WHICH YOU DEPRESS ONCE THE NEW CARTRIDGE IS INSTALLED.CHECK BOOKLET ON FRIDGE AND SEE WHAT BUTTON OR SEQUENCE OF BUTTONS NEED TO BE DEPRESSED TO CANCEL
Aug 01, 2007 | Whirlpool GD2SHGX Refrigerator
Furniture Logo
262 people viewed this question
Top Furniture Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Furniture Expert? Answer questions, earn points and help others
