Question about Amana BC21V1C Bottom Freezer Refrigerator
How do i remove bottom vents to clean on amana bc21 or bx21
How to clean bottom front vent
Maytag317
  • 1136 Answers
SOURCE: Need to defrost behind freezer since fridge won't work.
Hi, If the vent is plastic, it most likely snaps into place. If you look in the middle of the vent, there is a small tab holding it in.
Since you are needing to defrost this, do you know what to test to find out which part is bad?
I hope this helps and, if you need assistance testing the defrost, please let me know.
Thanks
Vic
Posted on Jun 20, 2009
SOURCE: Our Amana ARB2217cc bottom freezer works fine, the
Did you find what was wrong? We have the same model and are currently having the same problem. The top portion will not get cooler than 55 degrees but the bottom seems to be working fine. The back fan also seems to be running smoothly.
We vacuumed the vent below the freezer section. Hoping this will help.
Thanks for your help!
Posted on Dec 23, 2009
freetek
  • 5568 Answers
SOURCE: Amana refrigerator not cold
The fan that should circulate air between the two compartments has failed. These usually have 'sleeve' bearings which can become sticky and fail to start up without help. Go to the Sears/parts website and enter your Amana model number; if you are lucky, they will have a line drawing of your model which can aid in finding how to access the fan:
Sears Parts Dept.
They have info for thousands of non-Sears items and most can be ordered via that website as well.
Posted on Feb 25, 2010
woodchuck789
  • 4059 Answers
SOURCE: Freezer part of my amana side by side is cold but not freezing
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Part 1541 on this diagram is your timer. It's under the front behind the kick panel. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=21463&diagram_id=646025#d646025
Posted on Apr 24, 2010
heatman101
  • 43501 Answers
SOURCE: Amana bottom freezer Refrigerator. Freezer is cold
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 28, 2010
I have the heater 2 years and I now hear a noise and the front bottom is getting extremely hot right above the blower vent.
Make sure the blower vent passageway is clean and free of debris. It should like the vent is plugged.
Nov 14, 2014 | Dryers
I want to clean the inside of my DLG0452W. Hasn't been done in 10-11 years. This is all part of venting. It properly. Can I take the bottom panel off?
i looked up your model and it looks like you haave to remove the top panel and then the front panel to get to the inside cabinet,if on the front you do have an access panel on the bottom then yes you want to remove the bottom front panel,pull out the lint filter,remove the duct that the lint filter slides into and clean that,then with a shop vac vac out the cabinet,then set the shop vac up to blow and blow all the lint from the back forwards and blow off the motor,this way you don't have to pull the belt and drum.when that's done go to the back and remove the vent line from the dryer,if it's a long run to the outside,go outside and make sure the duct is open,no cage or screen blocking it,go back inside,stick a leaf blower into the vent line and blow it out.do this once a year and your dryer will run better and last longer but mostly you won't have a fire.hope this helps.
Oct 08, 2013 | LG DLG0452W Gas Dryer
Cleaning out the dryer vent in the front of the dryer
The easiest and effective way is to get a long brush and use it from the top down with your vacuum hose to catch the lint as it breaks free.
If you are really adventurous here is how to take it apart...
- Remove the lower panel in front by pressing on the release springs, they are in the slot between the upper and lower front panels about 3 inches from each side. Lift and remove the panel.
- Snap the end caps off of the console on both sides.
- Remove the two screws that point down in the console into the top
- Swing the console up
- Remove the 3 screws under the console that hold the top to the back and slide the top toward you and lift off
- Look inside and tilt your head down like you are looking back at yourself. Locate and disconnect the wires to the door switch. Mark which ones went where.
- Remove the 2 screws from the front panel on the bottom first, then the top and pull the front panel off.
- From here you can clean around the motor the bottom and take the door apart to clean the lint chute.
