Question about TDK WR700 Wireless Headphones
TDK WR700 Audio automatic Cut out
Hi I have a pair of TDK WR700 headphone which I use for metaldetecting , the phones have a 2 mins audio cut out, as I run my metal detector in the quiet mode I am forever turning them back on, is there a mod to by pass the auto cut out. Cheers Jon
I WANT TO CONNECT HEADPHONES TO 1/4 INCH PHONE JACK ON TECHNICS AMPLIFIER IN A WAY THAT WILL CUT OFF SPEAKERS SO THAT AUDIO IS SOLELY THROUGH THE HEADPHONE. HOW DO I WIRE THIS USING THE PHONE JACK ON THE...
Please plug/ connect this wireless headphone base unit in Line Out jacks at back of amplifier to get sound in headphone and turn down amplifier volume control to shut off its speaker sound.
Thanks.
Aug 11, 2011 | Technics DJ Headphones
I just recently got a pair of Audio-Technica ATH-ANC27 headphones and I've noticed that when I touch the detachable cable the sound shorts out and plays through one side of the headphones.
There is a wire in the detachable cable that is broken inside so might have to cut and rejoin the broken part.Thats why when you touch the detachable cable you happen to move the wire so sound is only transmitted to one ear phone only.
Thanks and good luck
G.
Aug 04, 2011 | Audio Technica Audio-Technica ATH-ANC27...
Ive a problem with the volume of the headphones, the right one works fine but there is no sound from the left side....ive tested the headphones on other electronic equipment and the headphones work the...
Hi,,in most cases what causes one side of the headphone to work is because, the wire that is connected to speaker inside the headphone might have cut and it's not contacting properly.
What you will need to do is to open up the head phone (left),and check if the wire inside has not cut, If it has removed ,then you will need to put it back with soldering iron and a lead...
But if the wire inside has not removed and they are intact, then you will have to replace the left speaker .
Hope that helps...
Thanks for using fixya...
Nov 08, 2010 | Audio Players & Recorders
Sound
Except for the Headphone jack (mini-jack) and the coax audio, all of the audio jacks are audio IN. Which jack do you have your speakers connected to? The headphone jack is on the side next to the coax connection (ANT) and the coax audio out is at the bottom of that set of side jacks. The headphone mode should automatically cut the TV speakers. The coax audio out is set up by pressing Menu and then using the down arrow to highlight Audio. Then press the right arrow button to enter the submenu. Press the up or down arrow to reach SPDIF. Then you use the left and right menus to select PCM, Digital Dolby or OFF.
I hope this helps.
Jul 10, 2010 | Element ELC-HS321 32 in. LCD TV
When I plug in my headphones the sound is not re-routed through the headphones. It is still audible in the room.
It does not look like you have the switchable headphone connector that you can use a pair of headphones and will cut the audio to the tv speaker out.If you are using the audio out connectors in the rear of the tv all you can do is lower the tv volume when you are using the headphones(fixed audio)
Jan 14, 2010 | Dynex DX-L15-10A 15 in. HD-Ready LCD TV
Can't pair TDK BT-100 headphones to my Iphone
I managed to pair the device after plugging the bluetooth headset into the USB power slot. Then I press the main button for 5 secs until the red light started flashing very rapidly and I typed in 0000 and the headset paired off with my Iphone. Good luck
Aug 19, 2009 | TDK Audio Players & Recorders
Audio output from my TV
take a red and white audio rca cable and cut off one end of the jacks. on the end you cut, solder a headphone output plug on. can also solder on the lines of a pair of headphones (where you've cut off the 1/8 in jack) directly to the rcv jacks.
Nov 07, 2008 | RCA Personal MP3/CD Player
Garmin GPS - suddenly has no sound - it just cut out
1. Are you sure the volume setting is all the way up?
2. Are you sure the sound isn't muted?
3. Have you tried a pair of headphones in the headphone jack? If the headphones have sound, your internal speaker is bad. If you don't feel like sending it back for repair, you can purchase a FM transmitter like those used on IPODs and CDplayers and plug into your GPS's headphone jack and play the audio through your car's FM stereo.
4. If you don't hear sound from the headphone jack, most likely the audio output section is defective and you'll need to send it back to Garmin to be repaired.
Please let me know if I can be of further assistance to you.
- Jim
Mar 17, 2008 | Garmin Nuvi 660 GPS Receiver
Using headphones with Logitech X-230 speakers
I really don't know, because some of the newer gadgets come with fixed volume control due to law suits, ect. Try to see if you can bring you TV menu up and see what the sound setting is.
Dec 25, 2007 | Logitech X-230 Computer Speakers
TDK WR700 Wireless Headphones Logo
44 people viewed this question
Top TDK Audio Players & Recorders Experts
Josh Whitehead
Josh Whitehead
Are you a TDK Audio Player and Recorder Expert? Answer questions, earn points and help others
