Question about Sanyo DP32746 32 in. LCD Television
The power button lights up but no sound or picture.
I have a Sanyo 32 inch digital lcd flat screen. When I turn the power button on, the green light lights up but no sound or picture. This is the third time in a week and a half this has happened. Normally it will come on after a few minutes but not this time.
    Problem Solver:
  • 5 Answers
Check to see if the set is under warranty or an extended warranty.
If not, ouch, but do-able.
From least to worst case, possibilities include
1. Bad panel drivers (between the Y-Sus PCB and Panel)
2. Bad Y-Sustain board or equivalent.
3. Bad power supply.
4. Control PCB.
5. Bad Panel.
Or any combination of...
I would recommend that you have a certified and factory authorized technician repair your set. Or at least diagnose it. Not always is it just replacing a board. There are adjustments that need to at least be verified by a knowledgeable technician.
Wouldn't want to get zapped. There is High Voltage back there.
You might also try entering the make and model number of your set online to search for others with like problems on the same model. Odds are that it has happened more than just once and that other techs may have a definate solution to your problem.
Just takes a little research.
Good luck.
Tim
Certified TV
Posted on Jan 25, 2009
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
https://www.youtube.com/watch?v=BH1OcQ6dIEE
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/54708-4-sharp-power-button-flashing
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from www.tomsguide.com
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
www.normsweb.com/tektips/42dh77.shtml
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
Rca flat screen; 32 inch; model # L32WD22; green power light comes on but no picture or sound
i think its from the cables try to put them correctly ... i think u putted them not in the good place
Jul 02, 2012 | RCA Televison & Video
Sanyo 50" plasma flatscreen, hdtv
Picture frozen on one picture for some channels and blank on others. Sound is on. What could this be? We have a 50" Sanyo. HELP!
Apr 13, 2011 | Sanyo DP32746 32 in. LCD Television
My akai flat screen tv is not turning on. the red light at the bottom of the tv is on and when the tv comes on the red light turns green and in a few seconds the tv comes on, when i press the power button...
i have one of these akai 27 inch with dvd, i had a similar issue i found a power supply at auction and exchanged it and it works fine now, normally with this symptom your power supply is fualty. if the light goes green and you have no picture then you know other boards are fualty
Jun 04, 2010 | Akai LCT3285TA 32 in. LCD Television
Sanyo TV LCD 32 inch about 3 years old. No
the power supply of your tv is bad try to check the fuses if fuse are open try to replace them with the same value..try to power it on but if the fuse blows again replace the power supply board...
good luck plse rate my help.
Jun 04, 2010 | Sanyo DP32746 32 in. LCD Television
Green light blinks but no sound no picture
Power surge will knock out picture and sound if you don't have a power strip. Found out from Best Buys when purchasing another LCD TV. They have a warrenty against such problems.
Jan 18, 2010 | Sanyo DP19648 19 in. LCD TV
Power button is green - no blinks / no picture / no sound
Unplug it from the wall, wait 2 minutes and plug it back in. if problem still exists, its probably the main pcb.
Jun 19, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
Sanyo DP32746 32 in. LCD Television Logo
130 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
