Question about managemylife.com
How do i change the baking element in my kenmore oven?
Do I need a certain tool to unscrew the baking element from the oven?
  • Anonymous Mar 27, 2014
    When trying to bake, once the temp. Is reached, F10 shows up on the display and the oven beeps. How can this be fixed?
  • 25 Answers
Yes make sure the power to your stove is shut off at the breakerbox, the use a screw driver to unscrew one small screw form each end of your element, save the screw. Put the new element in the same way you removed the old one using the original screws. Turn the breaker back on then turn on your oven , the new element should become red quickly .
Posted on Dec 01, 2012
Kenmore electric range model 911.95875790, no heat to either baking and broiler elements.
Hello. I looked carefully at the service manual for your unit--surprisingly, there is no thermal switch inline with the bake/broil elements. Usually, if the bake or broil elements pop, this blows out the thermal switch, killing power to the elements for safety. The main control board can get damaged due to the high current draw during a short-circuit. The part number for the main board is WB27T10008. The overlay(the decorative sticker with the button/names on it) numbers are as follows: almond WB27T10022, black WB27T10023, and white WB27T10021. I hope this helps you!
Sep 18, 2015 | Kenmore Ovens
Kenmore electric oven will not bake
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. If the element is burned or no longer has continuity, it will need to be replaced.
Apr 04, 2014 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore electric range oven baking element does not go on eveything else works
The bake element
Jan 30, 2014 | Kenmore Ovens
Bake element not working
You will need to replace the oven control ERC
Jan 25, 2014 | Kenmore Ovens
Where are the bottom elements located on a kenmore electric stove c880 type 30s..
They are under the oven cavity. The Built in elements are considered a deluxe feature. In case it needs to be changed depending of the manufacturer ( Kenmore is only a name and many suppliers build product that are rebranded Kenmore ) the element is accessible through the right or left side. In case it needs to be changed you can remove the side panel and slide the baking element out to change itr
Mar 14, 2011 | Kitchen Ranges
Oven takes 20 minutes to fully heat on bake - Kenmore oven plt095-2
if its a gas model most of the time you will have a weak oven ignitor. if an electric,check to see if the bake element gets hot ,some ovens will bake with upper and lower elements so if only the upper works it will take much longer to pre-heat.good luck!
Jan 16, 2010 | Kenmore Ovens
How to change the bake element in a GE stove
Unplug or turn off all power to the oven. With most ovens you can then unscrew the element from inside the cabinet with either a screwdriver or a 1/4 nut driver. carefully pull the element out with the wires attached and dont let the wires go back through the holes. Unplug or unscrew the wires from the old element and plug into or screw onto the new depending on the type of terminal. If it is a push on type terminal make sure the connection is tight, if they are not tight pull the terminal back off and tighten the gap with pliers and recconect. put it back together and you are done. If by chance the wires are not long enough you will need to pull the stove out, remove the back panel and make the connections from the back. Good luck, it is not hard.
Dec 13, 2009 | GE Ovens
Kenmore oven lower element sporadically heating.
When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
May 27, 2009 | Ovens
Kenmore electrical oven
Trying to better define the problem....
Do you have any cuts, holes or "shorting" or tin-foil/aluminum around your bottom bake heat-element? If so, you may need to replace the baking Heat Element. (Ensure you do not use aluminum foil around your heat element to prevent your oven from getting dirty)
To replace your baking heat element, with power off; remove 2 screws securing the bake element. Slightly tug and pull towards you for about 3 inches or so and disconnect the connecting wires at each end. Then completely remove the heat element and install new in reverse manner. Whats' you're model number?
Jan 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore Range 911.9324890
Replace recepticles for large elements. It is the part that the heating elements go into. And while you are at the appliance store, pickup a new bake element for your oven. Just unscrew element from oven wall and install new one.
Nov 16, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
managemylife.com Logo
66 people viewed this question
Top managemylife.com Computers & Internet Experts
thinksewfast
Are you a managemylife.com Computer and Internet Expert? Answer questions, earn points and help others
