Question about Goodman Refrigerators
Goodman pc036-1b rev e wiring diagram
Specifically, I need to know where the pink, black and red wires coming from the heater coils plug into. The red wire runs from one terminal of the heater coil to one of the circuit breakers. The pink and black wires were unplugged and hanging loose when I opened the cover of the unit. I recently bought a mobile home that had this unit.
  • 159 Answers
SOURCE: Kenmore 596.75509400 bottom freezer defrost circuit test
if the thermostat is not cold enough it will be open and not allow the heater to come on. I would suggest you let the unit run for a few hours then check on the defrost cycle. in that time the terminator should close allowing the heater to work
Posted on Aug 10, 2007
  • 4 Answers
SOURCE: maytag ice dispenser wiring diagram model MSD2456GEB
apc...appliance parts center has a good web site that might get you a wiring diagram. or your local appliance supply store might.
Posted on Jul 10, 2008
  • 147 Answers
SOURCE: wireing the baseboard heater
I can help you if you still here.
Posted on Nov 06, 2008
SOURCE: GE Refrigerator Defrost heaters are shorted to ground.
My oven is turning on by itself. It will heat up to around 200 - 250 degress and shut off. I have made sure the knob is in the "OFF" position. Any ideas?
Posted on Dec 22, 2008
catriver
  • 878 Answers
SOURCE: Freezer won't defrost, coils full of ice.
Dave, you are throwing me a little here. By jumping line to defrost you should have 120 V. at the heater. J-11 to j-9. Are you measuring voltage? Lets ohm out the circuit. Unplug the refer and disconnect the blue connnector from the main board. Measure between the blue wire on the connector and the orange wire on J-7 pin 9. This is right to the right. You should have approx 22 ohms. If you don't have this the problem lies either in the heater, harness,or defrost T-stat. The Tstat sits on the evaporator, opens at 140 degtrees and closes at 110 degrees. So it should read closed. Let me know how you are doing, Catriver
Posted on Jan 29, 2009
Specifically I'm trying to identify the wire on the spark plug coil assembly to which I should connect the signal wire of a Tachometer to. The wire colours are, red, yellow, green/white, and blue.
It says the tachometer wire is Yellow/Green, you do not have that listed. You will find it in the list below, it is highlighted..
WIRING INFORMATION 2001 Subaru Legacy
WIREWIRE COLOR LOCATION
12V CONSTANT WIRE WHITE Ignition Harness
12V IGNITION WIRE GREEN Ignition Harness
12V ACCESSORY WIRE YELLOW Ignition Harness
STARTER WIRE WHITE/BLACK Ignition Harness
POWER DOOR LOCK (-) WHITE Harness In Driver's Kick Panel
POWER DOOR UNLOCK (-) GREEN/RED Harness In Driver's Kick Panel
PARKING LIGHTS (+) ORANGE At Light Switch
DOOR TRIGGER (-) PINK/BLACK In White Connector Behind Fuse Box
TRUNK TRIGGER (-) YELLOW/BLUE In White Connector Behind Fuse Box
TRUNK RELEASE (5-wire) LT.GREEN/YELLOW At Motor In Tail Gate
FACTORY ALARM ARM (-) Factory remote only
FACTORY ALARM DISARM (-) Factory remote only
TACHOMETER YELLOW/GREEN At Ignition Coil
BRAKE WIRE (+) WHITE/BLACK At Brake Pedal Switch
HORN TRIGGER (-) RED/GREEN Harness At Steering Column
LEFT FRONT WINDOW UP BLUE/RED At Driver Window Motor Inside Door
LEFT FRONT WINDOW DOWN BLUE At Driver Window Motor Inside Door
RIGHT FRONT WINDOW UP BLUE/RED Harness In Driver's Kick From Driver Door
RIGHT FRONT WINDOW DOWN BLUE Harness In Driver's Kick From Driver Door
LEFT REAR WINDOW UP BLUE/RED Harness In Driver's Kick From Driver Door
LEFT REAR WINDOW DOWN BLUE Harness In Driver's Kick From Driver Door
RIGHT REAR WINDOW UP BLUE/RED Harness In Driver's Kick From Driver Door
RIGHT REAR WINDOW DOWN BLUE Harness In Driver's Kick From Driver Door
Feb 07, 2016 | 2001 Subaru Legacy
1990 Chevy GMC Suburban alternator wiring
Well, according to my diagrams for 88-94 models, the alternator only uses the red and brown. There are pink-black wires that power some of the sensors and solenoids but should go to a fuse marked ECM in the fuse box.
