I have A line that runs vertically thru my Mitsubishi Plasma TV. It look like Plasma burn, but its not. Its in the exact middle of the screen and its getting worse. Have you seen this before? Please Help Thank Scott
  • 133 Answers
If you take the back of the tv off, there are 2 boared on the left side, sometimes it is one, you will see ribbon connectors that goe from those boards- int the panel, alot of times you can umplug those, then plug them back in, it solves the prob sometimes, if it doesnt, turn the tv on, then unplug it- while still on, after 20 seconds- plug it back in, it will do a reboot, and turn itself back on, if the line is still there, it is most likely a defective panel, if your not under warinty, unfortunatily- it is cheeper to buy a new tv, hope this helps a little
Posted on Jan 11, 2009
LG vertical green line
LG plasma vertical line repair - YouTube
? 2:33
https://www.youtube.com/watch?v=24FkcQoeGPg
Feb 10, 2013 - Uploaded by Matt Mayer
I have an LG plasma, my vertical line is in the middle, as if one would have ... Panasonic Plasma TV TC-P50X5 Vertical GreenBar Line Fix ...
EASY HOW TO FIX LG plasma TV - color bars - YouTube
? 4:45
https://www.youtube.com/watch?v=QyaBiSkc1l8
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ..
Jan 16, 2016 | LG Televison & Video
Multi colored strip running thru tv
I'm affraid to say that your screen has got a PDP/LCD fault. Just like a tube going on a TV. This is a fault which is beyond economical repair
May 27, 2010 | Toshiba 50HP66 50 in. Plasma Television
Mines a LG RZ42PX11 it intermittently gets a black vertical line down the middle of the screen.
Hi I have a LG RZ42px11 there are 6 vertical thick black lines running down the middle off the screen, when cold the TV seems OK but if it has been on for around 10mins or on standby the lines stay on screen.
Thanks.
Douglas.
May 13, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
I have a black vertical line in the middle of my
There are two boards at the bottom of the set connected to the panel. Follow the black line to the boards(it will be inline with one or the other) either that board is bad or the panel itself is bad . The boards do not meet exactly in the middle.
Oct 21, 2009 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Good sound no picture just line thru middle of screen
If the line is going across the screen from side to side that means you have lost vertical deflection, and you don't want to run the set like that because you can burn that line into the picture tube. Most likely would be the vertical output ic, probably with a 400 location number, example IC401, could also be a capacitor in the vertical circuit most are close to that IC.
Aug 28, 2009 | Mitsubishi Televison & Video
Black line in middle of 42'' plasma screen
It could be one of buffer was defective. Get it repair does not cost so much $$$.
Aug 18, 2009 | Televison & Video
Vertical lines on screen
1. Frist on the BURN MODE.
2. Check whether same
Vertical lines on screen ?? 3. If yes ..?
4. Then change the LOGIC BOARD or PDP
Jan 11, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Samsung hpr4252x perfect picture in
You have a burn in problem from watching widescreen movies.If you have access to a signal generator or tv setup disc run a perfectly white screen on the plasma for about 30 min.This should help even out the pixels on the display.
Mar 05, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Got a blue vertical line on me plasma
I had the same problem, a vertical blue line from top to bottom on my samsung TV.
Try this download this http://www.jscreenfix.com/video.php i burned it to a dvd and it fixed it within a minute.
Nov 07, 2007 | Samsung HPN5039 50 in. Plasma HDTV
Mitsubishis TV Problem
have a Mitsubishi TV 1993. Model CS-35301. The problem is that there is a white line that is running through a blank screen. The sound is fine just no picture. Have you heard of "Vertical Collapse?" I would love to save the TV. Hi nothing to worry just minimise brightness to avoid screen burn. "Vertical Collapse?" means one bright hor.line in the middle of screen. this problem can be solved 1 check vertical yoke connector or wire loose 2 check supply to vertical section which normally comes from EHT transformer check components in vertical section or print loose regards thanks
Sep 10, 2007 | Televison & Video
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
