Question about Olympus FE-210 Digital Camera
Hi..i can not transfer my pictures to my pc. i am having a hardtime using the mtp device. what should i do?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Olympus Master
  • 102,366 Answers
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Posted on Oct 07, 2012
Tried connecting the GT-T9500 to a Lenovo (2011 Windows 7 laptop). Nothing happens. What needs to be done to transfer files from the phone to laptop. Thank you!
In your android device You should go to "Settings" then "USB computer connection" and here you can choose a mode in what your device is connecting to a PC "Media device/MTP", "Camera/PTP", or only charging mode.
You should switch to MTP mode.
Mar 19, 2015 | Samsung GALAXY S4
How do i transfer pictures from samsung sgh-s425g phone to laptop computer
Set your device to MTP mode in the USB settings. It will then act like a camera or media device so you can transfer items to and from your phone.
Sep 13, 2014 | Samsung SGH Cell Phones
What is msc mode?
MSC stands for Mass Storage Class. Used in connection with USB connected devices. Full term is USB MSC. Its a protocol used to transfer files between a USB device and a computer. MTP Media Transfer Protocol is the modern equivalent. Some devices like for example the Garmin Sat Nav default to this latter protocol when connected to a PC.
Dec 21, 2013 | Audio Players & Recorders
Mtp device
MTP is the protocol used by android to transfer data back and forth to your PC. It is nothing to be concerned about, and the setting can be left on all the time.
Nov 21, 2013 | Nokia C7 (8 GB) Smartphone
I need driver called mtp usb device for my c2-03 mobile
Many devices use Microsoft's Media Transfer Protocol to synchronize with computers. Unlike standard USB mass storage devices, MTP devices don't behave like USB flash drives. Windows Media Player includes built-in support for MTP devices and can synchronize media files to and from them. You can download MP3s to your portable music player, cellphone or other MTP device using Windows Media Player's sync feature. The device appears in Windows Media Player when you connect it to your computer.
Read more: How to Download a MP3 to MTP ' eHow.com http://www.ehow.com/how_12186594_download-mp3-mtp.html#ixzz1wFmzrcvt
May 29, 2012 | Nokia C203
Not enough space
You should have your Sansa player set to MTP (Media Transfer Protocol) when you are using it with any of the supported subscription (ie) iTunes, or Rhapsody music services. The main purpose of MTP is to transfer media files and associated metadata to/from devices, with optional additional support for reading and setting of device parameters such as special DRM-related device parameters for restricted content. Otherwise, you should set it to MSC (Mass Storage Class), which is the normal USB mode for storage devices like thumb drives, and camara SD memory cards.
See this tip posted here Tips on MP3 connection problems..
MTP stands for Media Transfer Protocol. It is a Microsoft standard and is Microsoft's solution to connecting MP3 players and cameras to a w*ndow based Computer. MTP mode must be used in order to transfer ANY Digital Rights Management (DRM) protected content. MP3's downloaded form services like Rhapsody and Napster will only function in this MTP mode. Things to do if you are getting not enough space mesage.
1. Turn device OFF. 2. Facing the hold switch slide it to the right so an orange color would show putting the device on Hold. 3. Connect the device to the PC.
If you added songs to the device in MSC mode, then you switched to MTP mode, you will not be able to see the songs added in MSC mode and vice versa, though the space used on the player will still reflect their presence. Switching modes should make the files show up. For example, switching back to MSC or MTP mode.
For older players - e200v1, c200v1, c100, m200 - the files become hidden files if the modes are switched. An easy workaround is to edit the folder options to show hidden files.
STEP 1 - Edit the folder options of the computer to show the hidden files
Windows XP: 1. Double-click My Computer. 2. Under the Tools menu, select Folder options, then click the View tab. 3. Under Hidden files and folders option, select Show hidden files and folders. 4. Uncheck the Hide protected operating system files (Recommended) check box. 5. Click Apply, then click OK.
Windows Vista: 1. Double-click Computer. 2. Click the Organize button on the upper left corner. 3. Click Folder and search options. 4. Click the View tab and select Show hidden files and folders. 5. Uncheck the Hide protected operating system files check box. 6. Click Apply, then click OK.
SOLUTION 2 - Perform a Check Disk.
STEP 1 - Switch to MSC mode 1. On your Sansa player, switch the USB mode to MSC. 2. Connect the Sansa player to the PC.
STEP 2 - Perform Check Disk 1. Locate the Sansa player under My Computer. 2. Right-click the removable drive associated with the Sansa player, and select Properties. 3. Click the Tools tab, and then click Check now. 4. Click to select the Automatically fix the file system errors and Scan for and attempt recovery of bad sectors check boxes. 5. Click Start.
SOLUTION 3 - Format the player in MSC mode or MTP mode.
Jan 16, 2011 | SanDisk Sansa m240 MP3 Player
What are the steps to download photos from phone to computer?
If you're using an Android phone, that's easy! First, connect your phone to computer, then select the MTP or PTP mode on your phone. Then you can transfer files between phone and computer casually.
If you're using an iPhone, you will need some tool. Like iTunes, iCloud, FonePaw iOS Trasnfer etc which can help you transfer files between iPhone and computer.
First download the program, and connect your device as well as the Android phone. Then select the files you want to transfer and that's OK. The steps to download photos from phone to computer is easy.
Nov 11, 2010 | Computers & Internet
Problem to transfere recordings from sansa express to computer
the same problem with my sansa mp3 player is is showing me an mtp device but could not find any folder in pc
Nov 23, 2009 | SanDisk Sansa MP3 Player
MTP
Hi I am having a problem to with the MTP device. Bottom right corner of my screen has the window that says found new hardware...MTP device. I can not close out the window because it keeps coming back. Then I hear this like bubble sound when it's on the screen. Any suggestions? I think its for my new phone that I downloaded on the laptop. I am going to uninstall it and reinstall it and see what happens. Any other suggestions please let me know thanks...
May 02, 2007 | Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player
Olympus FE-210 Digital Camera Logo
41 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
