Question about HP LaserJet M3035 MFP Printer
How to get print count off of an HPLJ3035MFP - HP LaserJet M3035 MFP Printer
    President:
  • 643 Answers
Usage page
Shows a page count for each size of
paper printed, the number of one-sided
(simplexed) or two-sided (duplexed)
pages, and the average percentage of
coverage.
1. From the Home screen, touch Administration.
2. Touch Information.
3. Touch Configuration/Status Pages.
4. Touch Usage Page.
5. Touch Print.
Posted on Nov 30, 2012
Hp Laserjet P2055d-Page Counts error
are you looking at the pages printed on the toner cart. print out the supplies page.
Jul 28, 2017 | HP Office Equipment & Supplies
Tip
How to get the page count on a Ricoh Aficio copier
On Ricoh's Aficio line of copiers, you can get the page count without having to print out a configuration page or status page. To see the page count of an Aficio copier, follow the steps below.
For models with touch screens:
With the copier turned on, press the User Tools/Counter button on the operation panel. (If User Tools and Counter are two separate buttons on the model you are using, press the Counter button, and the page count will be displayed -- that's all there is to it.) When the User Tools menu appears on the screen, press the Counter button on-screen (typically located in the lower left or lower right corner).
The copier's page count will be displayed on the screen. For copiers with additional functions (such as printing) the page count will also be broken down by function. Color copiers will display a color page count and a black and white page count, but not a total count.
You can print out a hard copy of the page count if you want it for your records, or to fax somewhere. To print the counter, press the Print button on the screen, then press the Start button (on the right side of the operation panel).
For models without a touch screen:
With the copier turned on, press the User Tools/Counter button on the operation panel (typically located just to the left or right of the display screen). The User Tools options will appear. If Counter is the highlighted option, press the OK button to select it; otherwise, use the arrow buttons to select Counter, then press OK.
The counter will be displayed on screen, but you can print it out by pressing the selection button below where Print is displayed, then pressing Start.
on Jun 13, 2011 | Office Equipment & Supplies
The ribbon will only print red ink
While in the D position or PD position, N Count
is OFF. In the N Count N position every
Plus, Minus, Equals Plus, Equals Minus,
Memory Plus or Memory Minus key depression
is counted. The Accumulator and its N Count
or the GT N Count can be printed by
depression of the Subtotal or Total key. When
either Memory Subtotal or Memory Total is
depressed, Memory N Count will print. N Count
is always printed in red, left justified. If the
Equals key is depressed immediately after the
Subtotal Total, Memory Subtotal, or Memory
Total the average of the entries is printed.
When the N Count prints on the 7150, an audit
symbol will print to the left of the N Count.
The audit NA will identify the Accumulator
register N Count, NG will identify the GT
register N Count and NM will identify the
Memory N Count.
Apr 23, 2012 | Monroe 7130 Calculator
How do I print the total amount on my ticker tape of what I've added? I pressed the equals sign but that didn't work.
OFF • P P•IC
ON POWER SWITCH; PRINT / ITEM COUNT MODE SELECTOR:
"OFF": Power OFF
"•": Power ON. Set to the non print mode.
"P": Power ON. Set to the print mode.
"P•IC": Power ON. Set to the print and item count mode.
1) For addition or subtraction, each time is pressed, 1 is added to the item
counter, and each time is pressed, 1 is subtracted.
• The count is printed when the calculated result is obtained.
• Pressing of , clears the counter.
2) When the grand total/rate setting mode selector is in the ON position (GT), the
counter will count the number of times that the calculation results have been
stored in the grand total memory. To print and clear the count, press the key.
3) The memory item counter will count the number of times that the key has
been pressed in the addition.
Note: • Each time the key is used in the subtraction, 1 will be subtracted from
the count.
• The count is printed when the memory is recalled.
• Pressing of the key clears the counter.
Note: The counter has a maximum capacity of 3 digits (up to ±999). If the count exceeds
the maximum, the counter will recount from zero.
Dec 17, 2010 | Sharp EL-1801P Calculator
Need to know how to get a page count from an ricoh aficio 1022. i hear you can get it from the config page but how do i print out a config page? help!
Press the usertools key then select counter on the display. You will then see the counts. You can also print the counts from this screen by pressing print on the display screen then press the print button.
Jun 30, 2010 | Ricoh Aficio 1022 All-In-One Laser Printer
Konica Minolta Pagepro 1350 page count or Print Config sheet?
please go printer utilty option on your pc then you can print a testpage
Feb 10, 2010 | Konica Minolta PagePro 1350W Laser Printer
How do I get a meter reading of number of copies?
Here you go.
  1. Press the [Reports] button on the Control Panel
  2. Press the [Up] or [Down] arrow until 'Systems Data' is displayed on the Display Screen.
  3. Press the [Enter] button.
    The System Data list will be printed with the following information:
    • Total Page Counts: Total number of pages printed
    • CRU Prints: Number of pages printed using the current Toner (Dry Ink) Cartridge
    • Replaced Toner Counts: Number of new Toner Cartridges installed in the machine
    • Replaced Drum Counts: Number of new Drum Cartridges installed in the machine
    • Current Drum Page Counts: Number of pages printed using the current Drum Cartridge
    • Platen Scan Page Counts: Number of pages scanned using the Document Glass
    • ADF Scan Page Counts: Number of pages scanned using the Automatic Document Feeder (ADF)
Feb 10, 2010 | Xerox WorkCentre M15i Laser Printer
I wish to read the total copy count on Xerox WorkCentre M15i
You have to print out the meter report.
Apr 19, 2009 | Xerox WorkCentre M15i Laser Printer
Print count setting
If this is a hewlett packard printer then you need the manual to do that. You can log on to hp.com and get all the information you need.
Jan 12, 2009 | HP LaserJet 2840 Printer
My hp 1320 prints multiple copies instead of one copy
Go to "printers and faxes."
Right click on your printer and select "Printing preferences."
Select "Advanced" tab
Double click "paper output"
If "Copy count=2" then change to 1 and apply
IF IT ALREADY IS SET TO 1 THEN:
Set "copy count=2" then APPLY
Repeat the above and now set "copy count=1"
The process of setting and resetting the copy count fixed my issues.
Dec 03, 2008 | HP LaserJet 1320 Printer
HP LaserJet M3035 MFP Printer Logo
111 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
