Question about Kodak SLICE 14MP 5x Optical/5x Digital Zoom HD Camera w/3.5" Touchscreen LCD Radish
My kodak slice wont turn on anymore even after charging?Anybody?
Is the battery pack sensitive to cold?It was outside in the car overnight in -15 celsius.
    Genius:
  • Kodak Master
  • 1,019 Answers
Hello, The cold temps do have an effect on any type of battery, it is far cheaper to try a new battery that has been fully charged than to take the camera to a shop to be checked. All you will be out is the cost of the new battery.
Posted on Jan 24, 2013
5 Suggested Answers
SOURCE: Kodak v803 wont turn on
i had the same problem, if you try to turn the lens in as if you turning a dile, the lens will go back in manually once you have the lens completly in again, as if the camera is switched off, then turn the camera back on at the power button and the camera will operate as normal, this worked for me i hope it works for you too.
Posted on Aug 06, 2009
leepania
  • 1099 Answers
SOURCE: batteries don't hold charge any more.
The batteries will only last for about 200 recharges. Depending on how you use the camera and batteries. Try with new batteries.
In order to buy new batteries contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Alternatively buy them directly online.
http://store.kodak.com/store/ekconsus/en_US/list/Accessories/Batteries__Chargers/categoryID.28887900
Posted on Jan 21, 2010
lock123
  • 6831 Answers
SOURCE: kodak easyshare ls743. lens wont retract. camera error #E45 shows on screen. battery is fully charged.
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Dec 14, 2010
caroldon
  • 17130 Answers
SOURCE: my kodak slice wont hold
The battery is worn out , it is weak or has expired the life. so to confirm you need to take the battery out and ccheck the charge current, then put this for charging and recheck on the change of voltage. Now place on the camera and as the charge goes down check the voltage.This will indicate and confirm the battery.
Replace with the same type.
Posted on Jun 14, 2011
I have a kodak z650, this is "new" machine in the original box but we never used in the past six years. When then i turn on in the LCD showed "Kodak easyshare logo" then turn off by itself... The le
If you really left the batteries alone for 6 years without regularly charging them, they won't work anymore. I still have two KLIC 500 batteries from Kodak, which I bought in 2005, Both are in very good condition, because the both get a charge every 3 months, even in periods I did not use my camera.
You could try. charging the batteries several times, but don't have to high expectations.
Jan 03, 2014 | Kodak Cameras
I have ZTE Jack 3G.it wont charge till full even when left overnight only to find it not full and continues charging.please help me with his issue.
It sounds like the batteries are dying. A short in the battery pack will give problems like that. Replace them.
Jan 13, 2013 | Cell Phones
My kodak slice wont hold charge anymore. it works fine when its on the charger but when i take it off its dead. how can i fix this?
Jun 14, 2011 | Kodak EasyShare DX4530 Digital Camera
When the weather is very cold (below zero) the car will not even try to turn over it wil only click at the starter and ignition no turn battery is fine never does this any other time. only cold, but once...
It is normal for batteries to lose a good deal of their power due to cold temperatures. If you want better starting power, try using a battery charger/maintainer overnight. It should charge at no more than 2 amps. The slow trickle charging overnight will charge and warm up the battery and allow it to develop full power for a cold morning start.
Feb 04, 2011 | 2005 Saturn ION
My kodak easyshare camera isn't charging.....we already bought a new battery...and it still wont charge?? The charger is still good and working?
My kodak camera requires taking out the battery pack and charging outside of the camera. My batteries have a generic charger I got off of amazon that has a red and green light on it that tells you whent he batteries are fully charged.
If the charger is blown, that might explain why they are not charging.
Are you trying to use AA batteries instead of the recommended battery pack? I would use the recommended battery packs available through amazon.com.
Jun 25, 2010 | Cameras
I have an LG 8700. It is only 8 months old. When I charge the phone, it will beep. Sometimes it will do it every so many seconds, sometimes continually. It will also turns itself back on, and as this...
That batt is almost dead, had a similar problem. No tricks just replace it. Or try charging using a universal charge where you remove the batt and charge it seperately
Jun 04, 2010 | LG VX-8700 Cellular Phone
Kodak DX 4530 dock cradle 11 wont work..can it be repaired?
The dock will only function with the KODAK batteries
KODAK CRV3 Lithium Batteries or KODAK EASYSHARE Ni-MH Rechargeable Battery Pack
Jan 03, 2010 | Kodak EasyShare DX4530 Digital Camera
Kodak camera wont charge
It needs to be charger overnight. If that doesn't work for you, you'll need a new battery.
Aug 06, 2009 | Cameras
Camera will not stay on
I have basically the same problem. I sent it in for repairs. It came back and I followed the instructions they came be. BUT IT STILL WONT WORK. it's worse then before, the logo wont even come anymore ! :(
Jul 18, 2009 | Kodak EASYSHARE M1063 Digital Camera
Left key in ignition overnight, now car wont start
try checking the main relay under the dash
Mar 15, 2009 | 2004 Honda Odyssey
Kodak SLICE 14MP 5x Optical/5x Digital Zoom HD Camera w/3.5" Touchscreen LCD Radish Logo
120 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