Have you tried hooking up the harness without using the pink-black wire ?
Aug 28, 2012 | 1990 GMC Suburban
I have a 1984 harley sportster with a 3 wire sensor(white,black,and blue wires) that i need to hook up to my new dual fire ignition coil, and new barrel type key ignition. not sure where the wires for...
I can send you a complete wiring diagram for your Sportster. The wires you are talking about go to the stock igniton unit, the "brain box" or "black box" that is behind the triangular plate on the right side of the bike as best as I can remember (1984 was a long time ago). There should be two white wires on the coil and one is the "hot" wire and the other goes to the ignition unit. The pink wire goes to the tachometer. The blue wire goes to the opposite side of the coil from the white wire, same side as the pink wire. The black wire is a ground wire for the igntion unit most likely. But, I'm confused by you saying the wires go to a "sensor". The only sensor on the bike is in the timer cavity on the right side of the engine and the wires coming from it are different color from what you mention. Are you sure it's not simply a plug? Contact me directly at wd4ity@bellsouth.net and I'll send you the diagram. Remind me of what you need.
Steve
Jul 25, 2011 | Harley Davidson XLS 1000 Motorcycles
Where can i get a wiring diagram for my 2002 chrysler neon auto
12V CONSTANT WIRE RED and PINK/BLACK Ignition harness
12V IGNITION WIRE DARK BLUE Ignition harness
12V ACCESSORY WIRE BLACK/ORANGE Ignition harness
STARTER WIRE YELLOW Ignition harness
PARKING LIGHTS (+) BLACK/YELLOW At Headlight switch
POWER DOOR LOCK (5-wire reverse polarity) ORANGE/PURPLE Harness Coming Into Vehicle From Driver's
Door
POWER DOOR UNLOCK (5-wire reverse
polarity)
PINK/PURPLE Harness Coming Into Vehicle From Driver's
Door
DOOR TRIGGER (-) YELLOW/BLACK At Headlight Switch
DOMELIGHT SUPERVISION (-) Use door trigger
TRUNK TRIGGER (-) GRAY/BLACK At Light In Trunk
TACHOMETER WIRE TAN/BLUE or BLACK/GRAY At Ignition Coil
BRAKE WIRE (+) WHITE/BROWN At Brake Pedal Switch
HORN TRIGGER (-) BLACK/RED Harness Coming From Steering Wheel At
Column
CAUTION! SRS airbag wires are not enclosed in protective loom at the steering column. They are a twisted pair of wires that run with rest of
ignition harness. Be careful not to cut or probe these wires.
Radio:
(Black plug)
Rear Right speaker -: Blue w/White stripe
Rear Left speaker -: Brown w/Yellow stripe
Front Right +: Purple
Front Left +: Dark Green
Rear Right speaker +: Blue w/Orange Stripe
Rear Left speaker +: Brown w/Blue Stripe
Power Antenna/Amp: White
(Gray Plug)
+12v battery wire: Pink or Pink w/White Stripe
+12v Ignition wire: Red w/ White Stripe
Front Right speaker -: Blue w/ Red Stripe
Front Left speaker -: Brown w/ Red Stripe
May 03, 2011 | 2002 Dodge Neon
Wiring diagram for a 3 way ceiling pull switch.
