Question about Refrigerators
Our fridges problem is that when we started the fridge after 3-4 mins the fridge stopped working its on standby but the cooler/fans stops working.
  • Refrigerators Master
  • 4,654 Answers
I am trying to understand your refrigerators problem. Has it been cooling normally before this happens? Do you hear any clicking? Also what model is your Samsung? The model number should be around the fresh food section door frame. Are you saying the the refrigerator tries to start but the fans also turn off after the first 4 seconds?
Thanks Sea Breeze
Posted on Dec 03, 2012
eagle338
  • 4889 Answers
SOURCE: Zanussi fridge freezer - fridge not working
The defrost cycle is not happening like it should, that's what causes the block of ice (and poor air flow). If you have all that defrosted look at the defrost bi-metal, it usually is a small round disk with a couple wires coming out of it and it's clipped on the coils. When it's cold enough, it passes electricity to the heat elements, when it gets hot enough it "opens" and kills power to the heat elements. If that is bad (swollen cracked or bloated) and not passing electricity to the elements that's the problem. Another item would be the defrost timer itself, if it doesn't work (no clock motor turning) then it will never go into defrost. And the last and usually least expected failure would be the heat element themselves not working
Posted on Oct 09, 2007
fridgetech
  • 473 Answers
SOURCE: Fridge too cold
There is a damper motor that is behind the vent where you feel the cold air coming out in the fridge section.  That damper should open and close after making temp. adjustments.  See if you can look in the vent and see if it is wide open.  Set your freezer on the coldest setting and check this vent again an hour or so later.  If it is still wide open then that damper motor is bad.  Let me know if you find something different or have any questions.
Posted on Oct 10, 2007
fanny
  • 146 Answers
SOURCE: LG fridge suddenly stopped cooling.
If the fan inside the freezer is running and the compressor behind the fridge is running and is hot to touch, you have a gas problem or the compressor is inefficient. This can only be confirmed by connecting refrigeration gauges to the gas system and should only be performed by a fridge tech.
Posted on Nov 04, 2007
  • 958 Answers
SOURCE: samsung side by side refridgerator making noise and freezing
its a heater cycle problem..the defroster is not working properly. its building up ice in the evaporator that touches the evaporator fan that makes that loud noise but stops when you open a door. it could be either a bad heater, a bad thermo disc or a bad timer.hope i was able to help
Posted on Feb 12, 2008
SOURCE: MIni fridge stopped working/cool.
I got mine in 2005. It stopped working 4 or 5 weeks ago. It made a clicking noise and the compressor was very hot. Compressor is under warranty but appliance repair shop wanted $125 to install it and another $75 to charge it with freon. I saw a posting somewhere else that said it was a relay switch. I ordered one from RepairClinic.com for $24.00 incl. shipping, put it in and it's working now. There's a black plastic housing on the left side of the compressor. Just unscrew that, pop the cover off (that was a little tricky) and plug in the new part. Maybe I'll get another 3 years out of it.
Posted on Aug 04, 2009
Semi conductor electric cooler
These people have a similar fan motor.
http://www.appliancepartspros.com/search.aspx?model=dts%20181%20cr%20dr%20ww
some semi conductor fridges use mains operated computer-type case fans.
Aug 06, 2015 | Furniture
Fridges stops working randomly but the freezer works. Then the fridge starts working after a couple of days
When the fridge stops working, can you hear the fan operating inside the unit? It sounds like you have a failing evaporator fan motor. This fan motor circulated cold air from the freezer to the refrigerator.
Apr 19, 2015 | Refrigerators
Freezer too hot top shelf - fridge frozen on bottom drawer
I would replace the fan or fan switch if it has one
Apr 27, 2017 | Refrigerators
Samsung SR S2028CSS Fridge Freezer - Fridge temperature problems
Try setting it to lower temperature. If that don't work the thermostat is bad.
Jun 28, 2009 | Refrigerators
Whirlpool fridge stopped working. Actually somehow
This is an indication of a direct electrical short. Unplug refrigerator and do not use until the problem has been repaired! Sea Breeze
Mar 27, 2009 | Whirlpool ED5FHEXMQ Side by Side...
How can I tell if my fridge isn't working?
Unplug the Ref for 15-20 min. take off the cover so you can see the compressor, then plug it back in and listen for the compressor to start. You should be behind the Ref so you can tell the difference between the fan running or the compressor.
The compressor should start and keep running.
The fan cooling the compressor should be running.
The fan in the freezer should be running.
You should feel cold air coming into the Fridge side from the freezer side.
Jan 12, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Fridge slowly gets warmer and stops working
You have one of 3 parts not working.
1.The defrost timer.
2.The defrost element.
3.The defrost themostat.
Jan 11, 2009 | GE Refrigerators
Viking Imperial Fridge... Purchased in early 90's
what is the stat set to ? A common problem with bottle coolers that work the same way, is people turn the stat to high ( very cold). This then drops the evaporator temperature so low it freezes up, in turn this stops the airflow and the ice build up worsens until you get the result you have, a warm fridge due to no airflow at all. It could be short of gas as this can cause it. A faulty defrost heater / timer can also cause it if its fitted as can a faulty fan that stops spinning. Due to the age of the unit I would try turning the stat back to 3/4 and see how that goes. it will get cold but will be more gradual, but hopefully shouldn't freeze up.
Mar 19, 2008 | Refrigerators
Samsung side by side refridgerator making noise and freezing
Feb 12, 2008 | Refrigerators
Nov 04, 2007 | Refrigerators
Refrigerators Logo
74 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
