Question about Rascal 318 Electric Scooter
On My Rascal 318 I have 2 flashing lights in the middle what does this mean?
I put new battery in it because I have not used it in over 2 years but I get two amber(yellow) in the middle what does this mean?
Used scooter, new batteries that were charged off the machine when i bought it, now the rascal wont charge the batteries..any suggestions
Is there a particular battery charger for this vehicle? Can you use a car battery charger directly to the batteries?
Jul 17, 2015 | Health & Beauty
How to change batteries in a Rascal
The Rascal 600/300, remove the seat, lift off the cover, unplug a battery, replace the old battery with a new one, putting the cable connections on the same way, red is +, black is -. Do the same with the next battery, reconnect the anderson plugs,reinstall the cover and seat and plug in the charger with the key on watch to see the needle raises up toward the full mark, allow to charge fully, overnight is good. keep the bats charged up not allowing them to drop below half way for the first 20 charges to break in the batteries. as a rule charge the scooter after every use!
Scooter Doctor App
Jun 29, 2014 | Rascal 300 Electric Scooter - Used...
I replaced the controller on a rascal 318 scooter
an aftamarket part can do this--but chec all grounds and wiring again-is the battery at 12.6volts-any less is a factor--seek a maintenance manual online or somethin similar at ur library
May 28, 2014 | Rascal 318 Electric Scooter
Joy stick to fast 318 power chair
Hi, Unless you have access to a PG Drives fault/programmer unit, You will need to go to a Rascal dealer to sort this out for you.
Feb 09, 2014 | Rascal 600 T Electric Scooter w Seat Lift...
I have a 3 wheel falcon. Its wonderful but all of a sudden I'm going along and it stops short for no reason
When the failure occurs does a light flash on the tiller. If you see a flashing light count the number of flashes get back to me, your controller has found something wrong. When the scooter stops short do any lights light or is the scooter completely dead. Take the batteries to a battery shop.Have them load test them. I have a Rascal 600t my batteries will put out 500 cranking amps. If the batteries test good have the shop charge them up for you. Does it work right now. Yes, check your charger. No, check the freewheel mechanism when its in freewheel mode it electrically disconnects the motor. Well this thing gets wet at times i have to WD40 mine to get it to work right. The last thing to do is but the back end up,run it, while wiggling wires. Pay particular attention to connectors. The toggle switch in the tiller often gets intermittent. On my scooter the plugs on my get loose causing my scooter to fault out or to stall.Hope this helps
Jun 01, 2012 | Pride Sonic 3 Wheel Portable Scooter
My Rascal 318 has two constantly flashing yellow light and will not work. Help
Hi wrosser2
Two constant yellow flashing lights indicates three things
1. Low voltage. Load test your batteries even if they are new. You may need to take them out and charge them on a car charger. Your charger won't work without at least 20 - 22 volts. Your inhibitor on the charger won't close to make continuity to turn the charger on.
2. With an olms meter check your front to rear harness for continuity. If you have a bad wire, replace the front to rear harness.
3. Third and most costly is a bad controller. No way to check that without replacing it. Check 1 & 2 first.
Good Luck
mimobility
May 03, 2011 | Medline Industries MDS808450 Excel...
BMW 318 would not start this morning Error code 2BOA?
I think you need a new battery.
Replace it and the radio will probably reset ok when you input the code..
Jul 09, 2009 | 1996 BMW 318
Rascal 318 Electric Scooter Logo
63 people viewed this question
Top Rascal Health & Beauty Experts
Robin Hill
Robin Hill
Scooter Doctor
Scooter Doctor
john h
Are you a Rascal Health and Beauty Expert? Answer questions, earn points and help others
