Question about Kitchen Ranges
Cant set timer to allow top and bottom gas oven to work used to be able to press reset button then would work but no longer
Timer stays on 0000 cant set auto is staying on
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 30, 2012
catriver
  • 878 Answers
SOURCE: Digital Control (for oven temp and clock adjustment) not working
Puzzeled, usually when there is a stuck or shorted keypad there will be an error code. First let's see if we can tell if we are in Centigrade or Ferenhiet. Press the bake and broil button together for 2 or 3 seconds. SF should appear in the display. Press the broil pad again and C or F will be displayed. Toggle to F and press start. See if that was the problem. If not try to increase the speed of the + and - keypads. Press bake and broil together for 2 seconds until SF displays. Press the + keypad increase the speed of the control. It should toggle from 1 to 5, 5 being the fastest. Press start and see if that works. If niether works..then have someone remove the keypad ribbon cable from the control board and clean the ends with an eraser. See if that solves the issue...Catriver..post back and let me know.
Posted on May 12, 2007
SOURCE: Westinghouse 808 freestyle
try holding the time (first button from left) and button beside together then the + or -
hope it works good luck.
Posted on Oct 07, 2008
  • 15 Answers
SOURCE: caloric gas stove prestige series
to jenna 12 Does your stove have a stop and start timer? When you set your clock you may have inadvertantly moved the stop or start time on that timer. Check them, if they have knobs for setting the stop and start time, make sure the pointer is pointing to the current time and that the knob is popped out and not stuck in. when you have it right both the stop and the start knob should be out, not pushed in. They will pop out when you turn them to the current time.
These timers allow you to start something cookin at a time delayed several hours. this means they will not allow the oven to come on until it hits that time that you may have set in error.
If your stove has a digital stop and start timer check each one so that both show the current time, then your oven should light.
  • 23 Answers
SOURCE: The oven of GE Profile range simply stopped igniting
If it is a ge it would have a glow bar ignitor, either a flat rectangle shaped or a round ignitor. That is want the problem is 95% of the time. It is pretty easy to do. The floor of the stove will come right out and it probably has two screws in the back corners you can see. Remove them and the floor will lift out and you can see the burner and the ignitor.
Posted on Jun 20, 2009
SOURCE: LP gas conversion oven flame to big
I did all this and the flames are still huge inside the oven...
Posted on Nov 27, 2009
I have a GE sensor microwave oven. Tried to heat food and sensor eror came on. Everything is running even the timer but no sound but the timer is running. Cant this be reset pls help
HELLO.
This is the solution to reset your microwave.
1 Pressing the clock button will display the time. You can also use this to know what time it is while cooking.
1. Set the clock by pressing the "Clock" button.
2. Turning the dial on the GE sensor microwave oven will display the hour of the day. Once you have found the correct hour, press the dial in.
3. Again, turn the dial to set the minutes of the day. When this is completed, you will need to press the dial in again on the GE sensor microwave oven.
4. When the time and minutes are set, turn the dial again for a.m. or p.m. Then you will need to press the dial in to save the settings.
5. Press the "Start" button to allow the clock to begin on the GE sensor microwave oven.
Thanks.
Sep 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a zanussi gas cooker with electronic timer and i want to know if I can reset it as the automatic function has been started and I can't get the unit to do anything now?
if a 3 button timer press the centre button once, then press the - (minus) until the display reads 0000. leave for 10 secs till time of day returns. it should work now. if not this type include the model no and ill give correct instruction.
Aug 06, 2010 | Ovens
AEG single oven - clock runs for 12 hrs , buzzes and goes back to 12 o'clock - if set timer and check time remaining, it buzzes and jumps to clock setting loosing time remaining. Buzzer sounds ''hoarse''.
you must setting the count down timer instead of time of day. to set time of day. press centre button 4 times lamp flashes in bottom righthand of display. use + and - to get correct time after 10 secs time will lock in. to check you have not set count down press centre button 3 times lamp flashes top right corner of display if not at 0000 use - button to get to 0000 leave 10 secs then should revert to time of day. also check you have not entered cooking time. press centre 1x this also should read 0000. hope this helps
Jul 17, 2010 | AEG B2100-4 Electric Single Oven
Kleenmaid scala oven how to reset the timer buttons oven keeps
Press the cook and finish cook buttons at the same and +and- button to advance the time. They look like a casserole dish and a casserole dish with a cross through it
Apr 13, 2010 | Ovens
I have lost my manual for a Simpson Appolo Atlas Stove
call manufactuerer and ask if you can order one or try to do so online
Dec 22, 2009 | Stoves EC500DOA Electric Kitchen Range
Just brought a bosch oven and there no life in the bottom oven
If it has a timer, then make sure it is set manual and not auto, or the oven will not work.
Try pressing 2 buttons at the left of timer and one button on right of timer to set it to manual, if it does not work this way, then try another combination of buttons.
Hope this helps.
Plz rate my solution.
Thanks.
Jan 03, 2009 | Bosch HBL 435 Stainless Steel Electric...
Westinghouse 745 wall oven
First thing, remove the plug from the wall power for at least 10 minutes, maybe even thirty minutes and allow it to reset........ if that does not work write me at wbwill@sbcglobal.net and give more model info so I can investigate for you or check out a volunteer site, allexperts.com and you will find me there also.
Nov 10, 2008 | Ovens
Caloric gas stove prestige series
Oct 13, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
