I have a model atw4475vq1 that will not complete the filling process seems to leak out the drain line never allowing it to get to the fill sensor
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
Be sure the drain line is above the tub level.
Posted on Nov 30, 2012
  • 99 Answers
SOURCE: WHirlpool Waser model LSR8133HQ0 - tries to fill for rinse cycle
hellow my name is joyce and It sounds like you have a issue with your cut off valve that controls the water flow to your machine in between cycles, this is controled by your timer switch you may want to call technichian to repair. sounds like the only problem you have with the timer is on the rinse cycle not the wash cycle, but it defently needs to be fixed. if I can help you find a repair person please let me know.
thanks you and let me know if I can further assist you.
joyce
Posted on Feb 06, 2009
SOURCE: water leaking from underneath after washer drains
I have the same washer and there is a white plastic piece underneath the washer where two hoses go into. It contains the impeller that pumps the water out. Anyway, on my machine this piece was incorrectly injection molded at the factory. The glue bubbled out causing an air bubble -- once the air bubble in the glue can stand the pressure and pops, the leak occurs!!!!! If you are a handyperson, take this piece out and use exopy to fix.
Posted on Mar 30, 2008
barkencoa
  • 3463 Answers
SOURCE: Will not run wash properly
The sensor you are referring to could posslbly be the water level switch which controlls the level of water,and also. is a factor as to wether the washer will spin or not, it also is part of the heater circuit, so it has numerous functions.
I t can be found at the top right front of the washer, and is about 3" in diameter, and has a thin plastic tube going to it.
it could be sticking, there is no sure fire way of testing it properly, but you could try tapping it and blowing down the tube, it may solve the prob.
Hope this helps.
Plz rate my solution.
Thanks.
Posted on Jan 04, 2009
Healeyman
  • 1198 Answers
SOURCE: Water leaks when filling
Use a putty knife at the top front corners to release the spring catches. Lift up the top. Examine the plastic thing that delivers the water to the tub, it may be cracked or out of place.
Posted on Apr 27, 2009
  • 10 Answers
SOURCE: Kenmore washer won't stop filling during initial wash cycle
I had the same problem too on one of my washers (not kenmore) it didn't complete cycle because someone turned off the hot water valve. soo i turned on the hot water and it worked fine. keep in mind that mine wasn't a kenmore. hope this helps some...
Posted on Oct 08, 2009
How do i install my power steering return line
With the engine cold, loosen the steering reservoir filler cap to allow air into tank. Take the lowest fitting loose and let it drain into a bucket under the vehicle. When finished draining remove Line fitting at reservoir. Remove any brackets holding the line in place and remove line from vehicle. Take the line to automotive supply and buy proper replacement using old line to verify fit. Purchase enough recommended power steering fluid to replace what drained into bucket. Install new line in reverse of removal steps making sure seals (washers and/or "O" rings) are properly installed. Dispose of old fluid safely.
To fill reservoir and line: While filling reservoir with engine running turn steering wheel from left to right until wheel stops. Continue filling and turning until all air is out of system and reservoir is at the proper fill level. Check for leaks.
Mar 23, 2015 | 1988 Cadillac Eldorado
Why is my countertop dishwasher stuck in drain mode(s), and won't initiate or complete any wash cycle?
normally if a dishwasher fills then pauses it is trying to read the water level if it fills again it is trying get a reading from the pressure switch when it cant determine the water level it will drain to prevent it leaking, however you should get a error code for this kind of fault which makes me think it is the control board which is at fault by not being able to read the sensor rather than the sensor itself not working
Oct 08, 2014 | Dishwashers
How to bleed the radiator on a peugeot 2006 307 XS model
B1GG0RK1 - 206 TU ENGINE DW8 ENGINE
DRAINING - FILLING - BLEEDING COOLING SYSTEM
1 - SPECIAL TOOLS
b1gk06lc.gif[1] filling cylinder (-).0173/2 .
2 - DRAINING
TU ENGINE
b1gk070c.gifDW8 ENGINE
b1gk073c.gifALL MODELS
Carefully remove the expansion chamber cap .
b1gk06kc.gifUnscrew the radiator drain plug (1) .
NOTE : fit a pipe to the outlet to allow clean drainage of the system .
TU ENGINE
b1gk071c.gifDW8 ENGINE
b1gk074c.gifALL MODELS
Open the bleed screws (2) .
DW8 ENGINE
b1gk075c.gifDrain the engine by removing the plug (3) .
ALL MODELS
3 - FILLING AND BLEEDING THE SYSTEM
Before any re-filling operation, flush the cooling circuit with clean water .
WARNING : check the cooling system for leaks .
DW8 ENGINE
b1gk076c.gifTU ENGINE
b1gk072c.gifALL MODELS
Fit the filling cylinder [1] to the filler opening .
Open all the bleed screws .
Fill the circuit slowly with coolant .
Close the bleed screws in the order in which the liquid flows without bubbles .
The filling cylinder must be filled to the 1 litre mark to bleed the heater matrix correctly .
Start the engine .