These fans are manufactured by a number of overseas companies and sold exclusively by Home Depot. They do not have a standard color code for the fan switch. What you can do is turn off the power, keep the white neutral connected. Then using the black power wire fro the ceiling, take one of the switch wires and connect to that black, turn the power on and observe the speed .. low mark it 1, medium mark it 2, high mark it 3. Repeat untill you have identified all the speed wires. Then connect these wires to the 1,2,3, terminations of your new switch
Questions?
Please Vote !
May 29, 2010 | Hampton Bay 24750 Huntington III Ceiling...
Looking to put remote start and bypass module in 2007 saturn vue need wiring diagram
12 VOLT CONSTANT ORANGE (+) IGNITION SWITCH HARNESS STARTER YELLOW(+) IGNITION SWITCH HARNESS STARTER 2 N/A IGNITION 1 PINK(+) IGNITION SWITCH HARNESS IGNITION 2 N/A IGNITION 3 N/A ACCESSORY/HEATER BLOWER 1 ORANGE (+) IGNITION SWITCH HARNESS ACCESSORY/HEATER BLOWER 2 N/A KEYSENSE LIGHT GREEN (-) See NOTE *1 IGNITION SWITCH HARNESS PARKING LIGHTS ( - ) N/A PARKING LIGHTS ( + ) BROWN (+) @ BCM, PIN B10, GRAY 24-PIN PLUG, See NOTE *2 POWER LOCK RED/BLACK (TYPE A) @ BCM, PIN A8, 16-PIN GRAY PLUG, See NOTE *2 POWER UNLOCK ORANGE/BLACK (TYPE A) @ BCM, PIN A7, 16-PIN GRAY PLUG, See NOTE *2 LOCK MOTOR WIRE GRAY (+) IN DRIVERS DOOR HARNESS DOOR TRIGGER See NOTE *3 @ BCM, PINK 24-PIN PLUG, See NOTE *2 8957_VUE_(-) NEGATIVE DOOR PIN ISOLATION CIRCUIT.pdf DOMELIGHT SUPERVISION WHITE (-) @ BCM, PINK 24-PIN PLUG, PIN A1, See NOTE *2 TRUNK RELEASE N/A SLIDING POWER DOOR N/A HORN BLACK (-) @ BCM, PIN B2, PINK 24-PIN PLUG, See NOTE *2 TACH ANY WIRE NOT PINK or RED @ IGNITION COIL WAIT TO START LIGHT N/A BRAKE LIGHT BLUE (+) @ SWITCH ABOVE BRAKE PEDAL FACTORY ALARM DISARM DISARMS with FACTORY REMOTE ONLY ANTI-THEFT YELLOW (+), ORANGE/BLACK (-) and RED/WHITE (Not used) GM's PASSLOCK 2 System, these wires exit the Ignition Switch Tumbler together and are in the Main Ignition Switch Harness in the Column.
Feb 27, 2010 | 2007 Saturn VUE FWD 4
My heater is not running no ignition
your polarity wires need to be reversed the main wires coming into the unit are either black going to black white going to white changed the wires around to black going to white and white going to black that should solve your problem
Nov 04, 2008 | Goodman GMS90703BXA Heater
Need a wiring diagram for distributor for a 1988 pontiac fiero gt with a 2.8 v6
There are two plugs which are plugged into the distributor one is a two wire  and one is a four wire. the two wire has a pink wire on terminal A and a white wire on terminal B these two wires go to the remote coil  black plug The four wire has a black wire with a red trace on terminal A A tan with black trace on terminal B A purple with white trace on terminal C A white wire on terminal D
Aug 09, 2008 | 1988 Pontiac Fiero
Goodman GMP100-5 Rev Furnace Manual
I don't know where you are located, but there is a Goodman distributor in Sacramento, CA. Also in Ontario CA. They are a distributor so they may be able to help you or tell where to find someone who will help. Goodman is also known as GMC or Janitrol.
Jan 07, 2008 | Goodman GMS90703BXA Heater
Refrigerators Logo
154 people viewed this question
Top Goodman Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
Are you a Goodman Refrigerator Expert? Answer questions, earn points and help others
