Question about Lionel The Polar Express Train Set
Where is the U terminal on a 1033 lionel transformer
4 Suggested Answers
SOURCE: I am trying to hook up a Lionel 1033 transformer
I have the original Instructions for Operating the 1033(written in 1953) - the second paragraph of the "How To Connect Transformer" reads as follows: The "Multi -Control" transformers listed in this leaflet have four binding posts located on the top of the transformers. Of these, "A-U" and "B-U" combinations furnish variable voltage for the track. The control arm of the transformer simultaneously regulate the voltage output of both the "A-U" and the "B-U" combinations. The transformer nameplate indicates the voltage ranges of these two combinations.The "A-U" combination supplies any voltage from 5 to 16 volts. The B-U combination has voltage from 0 to 11 volts. In selecting the proper range of voltage for your particular outfit, try the lower "B-U" combination first. If the maximum train speed is not satisfactory, then try the "A-U" posts.
To paraphrase the "How to Connect Accessories" section: accessories work best with fixed voltage - these voltages are obtained from the following pairs of output binding posts: "A-B" 5 volts; "B-C" 11 volts and "A-C" 16 volts.
Hope this helps, Mark
Posted on Dec 06, 2011
residentoccu
  • 161 Answers
SOURCE: my f3 santa fe only runs in reverse with my 1033 tranformer
try reversing your wires from the transformer to the track.
Posted on Mar 02, 2013
SOURCE: I have a lionel type KW Trainmaster Transformer
New wire and plugs are available at chuckstrains.com , they can also tell you how to get into it
Posted on May 10, 2013
Can two tracks be powered with the Lionel Trainmaster R 100 Watt transformer?
Track 1 as you have it connected is terminals B-F. The second track would be terminals B-C. Connect post B to the outer rails Terminal 1 ? on your lockon. THis will give you 6-16 volts at the track.
Dec 01, 2013 | Toys
Need wiring diagram for Lionel 313 Bascule Bridge
There are 5 terminals on the bridge number them from outside to inside 1,2,3,4,5
Terminal 1 gets connected to the outside rails on a V,Z,VW,orZW transformer terminal U. The control button a #96 push button gets connected between terminals 2 and 3. Terminal 3 also gets a wire from A or B on a V or Z or Bor C on a VW/ZW. Terminal 4 gets connected to the transformer terminal D. Terminal 5 gets a wire to the lockon on the black bridge frame. The bridge needs 3 sections of track on each end seperated from the rest of the track as a stopping section remove the center rail pin on this section, This forms the stopping sections at each end of the bridge.
Oct 14, 2013 | Toys
My f3 santa fe only runs in reverse with my 1033 tranformer
Dec 29, 2012 | Lionel New Haven Freight Train Set
The A terminal of the transformer has no power but the accesory side does
Open up the transformer and make sure the terminal has not become disconnected from the power wire. Sometimes from use the terminal becomes unattached inside the casing.
Dec 08, 2011 | Lionel Cw 80 Transformer
Ι've just joined 2 ovals 40x60 lionel fastrack, used some other items 2 Lionel 6-12018 FasTrack O-36 MANUAL SWITCH RH, 2 Lionel 6-12017 FasTrack O-36 Manual Switch LH, A few 6-12014...
It sounds as though you may have two defective transformers. Lionel has reported problems with some of their smaller transformers. I would have the transformers and the engines checked by a Lionel service station or contact their customer service department for help.
Nov 12, 2010 | Lionel 40 Watt Transformer Train Set Track...
I am trying to hook up a Lionel 1033 transformer to my Christmas train. What terminal goes to what? I want my old 2026 to smoke and my 6446W to whistle.
Dec 14, 2009 | Toys
Reconnecting tranformer wires (red & black) to underside of FasTr
The red wire goes to the center terminal, and the black to the outer one.
Jan 04, 2009 | Lionel Cw 80 Transformer
Lionel The Polar Express Train Set Logo
69 people viewed this question
Top Lionel Crafts & Hobbies Experts
Jeff Hogancamp
Jeff Hogancamp
ray gallant
Traindoc
Level 1 Expert
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