Maintain the engine speed at 1500 to 2000 rpm until the end of the second cooling cycle (fan(s) starting then stopping) keeping the filling cylinder filled to the 1 litre mark .
Stop the engine .
Remove the filling cylinder [1] .
Immediately tighten the plug on the expansion chamber .
If necessary fill up to the level of the maximum mark (Engine cold) .
Jul 06, 2014 | Cars & Trucks
Washer will fill up and drain but nothing else
What is the complete model number of your unit?
Dec 07, 2012 | Washing Machines
Machine seems to fill with water when not in use
This often is a drain hose that is too low or a drain hose that has been pushed too far down inside the stand pipe....the water is actually siphoning out of the washer. Do not "seal" the drain hose to the house plumbing pipe, this will also allow the water to be siphoned out.If drain hose is checked ok then its confirmed problem of faulty water fill valve.
the fill valve is leaking. When they go bad they can leak water without being told to by the timer. I would replace the fill valve after pulling the hose off the fill end and watching to see if water drips out.
For getting parts you can get it from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 10, 2010 | Bosch Axxis WFL2090UC
Freezer drain line and upper drain pan freezes up regularly.
sounds like your fill tube is leaking
you should be able to pull it out from the back of the machine
to inspect it
if the fill tab on the tube is facing in any other direction than down it should be straight down
Oct 09, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Isuzu axiom 2003
there is no dipstick or filling ports in the engine bay. underneath the car near the valve boby pan there are 2 bolts, one for draining the trans., and one for filling the trans. this is not the easiest of repairs and it is quite messy. drop cloths or some kind of catch would be wise. first drain the pan by removing the lower bolt. allow the fluid to completely drain and reinsert bolt. next remove the larger (valve body) pan. there is a filter that you will see is held in place by 3 bolts, remove filter and replace with new one. clean mating surfaces of all debris and fluids. next apply the gasket to the pan you just removed and cleaned. fill the empty pan with about 3-4 quarts of new ATF. a second pair of hands here is recommended. together realign pan to trans. careful not to spill fluid! apply a few bolts to allow for free hands. insert all bolts DO NOT OVER TIGHTEN BOLTS! this is very important, only tighten bolts until gasket just starts to squish. over tighten and you risk a new leak.
now the messy pain in the **** part. in oder to check fluid level, you need to have car parked on level ground. remove the upper bolt from the pan you just reapplied. You will need some sort of pump and a few feet of hose to complete the filling process. fill until fluid runs back out the hole, quickly insert bolt, tighten to specs. and wipe exterior of pan to see for any new leaks.
this should solve any trans. slips do to ATF seepage.
best of luck
Feb 21, 2009 | 2002 Isuzu Axiom
KitchenAid Dishwasher fill up with water after use
Is the water clean water or dirty water? This may sound like an ignorant question, but it can make a difference. If the water is clean water, it sounds like you could have a bad fill valve. If the dishwasher is filling with water when it is not running, chances are the fill valve is leaking. The valve is closed when the float switch senses the tub filling to a certain level. The valve is also closed when not energized by the control board during drain, drying and off cycles. However, if the valve diaphragm is not seating properly when closed, it will continue to leak by. That's probably why you don't notice it while is running and it has a chance to fill during the night when not in use. Here's what to look for: With the dishwasher off, take a towel and dry the tub as much as possible. Now, locate the fill port where the water comes in (usually on the left hand side of the tub). Watch this fill port closely for several minutes to see if water is running in. It could be as minute as a trickle or drip. If any water is coming in at all, the fill valve should be replaced. Now, another problem that can occur is when you notice dirty water staying in the tub or overflowing. This is usually caused by a bad check valve in the drain pump that's allowing water to leak back from the sink into the tub. Or, you do not have a high loop in the drain line. Here's what to look for: Check to make sure the drain line has a high loop as it leaves the dishwasher and before it gets to the drain pipe at the sink. That is, make sure the drain hose is looped above the trap in the sink and not laying under the sink somewhere. You can also try filling the sink with water and open the dishwasher door. Drain the sink to see if anything is getting fed back into dishwasher. If you see water starting to fill in the tub, chances are you could have a bad check valve. Some dishwashers have a check valve in the drain pump, while other models have the check valve located in the drain hose itself. Some don't have one at all. That's why the positioning of the drain hose can be important. Good luck to you and I hope this may help. If you determine a cause, post back with comments if you need advice on how to replace anything.
Sep 22, 2007 | KitchenAid 24 in. KUDS25 Built-in...
Will not advance from fill cycle
Check your drain hose to make sure you have not sealed the top of the standpipe (drain line), or shoved your drain hose too far down in the pipe. If you do not allow for an air gap, your washer will fill and begin to siphon through the drain line. It is common for folks to seal the standpipe or shove the drain hose down in the line too far in the belief that it will prevent overflows, or get rid of that nasty drain smell. This can be bad because it does not allow for the proper air gap to keep the water from being siphoned right out of the machine. You may have a tight fitting that doesn't siphon every time which may explain why the problem doesn't occur all the time. Double check to make sure. Hope this helps.
Jun 14, 2007 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
