Question about InFocus IN2104 Projector
Projecting with a Yellow cast - does this mean my bulb is about to go out?
Why will my mitsubishi lvp-x300 projector only project a solid, blue screen?
Blue is probably the default "no signal" screen. It means that the projector is getting no signal..
Sep 06, 2014 | Mitsubishi LVP-X300 Multimedia Projector
Nec vt540 vt540k
probably needs filters cleaning or a new lamp replacement.
Oct 07, 2013 | NEC VT460 Multimedia Projector
My Canon G11 - most indoor pics have a strong yellow-orange hue. What can I do to correct this or is the camera broken?
Light from ordinary light bulbs has a strong yellow-orange cast, which our eyes tend to adjust for without thought. Check the white balance setting on your camera. This is to adjust the camera for the color of the light, to try to make white come out white, hence the name "white balance." Set the white balance to incandescent (light-bulb icon) for indoor shooting under light bulbs, or to automatic to let the camera take its best attempt.
Try experimenting with the white balance setting. Taking pictures in bright sunlight with the incandescent setting will give your pictures a very blue cast, making things look a little colder. There are other settings, such as flourescent.
Sep 19, 2010 | Cameras
I replaced the lamp on a Panasonic PT-LC80U thinking this will solve the yellow appereance, but it did work, it seems that there are not blues in the image. What Can I Do to solve the problem?
here are some probable causes..
This appears to be an older model (over 5 years old) and LCD projectors turn yellow with age. It's just what they do
However, if you are projecting a computer signal or a component signal, a short in the blue signal of the cable can cast yellow hues over your image. The hue will cover the entire image as if you are viewing the image "through rose (or in this case, lemon) colored glasses" so to speak. That's an easy fix.
Harder fixes: the blue LCD panel is weaking and/or gone bad.
If you have a round yellowish spot in the middle of your screen, the diffuser has been overheated and is "burnt".
Apr 08, 2010 | Panasonic PT-LC80U Multimedia Projector
Sony wega rear proj-i believe the bulbs burned out ,tv works in BW only
Because your TV is still projecting a B&W image doesn't mean the lamp is bad. This TV is having something else going on other than a lamp. Possibly a processing board issue if it's only projecting B&W.
This will need to go into a trusted service shop. I would call and see if you can get an estimate of repair first.
Blessings,
A/V Media Tech Guy
Dec 19, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Hitachi projector model CP X260 projects yellow spot on screen
This is probably the polarizing filter. It will need to be replaced. It should not cost very much to fix.
Jan 07, 2009 | Office Equipment & Supplies
Model: Samsung 47w3hf - Convergence problem?
YOU ARE GOING TO NEED 2 X STK392-010 INTEGRATED CIRCUIT THE COST OF WHICH CAN VARY BETWEEN £20 AND £45 EACH AND SOME SKILL IN FITTING I c`S AND THIS SHOULD CURE YOUR PROBLEM.
SUPER8
Nov 20, 2008 | Samsung Televison & Video
Yellowed image projection
The yellow you see is all dust on the mirrrors inside your projector.
If u are lucky you can get the mirrors cleaned by a pro, if you are unlycky as i was, the blue mirror has burn and u need to replace it.
Take your projector to someone who repaire tv:s ot other electronics, they will help you. If its only the cleaning its cheap, if you need to replace a mirror its expensive.
Good luck
Oct 23, 2008 | Sanyo PLC-SW30 Multimedia Projector
Nec projector vt 660
could be bad bulb is it setting in right is coler wheel freeley moving
Oct 06, 2008 | NEC VT47 Multimedia Projector
Yellow band on the edge of screen
Hi chucri
This is most definitely not a lamp problem.
If a yellow colour in either stripes or blotches occur it is a blue LCD polarizer that needs replacement.
May 16, 2008 | Sanyo PLC-SP20N Multimedia Projector
InFocus IN2104 Projector Logo
Top InFocus Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
