Question about Gateway ZX4250-UB30P All-in-One AMD Fusion Dual-Core E-300 1.3GHz 2GB
How to disable the realistic card reader in gateway zx4250
I would like to disable the card reader, but I don't know how to do it
  • 564 Answers
If you go to device manager and look under disk drives you should see your hard drive and card reader. If you right click on card reader you can disable it.
Posted on Dec 01, 2012
2 Suggested Answers
Gateway desktop can't read a sdhc 32gb memory card
well it should read it unless the reader is incapable of reading cards of that capacity.. Are you sure the card is good ? try it on another reader..
A firmware update wont be of any help there since the capacity is HARDWARE not software. If the card is good you will need to replace the reader to a newer model or acquire and external card reader.
Dec 29, 2012 | Gateway Computers & Internet
Does anyone have suggestion for gettinv on the internet. I was able to till last week. Reg clean pro installed itself and ive been having problems since. I Lso uninstalled realtek USB 2.0 card reader and...
do you have the cd to the usb card reader that you can reinstall?
you don't say which windows you have, have you tried going to
control panel & uninstall programs folder & see if the REG CLEAN
PRO is there & delete it, if it's not there go to search & type in the
name reg clean pro & see if that program can find it & try to delete
it there.
May 28, 2012 | Google Computers & Internet
SD Card Reader
it might be a hardware problem,just don't try to push your card too hard into the reader, just slightly place it in reader.
Or it might be your Card is Currupt.Have you tried to insert any other card ?
Feb 08, 2012 | Gateway MX6442 Notebook
How do I upgrade my ram on my Gateway All in one zx4250?
I too purchased a Gateway ZX4250 and a 4 GB RAM upgrade kit. It took me awhile to figure out how to open the case. Here is what I found.
1) Remove the two rubber pads at the bottom of the case (don't worry they pop right back on).
2) Open the small back cover.
3) Remove the one screw.
*****CAREFUL****
4) This part is a little difficult but just be careful not to use too much force. Take two small flat head screwdrivers and slowly separate the plastic silver front panel from the plastic black back panel. Start at the bottom where the two rubber pads were removed. Work your way around the case, you can see how the clips are connecting the two panels as you work your way around the all-in-one. It shouldn't be too hard just be careful on how much force you use.
5) Once the panels are separated you can now access the hard drive, optical drive and some other components.
6) Disconnect the Hard drive sata cable from the motherboard.
7) Disconnect the other cable right next to the sata cable on the motherboard (I'm not sure as to the purpose of this cable.
8) Remove the screws from the metal plate covering the motherboard. Take careful note that a grounding cable is connected to one screw.
9) Install your RAM.
10) Reverse the procedure to put everything back together.
This whole procedure to upgrade my RAM took about 15 minutes. I hope this helps some of you that are trying to upgrade your RAM. If you have any questions PM me.
Jan 03, 2012 | Gateway ZX493131e Notebook
My canon A480 powershot has hundreds of pics on it. I went to look at them this morning and now only 14 remain .. how can i get them back .. ??
Jessica, this occurred because you didn't intitially format the card in the camera when you first got it. It will work fine at first, but eventually what you experienced will happen. But you don't want to format your card just yet as it will erase it.
Instead, to recover your photos, you'll need to use a card reader with your computer to see if the files can be copied directly and saved to your computer. If you don't already have a reader, don't fret as they are very inexpensive. For example, here's one that I use that is very good. You may also purchase card readers at your local store, such as W or K mart, but they may be a bit more expensive at brick and mortar stores. With the card reader, you insert the card into the reader, then insert the reader into your USB port. The card then shows up as a hard drive, that you can copy and paste the missing photos from onto your computer. Also recommend using the reader in the future to download your photos from your camera, as it is very fast and relatively error free.
Now if by chance your photos still don't show up with the reader, don't fret as they're still there on the card. You'll just need to use recovery software with your reader to get them. It's very easy, here's a listing of very good freeware for that purpose.
Finally AFTER you've recovered your photos, format the card IN YOUR CAMERA using the camera's format feature. This will rejuvenate the card so it will be good as new, but it will also erase it. So again, only do this AFTER you've recovered the photos.
Good Luck!
Jun 26, 2011 | Canon PowerShot A480 Digital Camera
I have a cisnet c133-s33. I have no signal to the monitor.Pluged monitor into another computer and it works.I install a Diablotek varx-8p ati rage xl 8mb video card but still have no signal.Do I need to...
You can try clearing the BIOS & if you don't know how, don't do it!! I doubt it would help anyway. That's an old, off brand pc, good chance the motherboard is bad.
Apr 29, 2011 | Computers & Internet
I am trying to troubleshoot a video issue, I replaced the video card, I receded memory, etc, no video. How do I tell the BIOS to look at another video card instead of the on-board?
once the card is install u have to disable the onboard video by going into systems than device manager click on video and disable the intergrated video
May 03, 2010 | Gateway GT5058 Desktop PC
Gateway ZX4250-UB30P All-in-One AMD Fusion Dual-Core E-300 1.3GHz 2GB Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
