Question about Panasonic Viera TH-42PZ80U Plasma TV
Unlock zoom panasonic viera tv.
I have a panasonic viera plasma tv. I am unable to use the zoom in the menu screen. Is there a way to unlock this feature.
4 Suggested Answers
SOURCE: Panasonic viera
1.You may have the magnet of a speaker too close to the TV.
2.Turn off other electrical devices in the house one at a time.
3.Faulty cable.
Puzzler.
Posted on Oct 31, 2007
SOURCE: panasonic viera doesn't display computer correctly
I have had what is fundamentally the same problem. I have a desktop PC that I am plugging in to my Panasonic Viera TX-32LZD80. I am using DVI connection plugged in to HDMI port.
The solution is fairly simple; use the Menu button on the TV remote to get to the Main Menu for the TV and then select Setup which should be the fourth of four options. This will get you to the Setup Menu for the TV for the current channel. Look for the Picture Overscan option, it will very probably be set to On if you have the problem of %5 or so of display being missing on all sides.
Switch Picture Overscan to Off.
This immediately should solve your problem. A note of warning on this is that I suspected this was the problem but when I first looked at the Setup Menu I could not find the Picture Overscan option.
If you are unable to find the Picture Overscan option then trying fiddling with the Aspect settings. You will probably find it set to Auto. Switch it to 16:9 and you should find the Picture Overscan option will be available from the Setup Menu.
Hope it works for you.
Posted on Apr 25, 2009
dsacco86
  • 1077 Answers
SOURCE: what does it mean when my plasma tv turns off by
Basically when it turn itself OFF automatically all the time, the TV goes into "Protection Mode". This happens when there is a damaged circuit board inside the need to be replace and turn itself OFF to protect the other ones from being damaged.
A TV service tech will have to look at it to find out which boards need to be replace. There are about 7 different boards in your TV that would cause this problem.
Posted on Nov 02, 2009
Screen no longer contains all picture that should be viewable.
Check in the menu of the set to see if you inadvertently have set the screen size to a "zoom" mode. There are some sets that have fill & stretch features to make the 4:3 picture full screen and these can cause cutoff of the normal wide screen format when on those channels.
Sep 19, 2015 | Panasonic Viera TH-42PX80U Plasma TV
I cannot turn off closed caption on screen. Panasonic Viera Plasma TH 42PV60A
hi,
To exit closed caption do the following.
1. Press the menu button and select CC and press OK button.
2. In CC menu select MODE and using right arrow or left arrow button select it OFF
3. Press OK button
4. Press menu button to exit menu option.
ok
Mar 10, 2011 | Panasonic Viera TH-42PX80U Plasma TV
The direct tv menu guide is cut off around the edges...how do i fix?
Your TV resolution is not set to the proper screen size for viewing it properly and it probably cuts off your tv shows too and you just don't see it. Press the [FORMAT] or [ASPECT] button on the remote. The option available to remove the horizontal bars is Zoom.
Nov 04, 2010 | Panasonic VIERA TH-65PV500 65 in. Plasma...
CONNECTING THE SET TO MY SURROUND SOUND SYSTEM.
What surround sound system can I buy to go with my panasonic viera th-50px80u plasma tv. One where I can here sound from cable and bluray
Jul 03, 2010 | Panasonic Viera TH-50PX80U Plasma TV
Picture on screen is narrow and I cannot select normal view
use menue button on tv if this does not work change main board in tv
Jun 05, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
I want to know the perfect color settings for the th-42px80u
The Settings are :-
-Picture menu Picture mode: Custom
Picture: +80
Brightness: +60
Color: +44
Tint: -8
Sharpness: 0
Color temp: Warm
Color management: On
x.v.Color: Off
Zoom adjust: [grayed out]
-Advanced picture submenu
Video NR: On
3D Y/C filter: [grayed out]
Color matrix: [grayed out]
MPEG NR: [grayed out]
Black level: Light
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 10, 2010 | Panasonic Viera TH-42PX80U Plasma TV
The Picture appears to be zoomed in. Cannot figure out how to adjust picture to fit the television
There should be a zoom feature on your remote press that and it will take you to diffrent modes otherwise its got to be in the menu settings of the tv itself.
Thanks
Jul 18, 2009 | Panasonic Viera TH-46PZ85U Plasma TV
Panasonic viera doesn't display computer correctly
Right click onyour desktop and click properties (Windows XP) or personalize (Windows Vista).
Click the tab that says Settings(XP) or the link that says Display Settings (Vista)
Adjust your resolution by sliding the bar up or down until your dispaly matched the optimum resolution of your TV.
Dec 29, 2008 | Panasonic Viera TH-50PZ80U Plasma TV
Just bought at Panasonic TH-50PZ80U Plasma. On some channels we are getting a static type line across the top. Black and White. Any suggestions on how to get rid of it?
have you checked in the tv menu settings. check that overscan is turned on,as this will slightly zoom in to crop the error out. hope this helps!
Dec 02, 2008 | Panasonic Viera TH-50PZ80U Plasma TV
Panasonic Viera TH-42PZ80U Plasma TV Logo
365 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
