Question about AEG L16820 Front Load Washer
How to remove drain pump aeg l16830
I have an l16830 washer dryer, how do i access the drain pump?
4 Suggested Answers
SOURCE: AEG Washer dryer will not complete cycle
I ended up trying the machine on a few different cycles all of which failed to complete. Finally tried a 'Drying' only cycle and it emptied out quite alot of water which was odd. It now seems fine. guessing it was a blockage and a certain amount of water was backed up in the machine??? any clarity welcome.
Posted on Mar 25, 2008
SOURCE: How to remove drain pump on AEG 88840 washer?
Hi
Not really a fix this but may get you going for a while.
We have a AEG 12710 update with what sounds like the same problem,If you remove the filter you can see the pump impellor and with the power off you can spin this a bit with a screwdriver etc and then box it back up and it should spring back to life for a few weeks.This is what we are having to do every few weeks until i get a new pump sorted.
Hope this helps
Posted on Dec 06, 2010
  • 3 Answers
SOURCE: flashing e20
erroe e20
Posted on Feb 05, 2011
I have a AEG L16830 Lavamat Turbo Washer Dryer 1600 and it has no power to the machine
It sounds like you will need to reset it. The reset on the inside is probably a built in overload breaker.
Sep 27, 2014 | Washing Machines
My AEG lavamat turbo 16810 update, makes a rumbling noise when the pump runs. The filter is clear so I presume I need to remove a foreign body from pump. My question is how do I get to it. can you give...
I'm not sure if this model has an access panel with 2 screws at the bottom, but if not, An easy way to access is by tilting the washer against the wall and removing the bottom panel, Should be 4 screws. from there you can remove the hose and retrieve the debris from the pump most likely change. have a fairly good size bowl and towels close by to catch the water. make sure the washer is disconnected from it's power source. Hope this helps.
May 02, 2011 | AEG Lavamat 16810 Front Load Washer/Dryer
Getting E20 error message so I need to clean out the pump and hose but I can't get inside the machine - how do I get access to the pump? Thanks
Try bottom right / drawer here Filter within, you will see a long tube that comes out ,you take out the end stopper and drain first then remove and /clean filter good luck...
Apr 01, 2011 | AEG Lavamat 16810 Front Load Washer/Dryer
Door will not open
typical problem for front load washer is that it stops when it comes to a rinse or spin cycle.there is something blocking the drain pump.in order to drain all the water out of the washer the best way is to use a wet dry shop vac.
attach the vaccum to the end of the drain hose and remove all the water.
once the water is removed the door should unlock.then you can access the drain pump from either the front or rear panel depending on the model you have.some models will have a access panel on the front to check to drain pump however if you do not see anything in the pump.
then the obstruction is in the part of the drain hose that leads from the bottom of the tub into the drain pump.if there is no obstruction found then you need to check the wiring and make sure it is securely attach.
last thing when all else fails replace the drain pump
Feb 04, 2011 | AEG Lavamat 88840 Front Load Washer
Hi
Hope this helps
Apr 23, 2009 | AEG Lavamat 88840 Front Load Washer
AEG LAVAMAT 12700 VI turbo washing machine doesn't drain
Hi, You have taken out the strainer of the washer front and cleaned it regularly haven't you?? If that's clear, it's probably just the waste line blocked. Try removing the waste pipe where it joins under the sink, put it in a bucket and see if the washer drains. It's probably full of sh"te. If that doesn't work, then I'm probably full of sh"te and you might need a new pump.
Feb 10, 2009 | AEG L12700ViT Front Load Washer / Dryer
Looking for a manual for washer/dryer L16830
You can get the manual here line 20.
http://www.usersmanualguide.com/aeg/washing_machine
Good Luck And Please Rate FixYa!
Dec 28, 2008 | Washing Machines
AEG Lavamat 16830 washer dryer
can anyone tell me how to remove the rear panel of a AEG lavamat dryer. regards Roy
Jul 20, 2008 | Washing Machines
Error 20 AEG washer dryer
On 40c wash hit E20 error so moved programme onto long spin and all ok!
Jan 09, 2008 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG L16820 Front Load Washer Logo
100 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
