Question about Sony BDVE280 3D Blu-ray Home Theater System BDVE280
SONY BDV-E280 NOT WORKING....
On turning on it says welcome on front of unit then makes a few beeps noises welcome title disapears and thats it , have tried unplugging , but nothing happens.
  • chris Dec 02, 2012
    I need to keep un-plugging and re-trying , its as if the starter motor has gone on it, it started working but needs about 5 attempts of un-plugging and plugging in, have updated software and changed settings, once on it ok , brill system, but if turned of for more than 4hrs , system will not re start easily, is it a sign that some component is on its way out , 6 months left on warrenty.
4 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: I have a Sony STR-DE435 that won't turn on
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as another possible root cause for intermittent shutdown.
Posted on Sep 08, 2011
  • 4234 Answers
SOURCE: STR-DH700 won't power up unless I unplug-plug it.
This is a logic problem with the internal microprocessor. A quick experiment: Turn the unit on for about 2 minutes and shut it down. Doe sit power uip in this case? If so, I'd suspect that the heat generated during normal operation is creating an internal problem thaty is preventing the micro from recognizing the "off" condition. The power data line is hung and is not being recognizwed by the micro so any attempt to turn the unit on will fail. The unplug/re-plug essentially clears or resets the unit.
If the unit is new, return it for warranty repair. It will be important to describe when the unit fails however. Try to see how long it must remain on for the problem to occur.
Update this with your results if the unit is not under warranty and we'll try to narrow it down.
Thanks,
Dan
Posted on Nov 05, 2009
skywavebe
  • 1258 Answers
SOURCE: SONY BDV-E280 BLOWING FUSES
I have not worked on these directly but it sounds like a bad capacitor in the power supply that blows fuses upon a power on. If the unit has a switch mode power supply the switch on from the strip might be sending in a high transient causing the switch mode supply to draw too much current. How does the unit work if you just leave it plugged in?
If switching these on and off the better way would be through a zero crossing voltage solid state switch.
Posted on Oct 06, 2012
Stuck in demo mode / demo lock
Put the unit in dvd mode. then press and hold the stop and eject buttons. The display should read "demo off". Then the tray should operate normally.
May 28, 2013 | Sony BDV-E280 Home Theater System - 3.1 3D...
Sony BDV-E370
From page 68 of this manual: "Contact your Sony dealer or local authorized Sony service facility."
Mar 02, 2013 | Sony BDV-E370 Theater System
Reading srt on mp4
Hard-code the subs with mkvtoolnix etc.(supposedly 10 min. job no quality loss mkv file it makes) or bite the bullet like me. Use Format Factory or any other free converter, and give the Sony a tried and true xvid avi. That way you can watch it without subs too.
Dec 18, 2012 | Sony BDV-E280 3D Home Cinema System SONY1
My home theatre unit bdv-L600 will not eject the DVD as it says it is locked
I think your best bet is to remove the top of the unit and see what has caused it to lock. Removing the CD once the top is off may fix your problem.
Nov 10, 2012 | Sony BDV-L600 3D Home Cinema System SONY1
Oct 05, 2012 | Sony BDVE280 3D Blu-ray Home Theater...
I have a LG 32lg30dc TV and a Sony BDV-E280 and I lost the remote to the blue ray player. How do I play my movies?
Unless you have access controls on the front you will need that remote. Go to www.sony.com contact customer support and the technical department for possible replacement. Check out www.ebay.com Type: make and model and scroll down the list to see if you can luck out.
May 18, 2012 | Sony Televison & Video
SONY BDV-E280 REGION CODE
Go into menu and into video i believe.....Or google you rproblem
Mar 13, 2012 | Televison & Video
I need the three digit code for my Sony BDV-E370 home theater remote controller.
The RM-ADP053 comes in the box with the BDV-370 and is preprogrammed with the codes to operate that unit. The manual can be found at Sony at this link.
To reset the remote control back to factory specifications, press the POWER , TV/VIDEO , and VOL- buttons simultaneously.
Jan 18, 2011 | Sony Rm-adp053 Remote Control
SONY BDV-FS350 INSTRUCTION MANUAL
I found some support for a SONY BDV-360FS on their european site.
This is the closest model # I could find.
Is this the unit you are looking for support on?
Not the BDP-S300 or BDP-S350 blu-ray players, but a player with a builtin amplifier and speakers, is that right?
Oct 06, 2009 | Sony BDP-S300 Blu-Ray Disc Player
Nothing comes up on tv when i turn ps3 on and controllers wont connect
Read this very carefully. Turn off your ps3 from the back. Then turn it back on wait unit the light is red. Turn on the system through the front keep holding the power on. You will hear a beep one time that just tell you that the ps3 is powering on keep holding the button until you hear the second beep this will rest your video setting. If that dosnt work call me at sony
Nov 07, 2008 | Sony Playstation 3 (PS3) Console
Sony BDVE280 3D Blu-ray Home Theater System BDVE280 Logo
278 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
