Question about Buffalo Technology Buffalo Linkstation Live Ls-xl 2 Tb Desktop Network Hard Drive - Gigabit
LS-XL 2.0 flashes blue continuously. Unable to access:
How do I get my Linkstation Live LS-XL 3TB - Flashing Blue Light to stop blinking?
Lets hope you did not damage it with a failed installation. (if it was firmware) If you just tried the install CD: Most of the time when you change the router (this wifi box....) you also change the IP range. If you set a fix IP on the storage what most people do you do not find it in the new network. The solution woud be a reset, or connect a PC with old IP range, change it to the new.
What do you see in the NAS NAvigator? Quote the device name pls.
Oct 13, 2014 | Computers & Internet
How to do a hardware reset for LS-XL?
Turn off the LinkStation. 2. Turn the LinkStation on with holding down the function button. The function LED will flash blue. 3. Press the function button again while the LED is flashing.
The status LED will flash blue. It will start flashing amber when initialization begins.
Aug 24, 2014 | Buffalo Technology Buffalo Linkstation...
Engine won't start and shows trouble code P1516 and reduced engine power light is on
Here is the definition of the code.
Possible causes - Faulty Throttle Actuator Control (TAC) module
- Throttle Actuator Control (TAC) module harness is open or shorted
- Throttle Actuator Control (TAC) module circuit poor electrical connection (loose or broken wires)
P1516 CHEVROLET Description The Throttle Actuator Control (TAC) module contains data which is essential for proper TAC operation. The TAC module continuously test the integrity of this data. When the TAC module is unable to write or read data to and from Random Access Memory (RAM), or the TAC module is unable to correctly read data from the flash memory or and internal TAC module processor fault is detected and the Detected Trouble Code (DTC) is set.
Read more: http://engine-codes.com/p1516_chevrolet.html#ixzz286Gl3cSo
Sep 28, 2012 | 2002 Chevrolet TrailBlazer
Unable to connect my new nintendo DXi XL to wireless internet
Welcome to Fixya.
Nintendo Dsi/DS/Ds XL connects to the internet using wireless connection. You need to know the settings of your router. I've listed below the steps on how you will access the router and to obtain the information needed for you to be connected.
How to access the Router:
1. You need to know the ipaddress of your router. You can refer to the manual or check the Default Gateway of your computer (Make sure that you connect the computer to the router using an ethernet cable for you to get the Default Gateway). Click on START then RUN. Type CMD on the small box on the lower left of the screen. Type IPCONFIG on the black window and get the value of your DEFAULT GATEWAY (it starts with 192.168.x.x)
2. Open a Browser, Type the DEFAULT GATEWAY on the address bar of your Browser. It will ask you for a username and password. (Refer to the manual of your router or post a reply so that i can provide you the username and password of your router)
3. Go to the Wireless Settings Page of your router. Look for the SSID or the Network Name and theNetwork Key or Passphrase. You can personalize it so that you can easily remeber the details.
4. Make sure you connect to your SSID and enter the Network Key to make it secure.
Now that we already know the setting of the router then its now time to connect the Dsi to the network.
1. Go to Nintendo Wi-Fi Connection Settings of the Game
2. Search for an Access Point (SSID)
3. Select your Network (SSID), If you have an open network, just click "OK" and it should work just fine! If it's a Red Padlock, it'll prompt you for a Password or Network Key. This is the reson why we access the router.
4. Test the Connection.
Sep 10, 2011 | Nintendo Dsi XL Midnight Blue - Utlsbka
AM UNABLE TO ACCESS FB.....i get NETWORK error ALWAYS...
Hi! please the solve the following with out error
1. Registry keys at your system
2. Activation and continuation mode of anti virus
[delete especially trojan virus]
3. updates of java and flash players
4. blocking of add - on's
have fine
Dec 21, 2009 | GPS
Fell and now cannot access the drive
there can be 2 problems:
1) VIRUS INFECTED
2) DLL file is infected
May 17, 2008 | Fantom Drives 120 GB Hard Drive
Buffalo Technology Buffalo Linkstation Live Ls-xl 2 Tb Desktop Network Hard Drive - Gigabit Logo
139 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
