Question about ViewSonic VA1912wb Monitor
Screen Display stays on after several times of turning off and on
My Screen Display on the VA1912wb Viewsonic is having issues to start-up. When I leave work and come back the next day I have to spend around 10-15 minutes pressing the power button on and off until the screen display fully stays on. I was wondering if it could be a possible setting that might fix this or a power supply issue. Thanks for your response.
  • 1,684 Answers
The most common cause of this is a failure of the filter capacitors on the power supply board. If you can do a little soldering then the repair is easy to do. You will need to replace the bad capacitors and then the unit should be as good as new again. Here is a link to additional information on which capacitors you will need to replace.
http://www.ccl-la.com/catalog/product_info.php?products_id=90
I hope this helps you out,
BuddyMc
Posted on Dec 02, 2012
  • 277 Answers
SOURCE: Screen goes blank after a few minutes
hi if your sure that all the power settings of the screen and the comp are fine then it points to 1 reason: the screen is heating up and the automatic circuit shuts it down... try locating it some cooler place or put a vent behind it... see if it does any help if soo set it in a cool place good luck
Posted on Mar 16, 2006
SOURCE: Viewsonic VX900 turns on for second then shuts off
I had to replace a fuse(F1) on the inverterboard of my VX900 to get it back to life as fuzzytek sugested.
It was replaced by a normal "flat" fuse (for cars). Had no clue about the value, so I tried with 0,5A first. It blew right away. Next value I had was 2A, and it worked! (It might be too small, and it might be too big, but I think it is better to usa a "large" fuse rather than no fuse at all. :)
Some pictures from my installation:
Posted on Apr 11, 2008
  • 55 Answers
SOURCE: Viewsonic VX922 - black screen of death and the blinking (mocking!) green led
Really if this happens then you may want to contact viewsonic to see if it still in warrant. Reminder that most of their monitors have a 3 year warrany from the date of purchase. So make sure that you have your proof of sales/receipt/POP/invoice or what ever you want to call it ready. This model is old so they will ask for it if its a first time repair.
Posted on Apr 22, 2009
  • 1684 Answers
SOURCE: veiwsonic VA1912WB flashes then goes blank
You have a very common problem that happens to many LCD monitors after 2-3 years of use. Your monitor has blown the power supply that controls the backlight bulbs. Go to our web site at: www.ccl-la.com/badcaps.htm and look at the pictures of what blown capacitors look like. Open the back of your monitor and replace any of the parts that look like the ones in the pictures and you should be back going again. Be sure to usehigh temp (105c) replacements. Resolder them in with the side polarity stripe going the same direction and the old one came out. The values of the bad parts will be marked on the sides of the ones you take out, they can be ordered online from us or several other places, the one from Radio Shack are not suitable for use in the high heat inside on the monitor and will soon blow again.
I hope this helps, if so please rate my solution.
If you have more questions just ask.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Sep 12, 2009
SOURCE: Viewsonic VG2021m Image Vanishes on Start Up
It is the picture picture board on your monitor that is malfunctioning, since the power led or button is on, but the display screen goes blank after a few seconds, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Posted on May 07, 2010
I have view sonic VA1912WB 19'' black lcd monitor.. recently im acing problem with it..after i turn on the system the green light blinks and there is no display on screen.. after several(5-6)...
try another monitor on your system if you can barrow one somewhere to eliminate that it may be the computer... if it is the screen check the warranty on it at the view sonic web site... also check the cable from the comp to the screen to see if it is lose. try another cable or if it has hdmi dsub or dvi try those types as well. it may have a lose connector on the one your using...
May 20, 2011 | ViewSonic VA1912wb 19" LCD Monitor
My viewsonic Va1912wb flashes horizontal lines when you turn it on and i know it is not in pal and it is not the refresh trate help me please
Hi There and Welcome to Fixya.
Horizontal or vertical lines flashing/running across the screen poses serious display issues with any LCD/CRT monitors. It only boils down to 2 possible causes :
  • Corrupted video driver
  • Hardware issue
To help you determine which of the above, here's what you need to do.
  • Ensure that the computer is turned OFF
  • Disconnect ALL USB devices except the keyboard
  • Turn the computer on and immediately hit "DEL" (in some systems, it's the "F2") key repeatedly until you reach a different screen. (not the usual Windows screen)
  • Welcome to the BIOS screen
  • From here, spend 30min to 1 hour observing if the lines are present in this mode
If you still see the horizontal lines, then there's a need for the monitor to be serviced by a certified/trained technician. The link below will direct you to their support page for repair/replacement options, depending on your warranty status :
ViewSonic Support
Otherwise, the problem can be resolved by re-installing the operating system.
I hope this helps, Thanks for using Fixya.
Apr 09, 2011 | ViewSonic VA1912wb 19" LCD Monitor
Sir i am having viewsonic va1912wb black monitor , that was not getting display so please can u give me troubleshoot sir
hi dear friends step 1:check all the monitor wire step 2:if wire is correct then u must take a computer shopkeeper to clear a right solution
OK i hope you are agree with me thanks!
Apr 07, 2011 | ViewSonic VA1912wb Monitor
At start up my viewsonic va1912wb display blinks several times then i can see the picture but it is dark almost unreadable. Today it went darker than yesterday. HELP!
If it is dark due to brightness adjustment, get that adjusted. Usually when you adjust the brightness by pressing the menu button, the menu screen would not be dark. If everything is dark dark dark and you can only see some display but in very pitch darkness, then your monitor is a goner, backlit for the monitor is dead, and your monitor will need to be replaced. You can fix the backlit tubing, however it is risky, and expensive, and would cost less if you bought a replacement.
Jan 30, 2011 | Computers & Internet
Viewsonic Va912b monitor
it seems that there is a problem in the lcd back light or may be in power supply section
Sep 12, 2009 | ViewSonic VA1912wb 19" LCD Monitor
The screen is black even though the green light is on
Your inverter or backlight need to be replaced those are the main components that light up the display.
If you find this helpful please rate so.
Thanks
May 04, 2009 | ViewSonic VA1912wb 19" LCD Monitor
Viewsonic VA1912WB error says analog signal
I had a Gateway 19" TFT that did the same thing.
Does the power light stay on? If so, you more than likely have "dry" solder joints at the inverters. Take it apart & shoot a little solder on the inverter solder joints. Good as new now. The solder joints dry out because of the high heat generated. This is a very common problem.
Apr 22, 2008 | ViewSonic VA1912wb Monitor
ViewSonic VA1912wb Monitor Logo
49 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
