Question about Nesco Open Country 350 Watt Meat GRINDER
I have a open country meat grinder, Model # FG-350SK, . The gear that had the turning rod in it has broking and I woud like to get a replacement for it.
I need to order the main gear shaft. Can you help me with that?
I have meat grinder mtncearsmith mtn36 and i have problems i need repairs
is it the auger not turning?
Meat Grinder - MTN36: Auger Not Rotating - YouTube
? 1:35
https://www.youtube.com/watch?v=xlzkmd2qFwg
Dec 9, 2014 - Uploaded by Fe Service
Meat Grinder - MTN36: Auger Not Rotating. Fe Service. Loading... Unsubscribe from Fe Service? Cancel ...
For repairs, click the link
mtn36 meat grinder repairs Google Search
Jul 29, 2017 | Kitchen Appliances - Others
Model EH8804. Where can I get a replacement switch?
That is a specialised switch as it looks oval and is a three position switch on, off reverse. It _may_ be a standard switch underneath and the button is separate. A new grinder is only 40 bucks here
http://www.heartlandamerica.com/savoureux-pro-liner-meat-grinder.html
If you take it apart, you may be able to ID the switch on these images?
http://www.bing.com/images/search?q=replacement+switches&FORM=HDRSC2
Mar 10, 2016 | SAVOUREUX PRO LINE Meat Grinder
I need to order a gear for the meat grinder, where do I order them
I need gearbox of my gearsmith meat grinder, but where it find, I do not know yet.
Dec 11, 2014 | MTN Gearsmith New 3000W/ 3.4HP Compact...
Where can I get replacement blades?
http://www.amazon.com/Sunmile-Grinder-Cutting-Strictly-SM-G70/dp/B00M0ST9D4/ref=sr_1_1?ie=UTF8&qid=1417299151&sr=8-1&keywords=Blade+SM-G70%2FG73
Jun 15, 2014 | Sunmile 1.6HP 1200W 8 Meat Grinder UL...
Where can I purchase a replacement screw to hold the handle on my Model 323 meat chopper?
take the other side off and take it to a parts store and match it up. they will be able to match it for like to likeand cost you less than buying a full set.
Oct 23, 2013 | Universal Model 323 Food Grinder and Meat...
We have a "Back to Basics 4500" meat grinder that
The problem is due to the gears that have been damaged and if not then is the motor, many times the first problem leads to the second and the manufacture does not give any of the motor replacing parts only the extrenal parts which you find at the link Also here is the manual of your grinder at which you can remove all external parts and try to rotate the motor forward or reverse if not any reactions then we sugest for a replacement apliance.
Feb 01, 2012 | Back to Basics 4500BTB Electric Meat...
Nesco Open Country 350 Watt Meat GRINDER Logo
316 people viewed this question
Top Nesco Kitchen Appliances - Others Experts
Owen Barnes
Andrew Taylor
Andrew Taylor
Are you a Nesco Kitchen Appliances - Other Expert? Answer questions, earn points and help others
