Question about Corvette Chevy Malibu 90-04 Car Radio Wire Harness
I need a stock cd player wiring diagram for 03 malibu
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 49 Answers
Go to the auto wrecker to get a factory harness for it ,Just cut it out of a wreck car, End install it in your car,
Posted on Dec 03, 2012
3 Suggested Answers
  • 99 Answers
SOURCE: 2002 malibu wiring diagram?!?!?!?!?!?!
ok, the red and yellow wires serve 2 different purposes.the yellow supplies constant power to your stereo, and the red is switched power. what youve done is combine the two, and connect them to a constant power source. like this, your stereo wont be switched with your ignition. so take off the red wire, but leave the yellow wire connected to the wire its already on. make sure your stereo fuse is good in the fusebox of the car. then, use a test light, with the ignition switch on, to find the second wire on your cars harness that has power. that will be your switched power. connect that one to your red wire, and that will solve your problem.
Posted on Aug 04, 2009
  • 3640 Answers
SOURCE: what kind of adapter to install cd player into 2000 malibu
what you will need is the radio adapter kit for your car make. also you need a wiring connector for the car between car wiring and radio. match the wires to wires on radio, and then the connector will fit car wiring connector, just plug it in to car wiring.
Posted on May 11, 2010
03 chevy silverado aftermarket cd player
Maybe the sudden shock when connecting cable blew out the in-line fuse
Jun 16, 2013 | Cars & Trucks
Wiring diagram
My fault meant this as a solution post....
What do you need the diagram for? If your installing the radio, you do not need a diagram you need to go purchase the wiring harness for your make and model and year car. Match the colored wires together to the ones on the back of the head unit then connect them, then that harness plugs into your stock car harness that your stock radio unplugged from. You also probly need an antenna adapter cable that just connects to your stock antenna cable to add length and then plugs into your aftermarket radio. If you need a wiring diagram because you are trying to open you radio and fix it because it is broke or something...good luck to ya. Hope I helped... :)
Dec 15, 2009 | Kenwood KDC-MP208 Car CD/ MP3 Player
I took out the stock radio in a 1997 chevy corsica and put a cd player in it but i dont know how to get sound
have to connect wires from cd player (should have diagram with cd player)to applicable speaker wires and also proper ignition and signal wires.
Oct 20, 2009 | Sony Car Audio & Video
Aug 04, 2009 | Corvette Chevy Malibu 90-04 Car Radio...
Wiring diagram for a kenwood KDC MP232 to a 2003 chevy malibu
Aftermarket cd players are all universal and have the same colors. You need to go to your local car audio store such as walmart, bestbuy, ect and buy a wire harness adapter. Then all the wires are color coordinated to make it easy, just wire colored wires together and plug in. If I have helped please leave positive feedback. Thanks
Jun 08, 2009 | Kenwood KDC-MP232 CD Player
Need a wiring diagram for my 92 volvo 940 gl
Go to the following site and enter the make and model of your vehicle and it will give you a free diogram of the wiring to your stereo. The colors do not have to match up.
Apr 04, 2009 | Dual XDMR-7700 CD Player
Wiring diagram needed
The Pioneer website has both the OEM and Install Mauals in PDF format thast will solve your problems... I downloaded both earlier today...
Apr 01, 2009 | Pioneer CDX-FM677 6-Disc CD Changer
Wiring difference
If your installing a stock radio/cd player from another Dodge the wiring plug is the same and will fit.If your installing a aftermarket radio/cd player(JVC,Pioneer,etc)you will need to buy a adapter plug that wires up to the radio and is a direct fit to your factory wire harness,so your not cutting your wires.When you buy the adapter plug it comes with a wire diagram of which wire is what.Your aftermarket radio should have a diagram also,either on it or in the manual.Hope this helps you.
Mar 04, 2009 | 2002 Dodge Caravan
Wiring diagram Max 2255 Addzest sound system
BE MORE SPECIFIC!
Why do you need to trace them? Is it a stock amp? If you know where the amp is....then tracing the wiring is a cinch....
The amp has to be powered, so there's most likely a power wire from your battery. If it's a stock amp, it's powered from behind your cd player. And be more specific, what speakers? There's like what, six?
They all go to one spot man, right behind the cd player.
What's spiking? The sound? As in it's loud, quiet, loud, quiet, loud? You might have a bad ground somewhere, so check grounds. Those are easy to find, behind the deck the ground is black. If it's an aftermarket amp, then the ground is going to be close by to it. It's most likely screwed to the steel part of your car.
It could be your deck to, it might have just got randomly defective. You do have a 96 after all.
If it's an aftermarket cd player...check your wiring harness. You have to cut the wires from the car to tie them into the harness for your cd player, so jiggle those around to see if you can hear a difference.
Jul 21, 2008 | 1996 Mitsubishi 3000GT
Installing a CD player in '08 Aveo in plac eof stock AM/FM radio
You should check with Car Toys or Best Buy but you will probably need an adaptor and a wiring harness. If your doing it yourself your going to need to know how to get the stock radio out and the wiring diagram for the Aveo. Sometimes you can find the wiring diagram on Google by searching for it but usually finding diagrams for 2008 vehicles takes a year or two before it becomes available.
If your CD player has a tuner in it already you shouldn't need one. If it doesn't have one, that presents some other options.
Jun 22, 2008 | Sony CDX-CA400 CD Player
Corvette Chevy  Malibu 90-04 Car Radio Wire Harness Logo
170 people viewed this question
Top Corvette Car Audio & Video Experts
xxxxxx xxx
Are you a Corvette Car Audio and Video Expert? Answer questions, earn points and help others