Apr 23, 2010 | Kenmore 63942 Dryer
Maytag performa Keeps blowing Thermal Fuse. Vents are clean. Cleaned entire system. Seems to heat up as soon as dryer cuts off.Changed control thermostat as well. Can get one load and replace fuse.
something is still plugged with lint,if the vent line is long blow it out with a leaf blower to clean it out,you have to clean out the duct that the lint filter slides into,if the filter is on top remove the vent line,remove the back panel,remove the lint filter and the two screws in front of it and remove the four screws and clean out the duct,if the filter is in front take off the bottom panel,remove the filter and clean the duct,also vac out the inside of dryer where the motor is,when the dryer gets to hot the thermal fuse pops as a safety so you still have a block somewhere
Mar 19, 2010 | Maytag PYE2300AY Electric Dryer
My dryer is taking forever to dry clothes. Very damp and a lot of condensation when I open the dryer. It's model # MDE508DAYW
Good day,
Sounds like the vent system is badly blocked, the blower wheel has stripped off it's shaft, or there is a lot of lint in the blower wheel/lint screen area.
1. Remove the vent hose and see if your getting air moving thru smarty. Maytag moves a lot of air. If O.K. test dryer with vent off for performance. Clean or replace vent hose as needed.
2. Blower wheel sheared on it's shaft. You have to remove the front panel to see if the wheel is loose. Old version had 2 screws on the bottom of the front panel. Remove, disconnect door switch wires and remove. New style (no screws on bottom) requires a putty knife forced on each corner of where the top meets the front. About an 1 1/2 inch in from the edge. Force in, releasing clip, and pulling the top of the front panel toward you. Lift off.
Should the blower wheel be bad, replace but make sure the area between the blower wheel and door filter are cleaned.
Feb 28, 2010 | Maytag Dryers
Lg lds5811 leaking in front at bottom left of door. cleaned gasket and door, still leaking. any ideas, thanks
if its leaking down the vent out the bottom of the door when it runs.you need to replace the vent fan ***.the gasket on the vent door is bad.
Feb 24, 2010 | LG 24 in. LDS 5811 Built-in Dishwasher
LG LWHD8000RY6 water leak -- gathers inside on the bottom and by the radiator
This may be due to two things, unclean unit, glugged drain holes…an easy way to do this is to pull the front vent off and see inside and see if you can caulk all around the inside and seal up the front by the vent so the water is forced out the front vent [you need to drill a little hole in the lower section of that front vent after you clean the unit and caulk the inside]
Look to see if the drain holes are clear and the water coming out from them either from the back or the bottom…I am not sure how much work you need to do but you may think about installing a hose to it to drain the water out better than the small hole in the back or front…make sure that the unit is little tilted to the side that you have the vent hole at…
This unit discharge lots of water during heat humidity, etc. or dirt built up on the condensing unit on the back, so cleaning may be with vacuum, water pressure, or just by hand, it is up to you… let me know how that work for you and please do not forget to rate my service so we can improve on it with your help. God bless
Sep 11, 2009 | LG Heating & Cooling
How do you get the front panel off to clean underneath?
just pull either at the top or bottom of the bottom panel. It'll give.
Jun 29, 2009 | Kenmore 63942 Dryer
How to open lg dle2514 front load to clean blower and vent
Remove the 3 screws holding the top of the dryer.  Push the top towards the rear and remove top.
Remove the front control display board by removing the 2 screws and unsnapping the control panel.
Remove the 4 top screws hold the front panel and the 2 bottom screws in the door frame area.  Remove the light switch wire connector.  Tilt the front panel forward and lift up.
Apr 29, 2008 | LG DLE2514 Electric Dryer
Leaking water out of front vent when opened
Hi jpkenney, The vent can be replaced. If you open the door and look around the outside of the door, you will see the stainless screws that hold the top & bottom parts of the door on.( the top control section is separate to the rest of the door). Just undo the screws & there you have it. The vent can be replaced easily. Hope this helps.....goodluck.
Jul 29, 2007 | Miele 24 in. G881SCI Built-in Dishwasher
Amana BC21V1C Bottom Freezer Refrigerator Logo
55 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
