Question about Refrigerators
Ge arctica not freezing or cooling temp is at 72 degrees
Stopped working completely. Won't freeze, Won't get cold. Stays at 72 degrees in freezer and fridge.
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Dec 01, 2012
  • 3 more comments
  • darlene diaz Dec 01, 2012
    pss25mgmbb i just paid someone 80 bucks, she replaced the relay but checked the fridge this morn ... still at 72 degrees"/
  • Richard Roth
    Richard Roth Dec 01, 2012
    OK, check to see if the compressor is running and tell me if it is hot.
    is it black looks kinda like submarine, if thats it theres no sound and its cold to the touch.
  • Richard Roth
    OK, you will need to replace the main control board on the back of the refrigerator. There is an access panel on the rear lower right side. Remove the cover to gain access to the board. Be sure to take note of the wiring connections so you don't get them crossed up. I always take a picture of the connections before I replace the board. Here is the new board to order.http://bit.ly/TpI8Jy Keep me posted.
    Thank you Richard, you're awesome. i'll keep you posted. thx again
icansurf
  • 72 Answers
SOURCE: Freezer set at 0 degrees, but runs at 19 degrees. Ice Cream melting...
Low on freon/refrigerant maybe.
Posted on Mar 03, 2007
Bgillespie
  • 89 Answers
SOURCE: GE Arctica Profile getting too cold, temp set to 37 actual temp is 25-35
Wow, so you dropped some money into it, eh? I would take a look at the damper door asslb(DIFFUSER). located at the very top left of your refrigerator section in back. It has a motorized door that opens and close's and it may be stuck open. More than likely it is broken and needs to be replaced. GOODLUCK!!!!
FYI: All your cold air in your refrigerator comes from your freezer!
Posted on Dec 17, 2007
  • 74 Answers
SOURCE: GE Profile fresh food getting TOO cold
Faulty air damper is the usual cause , or possible sensor fault
Posted on Aug 28, 2008
Sea Breeze
  • 4655 Answers
SOURCE: Freezer is only cold not freezing, fridge is cool not cold
You will need to remove the rear panel in the back of the freezer compartment. If Frozen over defrost with a hair dryer. At the bottom you will see a defrost heater WR51X10101 Defrost Heater it has glass around the element inside and will be easy to spot if burned out. Let me know what you find, Sea Breeze
Posted on Aug 27, 2009
SOURCE: GE Profile Arctica model # PSS25NGMD - can't control temperature
Check the little damper door next the water filter at top inside the unit. You will have to remove the covers to get it. The little plastic ends will break off and then you can not control the temperture it act like a freezer. Hope this helps Also you can get this part online.
Posted on Jan 31, 2011
GE Profile Arctica fridge running too cold
You may want to check your damper assembly to see if the door is broken. If the door is broken it will air to migrate to the refrigerator compartment causing freezing issues. Also check to make sure that the damper door is not staying open. When you take the cover off with the door open the damper should close. If the damper is open then you need to replace the damper. Here is the damper to order.
Dec 05, 2012 | GE Refrigerators
Fridge section not cooling enough but freezer OK
Is the fan blowing in the freezer section? Also, check to see if you have airflow thru the damper (vent) in the frig section.
Mar 31, 2012 | GE GSL25JFPBS Side by Side Refrigerator
Won't dispense ice
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking same part needs replaced.The water valve at the bottom rear of fridge.
Thank you for using fixya
imufo2
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Jul 27, 2011 | GE Profile Arctica 25.4 Cubic Feet...
The unit keeps freezing up solid even on energysaver
Change or clean the filter and clean both coils, no air flow or reduced air flow, the coil will freeze. It will also freeze if its set to cold 72 min. setting. Example if your room temp is 72 degrees, than the air will be 52, and the coil temp is 32 degrees, any moisture will freeze. Hope this helps
Jul 02, 2011 | Whirlpool Heating & Cooling
GE Profile refrigerator temperature problem
refrigerators have 2 coils. the evaporator coil and the condensing coil. one is on the bottom of the fridg and one is on the back or inside behind a false panel. these coils must be kept clean or if the condensing coil cannot reject the heat absorbed by the evaporator, the box temp will stay high and if the evap coil cant absorb heat the box temp stays low running the risk of freezing
Nov 26, 2009 | Refrigerators
Nov 17, 2009 | GE Profile Arctica 25.4 Cubic Feet...
GE GSS25LSMFBS IS FINE IN THE FREEZER SIDE BUT FREEZES IN THE REFRIGERATOR SIDE.
Sounds like you need to adjust your airflow into the frig compartment. There are two adjustments for air flow on a side/side one at top next to thermostat and one at bottom next to crisper. If your freezer is working properly like you say then you just simply need to balance the airflow to get the proper temp of just above freezing to 40 degrees
Jul 27, 2009 | GE Profile Arctica Stainless Steel Top...
Honeywell T8112 Air Conditioner Will Not Cool, But Blower Works
make sure the system switch is in the cool position, then press run program button and allow a couple of minutes for system to cycle on, if it doesn't come on press the button for lowering the set point, set it to 72 degrees and then press the hold temperature key.
May 27, 2009 | Honeywell ER150B Air Conditioner
Refrigerators Logo
67 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
